It is currently Sun Jul 27, 2025 1:34 pm
 Post subject: Anybody use Strobosoft?
PostPosted: Sat May 24, 2008 9:26 am
Wondering if you've used it with a good sound card.
PostPosted: Sat May 24, 2008 10:59 am
I've got and it works very well (at least the Mac version), it's very accurate, easy to use, but I've never taken the time to play with all the adjustments & bells and whistles. I'd recommend getting the little inexpensive Peterson mic (TP-2) that can clip onto onto you peghead to get a signal w/o interference from ambient sounds. (you'll need a jack to convert the 1/4 phone plug into a mini plug to connect to the sound connection on your computer.
I might add that although I have this software, most of the time I use an old fashioned tuning fork out of habit or a little Korg CA - 30 (an inexpensive chromatic tuner). The main advantage to these are you don't have to be near your computer to tune up & they're cheap.
For the optimum of cheapness/funtion in the digital world - I like the freaky tuner - a free download that lets you match an audio pitch from a wide range of instruments and in a 3 octive range of notes. Very handy.
(If you search freaky tuner on the web you'll see sites for either PC or Mac downloads.
Hope this helps, john
PostPosted: Sat May 24, 2008 12:11 pm
Yes but just on my glorious Mac Book. :D I like it - woks great!
PostPosted: Sat May 24, 2008 8:54 pm
Thanks for the input, guys.
I'm also interested in using it for intonation. Any experiences?
PostPosted: Sat May 24, 2008 9:22 pm
I sure have Pat my friend but again just with a Mac Book and the integral mic. StroboSoft picks up the sound as well as or better than any of the digital tuners that I have.
When I first licensed StroboSoft I always used it when setting up and intonating guitars in conjunction with a Korg or Boss digital tuner. I did this mostly because it was new to me and I didn't trust it. These days I believe that StroboSoft is as accurate or more accurate as any digital tuner that I have used.
Also, not to high-jack here, but there is or was a pick-up available for the Strobo non-software tuners and I wanted to get one to plug into my Mac and try it out. The jack is the wrong size if I recall but there were/are adapters available. Has anyone done this using the pick-up with StroboSoft?
PostPosted: Sat May 24, 2008 11:23 pm
Thanks, Hesh. I believe I will check it out.
PostPosted: Sat May 24, 2008 11:55 pm
I'm trying to figure out how to post a photo. Hope this works. As mentioned above -
there is a clip on peterson mic (TC-2) that works really well. I bought one from Stew Mac for around
$15. The mic cable comes with a 1/4" phone jack that needs an adapter to take it down to a mini
plug that will plug into your computer. I have mine plugged into a mac book pro - which I hope the photo
will show - providing it appears on the post.
j
PostPosted: Sat May 24, 2008 11:59 pm
well glory halleluya
p.s. the mic can be plugged anywhere but I've found it works best clipped onto the peghead.
It works much better than the built in computer mic - as there's no influence from ambient
noise.
j
PostPosted: Sun May 25, 2008 12:23 am
I just tried a seymour-duncan acoustic tube pickup hooked into the
strobosoft and it works like a charm. You'll still need that 1/4" to mini
adapter. One feature of this pick up that is handy is the volume control.
You can adjust the volume on the computer as well.
I also tried an electric guitar plugged into the strobosoft - again
with the adapter and it works as well. You can pick one of those adapters up
at any Radio Shack of probably most music stores.
john
