It is currently Sun Jul 20, 2025 11:41 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 22, 2008 4:31 pm
crich wrote:
WOW. I don't know a thing about building violins, but I can appreciate the craftsmanship. How do you approach installing purflings. By hand? Clinton
Clinton when I started I cut the whole channel by hand. Now I have a jig for the Foredom tool that I use to cut most of the channel but the corners still have to be done by hand.
You can see from this that the corners are very tight!
PostPosted: Fri Feb 22, 2008 5:18 pm
Barry this is really impressive and very timely stuff, as you may remember I've carved the neck on my first violin, for my wife, she played with the LSO for many years, and I've nearly finished carving the top. Your info on fitting the bass bar came at just the right time. I can recommend making a violin, very therapeutic.
PostPosted: Fri Feb 22, 2008 5:29 pm
This is stunning stuff. Really, really beautiful.
I have been asked to make a violin for a grade 9 violinist, and I am balking a little, due to lack of experience for such an accomplished musician.. Perhaps one day...
Colin, can you post photographs of the violin when it is completed, please?
PostPosted: Fri Feb 22, 2008 5:47 pm
Sam, I assume there is a difference between a grade 9 violinist and a 9th grade violinist, at least in most cases! :D
PostPosted: Fri Feb 22, 2008 6:04 pm
Colin if there is anything I can do to help you with your wife's violin let me know.
PostPosted: Sat Feb 23, 2008 12:42 am
First name: Chuck
Last Name: Hutchison
City: Houston
Absolutely fantasticaly fabulous!!!
So that's how a violin neck is attached....No M & T, just butt joint and I assume the button does most of the holding power when its strung up to pitch?
Beautiful Barry, Just Beautiful! [:Y:]
PostPosted: Sat Feb 23, 2008 11:07 am
That is incredible work Barry! My son (only 7 years old right now) has been laying violin for about a year and half now and really enjoys it. So I will soon be starting one for him as well. Your post here will be VERY useful! I too love that Bubinga! and laminated neck. COOL!
PostPosted: Sat Feb 23, 2008 12:09 pm
Thanks Barry, don't worry I'll have plenty of questions for you, I'm fairly relaxed about it, but the soundpost installation is a bit daunting. But I never pass up expertise when available.
My biggest problem is fitting the work in with my other projects, but I'm finding it is good as procrastination for an original Venere lute I've got to restore!
PostPosted: Mon Feb 25, 2008 1:56 pm
I got the 1st coat of varnish on yesterday. Here are some photos with one coat of varnish. Also the scroll shot is a creative way to fix a major screw up. I whacked the completed scroll and knocked a chunk out of it. The fix was the customers suggestion.
PostPosted: Mon Feb 25, 2008 2:38 pm
Very nice customer! Clever too. It looks great. I love these violin threads.
PostPosted: Thu Mar 13, 2008 8:37 am
More progress! It has the final coat of varnish on it now. I will rub it out in a week or so.
PostPosted: Thu Mar 13, 2008 8:46 am
Looks very nice Barry. What varnish are you using? Brush or spray?
Laurent Brondel
West Paris, Maine - USA
PostPosted: Thu Mar 13, 2008 9:19 am
This is oil varnish that is brushed on. Only factory violins have sprayed finishes. Much different that fine guitars.
The varnish is a mastic,resin varnish made by Joe Robson. Excellent quality and really expensive.
He makes his varnish the old Cremonese way and carefully cooks it. 2 ozs. are $85.00!!!
It's a violin thing! There is a certain texture and clarity that only varnish made this way produces.
Once I get it rubbed out I will post some photos of the completed violin.
Users browsing this forum: TimAllen and 20 guests
