It is currently Tue Sep 16, 2025 6:17 pm
PostPosted: Tue Feb 12, 2008 12:16 pm
First name: Martin
Last Name: Edwards
I'm doing a set up on a Schecter Ultracure electric.
Now I thought that with the Knopfler connection, that Schecter were reasonably good guitars.
the Jack socket was loose, so I took off the strat like rugbyball jack plate.
I couldn't believe what I found.
One of the screws was into the mahogany body wood, but the other screwed into the JOIN between the body & a block of white wood glued into place..... a glue join that was loose & wobbly.
good grief, I'm a "wing it" sort of guy, but this is a $800 guitar!!!
PostPosted: Tue Feb 12, 2008 12:19 pm
Production line and manufacturing tolerance issue. You will see things like this in many production line instruments all the time.
PostPosted: Tue Feb 12, 2008 2:26 pm
Nice guitar there Martin, have you played her yet?
Another reason why I dislike some factory built guitars. I see a lot like these hanging on the wall of my local guitar store!! Doesn't take long to find the flaws...
PostPosted: Tue Feb 12, 2008 2:33 pm
Most of Schecter's line is of entry level quality and ends up in the hands of players
who are young or inexperienced so teir quality reflects what the guys at Schecter
think their customer base will understand and accept. It's sad.
Would I let that out of my shop? No....which is the case for the large majority of
builders in the world. It is just a case of poor design and planning as well as a
lack of concern about what the customer deserves.
Regards,
Kevin Gallagher/Omega Guitars
PostPosted: Tue Feb 12, 2008 2:34 pm
I am my own worst critic when it comes to things like this. Some things I can "fix" and make it look like it was supposed to be that way. Other things like this I just couldnt let go without some better form of fixing the problem.
I have burned guitars that just have cosmetic problems because I dont ever want anybody to see them.
PostPosted: Tue Feb 12, 2008 3:19 pm
More likely, he asked himself one question, it being the last one you mentioned. [uncle] [headinwall]
PostPosted: Tue Feb 12, 2008 3:48 pm
First name: Martin
Last Name: Edwards
ToddStock wrote:
- Will the problem be visible to the customer?
- Will it adversely impact playability or tone?
- Do I really care?
what about "will the boss find out?"
PostPosted: Tue Feb 12, 2008 3:50 pm
- Do I really care?
That leads into "Does the Boss care?"
PostPosted: Tue Feb 12, 2008 6:04 pm
First name: Ringo
Good, cheap, or fast. Pick two.
PostPosted: Tue Feb 12, 2008 6:15 pm
I'm wondering how the screws even fit through the plate into the guitar? Aren't the screw holes predrilled on the jackplate? If so, how could the jackplate line up in the routed oval and not have the screw go into the proper place? Somebody really must have been asleep at the wheel here.
PostPosted: Tue Feb 12, 2008 6:19 pm
For me that would read:
Good, cheap, or fast. Pick one.
PostPosted: Tue Feb 12, 2008 6:23 pm
I don't see anything out of the ordinary there. The more you look, the lower your expectations of most guitars will become. I'd call that about par for an $800 guitar. If it were a $5000 custom shop guitar I might be a bit more disappointed, but still not the least bit shocked.
Users browsing this forum: Mike Thomas and 37 guests
