It is currently Sun Jul 27, 2025 4:59 am
PostPosted: Fri May 16, 2008 8:08 am
I have a cheap Indian Rosewood back and side set that I want to use...The Back is a lot lighter than the sides....I am going to try and stain the back to the same color as the sides...I will be using Z-Poxy and French Polish as the Finish.....Should I use a water or oil based stain or does it matter......Thanks
PostPosted: Fri May 16, 2008 10:03 am
First name: Jim Howell
IMHO, it shouldn't matter as the stain should be sealed under shellac for the FP. Matching will probably take some experimenting, so hopefully you have some off-cuts that you can play with prior to committing to the guitar.
Jim Howell
Charlotte, NC
PostPosted: Fri May 16, 2008 10:48 am
I'd use a water based stain, as both the z-poxy and the shellac are alcohol solvent, then there is less chance of them reactivating the stain and transfering it to bindings, purflings etc.
PostPosted: Fri May 16, 2008 11:55 am
I'd think that this is a reason to use oil based.
PostPosted: Fri May 16, 2008 1:13 pm
I use StewMac stains in alcohol under Z-Poxy. No problems, been doing it for years.
Jimmy Caldwell
Users browsing this forum: ballbanjos and 17 guests
cron
