It is currently Fri Jul 25, 2025 7:11 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
 Post subject: Re: Body Done
PostPosted: Thu Apr 17, 2008 6:05 pm
I guess the other thing you should check is what scale length the body is built for. It's possible you could have the right fretboard and the wrong neck.
Good Luck
Terry
PostPosted: Thu Apr 17, 2008 6:06 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
It looks like 14" from nut to 14th fret.
Its 12 5/8" to 12 fret.
PostPosted: Thu Apr 17, 2008 6:21 pm
First name: Jimmie (Jim)
Last Name: Hall
City: Columbia
State: SC
Zip/Postal Code: 29223
Good Luck
Terry
It looks like the top was cut for a long scale. Thats why the roset joint is uncovered at the end of the fingerboard. The longscale board will cover that.
Jim
Edit: oops, you could be right.
If you can't do something well, learn to enjoy doing it poorly.
PostPosted: Thu Apr 17, 2008 7:31 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Good Luck
Terry
Jim
Yup, looks like a long scale FB on a neck meant for something else. All agree? Wonder what the neck was for?
PostPosted: Fri Apr 18, 2008 1:37 pm
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
Guys, guys,..... no need to speculate! grab a phone and a tape measure and call John Hall. He is the best authority on this kit. If there was a mistake in the assembly of parts for this kit I am sure he will make it more than right.
Steve Walden
Aspiring Builder,
Bartlesville, OK
PostPosted: Fri Apr 18, 2008 3:21 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
....uh, that is exactly what I have been doing. Whats wrong with talking about it too?
John is shipping something out, but did not tell me what it was (yet).
PostPosted: Sun Apr 20, 2008 9:59 am
Last Name: O'Melia
City: Huntsville
State: Alabama
John says I have the wrong FB.
PostPosted: Mon Apr 21, 2008 3:27 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
The pin is to locate the fingerboard properly and keep it in alignment when glueing it to the neck. If the fingerboard has holes in it that fit over the pins in the neck, and the fingerboard does NOT meet the body at the 14th fret, then you have the wrong fret scale of the fingerboard. I have used this fingerboard / neck combination numerous times, and it looks like the fingerboard is too narrow for the neck, even if you were to blend the neck and fingerboard. I'm quite certain you have the wrong fingerboard.
John Ressler
PostPosted: Mon Apr 21, 2008 10:31 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Hmmm, I did request a 1 11/16" FB. I wanted a narrow FB.
John is working on it.
