It is currently Thu Jul 17, 2025 10:54 pm
PostPosted: Sat Mar 29, 2008 12:36 pm
First name: David
Last Name: LaPlante
Here is my process for making a simple meander. The first thing to do is to work out the design on paper. Since I had some Brazilian rosewood side trimmings that were precisely 2mm thick, and intended to use a maple veneer .6mm thick, I worked the design out on graph paper with each square representing .2mm.
Thus three squares for the maple and ten for the rosewood.
Here is the drawing:
Note each piece has been color coded to distinguish it from the adjacent pieces. There are 2 pairs each of both laminated and plain stock in wide and narrow configurations plus a single 10mm wide maple veneer strip.
Here's the lay up for gluing the veneer to the rosewood
The #2 and #4 pieces will be cut from the laminated stock.
It is very important to cut precisely to the width indicated on the graph drawing
I'm using a Proxxon table saw (also available from Micromark) with the Micromark precision fence. This saw is well scaled to pieces this size.
Precision is important, any error will accumulate in the finished lay up and throw the pattern out of whack.
I also have a smaller Micro mark saw of the type use by model makers which is neeeded to cut the veneer sheets without shattering them.
Here are the pieces, cut to size and laid out on the pattern. Beyond is the pile of 2nds. You have to be very persnickety about discarding pieces that are not the correct size or have serious flaws as this will show up in the finished product.
PostPosted: Sat Mar 29, 2008 1:01 pm
First name: David
Last Name: LaPlante
OK, now its time to glue up the log. I've made a plexiglass jig that is cut to 90 degrees to help align the pieces.
I'm using Titebond...it dries quickly to facilitate assembly.
Once dry, the rest of the pieces are added and clamped
Here's a close up
Now the log is sawn into 2mm tiles with the thin kerf blade of the Micromark model saw.
This log produced 48 tiles which will be just enough for two rosettes.
Here is a detail of the finished tile.
PostPosted: Sat Mar 29, 2008 1:58 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
NICE David!!! [:Y:]
It's really great that you are doing & showing how to do all the great Torres inlays !
Thanks for showing us all your great work.
P.S. heading to Toga next weekend for the woodworkers show??
Mike Collins
PostPosted: Sat Mar 29, 2008 2:04 pm
Very cool...
PostPosted: Sat Mar 29, 2008 2:18 pm
Thanks, David. It is a very good tutorial on making this pattern.
PostPosted: Sat Mar 29, 2008 3:35 pm
First name: Gary
Last Name: Lee
Thanks for teaching us your beautiful execution of this timeless classic.
PostPosted: Sat Mar 29, 2008 5:47 pm
First name: Coe
Last Name: Franklin
City: Decatur
Cool!
Thanks, David.
PostPosted: Sun Mar 30, 2008 1:42 am
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
Thanks for making that look very easy. When you get to making the rosette, would you mind posting that to this thread as well. I think it would make a fabulous addition to the tutorial pages.
Great stuff.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Sun Mar 30, 2008 6:52 am
Beautiful work, David. Great photos. Thanks for the tutorial. Let us see the rosette when it's done, please.
Max
Max Bishop
Brighton, Michigan
PostPosted: Sun Mar 30, 2008 7:47 am
Nice Dave, an excellent technique. I'm going to make a copy for my shop notebook.
I used to use one of those micro-mark table saws, they work amazingly well, remarkable for such a small saw.
PostPosted: Sun Mar 30, 2008 2:36 pm
First name: David
Last Name: LaPlante
OK, for those of you who asked here are the next steps.
This is my work board, it's a piece of pine (easy to pin into) covered with release sheets from double faced adhesive. The mahogany disk is cut at 90 mm. The disk is waxed to prevent glue from sticking.The central rod centers the disk and figures later in the process.
Here are the components of the rosette, meander tiles, rosewood wedges also cut at 2mm, simple layered marquetry strips, .6mm Rosewood and maple veneer strips.
The veneer strips and marquetry strips are all heated through a moist cloth using a banding iron. This softens them so that they easily make the radius of the form.
Here is the first rosewood strip positioned, the marquetry strip comes next followed by the bordering maple strip.
The inner edges of the tiles are hand radiused with an exacto knife
Next the wedges and tiles are worked around the radius. These are alternated and held in place with push pins. I'm using fish glue for the assembly and checking to keep the pattern tangential to the center. Any slight variance as you go can be adjusted by making small bevel cuts to the tiles.
I work the tiles and wedges around to the point where the gap left will be covered by the fret board.
Last edited by David LaPlante on Sun Mar 30, 2008 2:49 pm, edited 2 times in total.
PostPosted: Sun Mar 30, 2008 2:45 pm
First name: David
Last Name: LaPlante
As mentioned, this is where the post comes in, for the Stew Mac dremel attachment which is used to trim and true up the tiles.
The outside rings are now added (in reverse order to the inner rings). Again, using the banding iron trough a wet cloth to soften them.
Here's the rosette completely assembled.
PostPosted: Sun Mar 30, 2008 3:00 pm
Dave, Your circle cutter looks like it has a 1/4 inch post instead of the stew mac standard 3/16, 1/4 would be nice, did you make it yourself? Also, I use wax paper but the double stick stuff looks like a better idea, can you recommend a source?
PostPosted: Sun Mar 30, 2008 3:18 pm
First name: David
Last Name: LaPlante
Marc, I just substituted the 1/4" post supplied with my LMI hand rosette cutter and reamed the Stew Mac jig. I use both for cutting the rosette channel in the top.
I get the release sheets as scrap from the laminating operation at work.......perhaps a photo mural place would have scrap?
PostPosted: Mon Mar 31, 2008 6:35 am
WOW David, that is a very neat operation, and extremely generous of you to share your technique with us , at what degree do you cut the small wedges ? are the angles 2 mm ? I am still in the inch mode ! LOL thanks Jody
PostPosted: Mon Mar 31, 2008 9:08 am
Nice, David. I'm glad to see how to use a work board for building a rosette. This way lets you work easily from the inside out.
PostPosted: Tue Apr 01, 2008 7:26 pm
David, brilliant and beautiful work. I almost missed this thread. Putting together photo essays like this takes a lot of time and I certainly appreciate the effort and knowledge passed on. Thank you!
You have the makings of good article for GuitarMaker here. They are always looking for material and this thread could readily be converted into a very worthwhile article.
PostPosted: Tue Apr 01, 2008 8:26 pm
First name: Josh
Last Name: French
City: Houston
Very cool David. Are you going to be making that rosette your standard? It looked great on your number 90 you posted.
Instagram: @jfrenchluthier
PostPosted: Tue Apr 01, 2008 8:36 pm
First name: David
Last Name: LaPlante
I think so Joshua, this one is simpler and bolder as well. I would like to find a design that isn't too labor intensive..............I think I may be zeroing in on it.......
Best!
Users browsing this forum: Michaeldc, oval soundhole and 12 guests
