It is currently Fri Sep 19, 2025 4:35 pm
PostPosted: Thu Feb 21, 2008 7:09 pm
I usually use HHG to glue the neck block to the sides, but on this "cutaway" side I feel that I may not have a perfect purchase. It looks alright, but I thinking using an epoxy ( I have NHP brand from Rockler). I'm thinking that if there is any gap filling to be done it would be better served with the epoxy than HHG. Does anyone else do this? Clinton
PostPosted: Thu Feb 21, 2008 10:30 pm
I use epoxy for that, for the reasons you mention. Plus it is end grain. I think epoxy probably works better on end grain that HHG or Titebond. That said, I have used Titebond for that joint many times without any problems.
Mark
PostPosted: Thu Feb 21, 2008 11:47 pm
What does szing it with HHG accomplish? Does the sizing soften as the hot glue comes in contact? Does help "bridge any discrepancies? Clinton
PostPosted: Thu Feb 21, 2008 11:48 pm
I also use epoxy for that area. Let it thicken a little before clamping.
PostPosted: Fri Feb 22, 2008 4:00 pm
Thanks. I'll go with the NHP epoxy. Clinton
Users browsing this forum: No registered users and 42 guests
