It is currently Sun Jul 27, 2025 3:53 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Bias tape question
PostPosted: Fri May 16, 2008 2:06 pm
I tested nylon twill weave tape against cotton-poly bias tape for strength as side reinforcements. I glued the tapes to standard sized samples of side wood, and found out how much force it took to break the samples. The nylon tape was much stronger as a material than the cotton-poly, but it dodn't glue well with either Titebond or HHG. The nylon tapes tended to come unstuck from the samples rather than breaking, and the samples with the nylon tapes broke at lower force than the ones with cotton-poly.
There is a place that makes linen twill tape, but iirc, you have to order 75 feet at a ime, and it only comes in white.
PostPosted: Fri May 16, 2008 7:41 pm
Alex buddy the primary function in life for a side tape, or brace for that matter, is to stop a crack in the side from running along the side. So we want the tape or brace to be resistant to cracking/breaking especially in the direction that the side grain is running. Make sense?
PostPosted: Fri May 16, 2008 8:18 pm
I've been using Mrs. Wright's polyester twill tape for a couple of years now. I glue it with 5 minute epoxy. The epoxy sticks pretty well to polyester. The extra thickness does not seem to create any problem with the linings.
Works well for me !!
Mark
PostPosted: Sat May 17, 2008 11:32 am
I just ordered some silk ribbon to see what it's like and if it will work. It is thinner than cotton or linen without being fragile.
PostPosted: Tue May 20, 2008 11:55 am
Mark
Mark, were the guitars that experienced the "controlled contact with terrain" done up with Mrs. Wright's & epoxy?
Pete
PostPosted: Tue May 20, 2008 1:41 pm
Mark
Pete
I'm not sure, Pete. I think they may have been a different type of tape glued with Titebond. At this point, I don't really remember what I was doing then !!
I'm also not sure how "controlled" their contact with terrain was. I think if it had been controlled, there might have been no contact at all !! :-)
Mark
PostPosted: Tue May 20, 2008 11:19 pm
ToddStock wrote:
Controlled Flight Into Terrain (CFIT) - just means the aircraft was in controlled flight when it hit the ground(i.e., not in bits and pieces or in stall/spin, etc.). No one intends to hit terrain, but gravity and pilot error show up without invitation.
CFIT it was then.
....learn something every day
M
