It is currently Tue Jul 08, 2025 10:40 pm
PostPosted: Wed Mar 26, 2008 6:40 am
I am wanting to cut the slot deepr in a stock martin neck , I thought it would be easy enough to get a box core bit 3/8 0r 7/16 and just run the router a few times . but I am unable to find any with the guide bearing top of the cutter, is there another way to do this using basic shop, hand tools . thanks Jody
PostPosted: Wed Mar 26, 2008 6:47 am
You can use a very sharp chisel, checking your depth often, or a router plane. Scribe the sides of the channel with a knife to keep the side walls even.
Horton, MI
PostPosted: Wed Mar 26, 2008 8:31 am
You can make a reasonably long stick that just fits into the truss rod slot and put sand paper on the bottom. I have done this before. It works well if you only have to remove a little.
PostPosted: Wed Mar 26, 2008 9:34 am
If you have a drill press you could make a fence, set the depth you want and drill a series holes with a fornster bit. You can clean up with a chisel used like a scraper.
You could also find a bit with the bearing on top (they are out there ) that was smaller in dia. than your exsisting slot. (Much safer that way work from one side then the other. ) You would most likely have to clamp a piece of wood the length of the neck to extend the sides of the existing slot for a bearing guide as using the sides of your exsisting slot might not work out for depth if the bit was too long.
You could also use a template guide on your router with a straight bit. again a straight board clamped the right distance from your slot to compensate for the difference between the bit and guide and go from both sides.
A plunge router is safest in all cases but can be done carefuly with a standard router.
Link
PostPosted: Wed Mar 26, 2008 9:37 am
For a 3/8" slot here's the bit. It's called a Dado clean out cutter.
In the olden days the made these without a bearing, so you could get smaller diameters.
http://www.amanatool.com/routerbits/dad ... 475-s.html
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Wed Mar 26, 2008 4:45 pm
Thanks Kirt,Todd,Brock,Link, and Chas, for taking the time to reply , thanks for the many ideas , I should be able to pull it off with one , or a combination of several, thanks Jody
