It is currently Mon Jul 21, 2025 2:21 pm
PostPosted: Tue Nov 06, 2007 11:30 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Some time ago Don Mayes (?) posted specs. for a bridge that was thinner at the high E (pitch), than at lower E.
Do you do this? If so, is the increasing distance from string to bridge hi E to lo E an advantage to finger-pickers or flatpickers?-or both?
PostPosted: Wed Nov 07, 2007 1:20 am
Last Name: Johnson
State: CO.
Am I stating the question or the facts wrong?
PostPosted: Wed Nov 07, 2007 2:45 am
thinning the bridge toward the treble side allows you to maintain a greater break angle on the treble stings where the saddle is lower. anyway, thats why i do it.
PostPosted: Wed Nov 07, 2007 3:14 am
Nope, I was told the exact same thing..."make it a bit thinner on the treble side of the bridge"...by the guy I built my first with.
But if I look at the pre-made saddles that are ordered from various places, they all have a symmetrical look to'em.
PostPosted: Wed Nov 07, 2007 10:31 am
That was me. But you can call me Don if you like....I kinda wish I were a
Don... hmm..
Anyway what Michael said is the reasoning behind it. I learned it from Dana
Bourgeois.
PostPosted: Wed Nov 07, 2007 10:39 pm
    I've always had my bridges a bit thinner at the treble end than at the bass
end just for that reason. It allows consistent saddle height across the bridge
while allowing the typical ower string height toward the treble end.
Hey Don,
    How are things ot there at the Mc facility? I'm sure they're lovng having
you around.
All the best,
Kevin Gallagher/Omega Guitars
PostPosted: Wed Nov 07, 2007 11:44 pm
Last Name: Johnson
State: CO.
Thanks soo much for your responses guys
PostPosted: Sat Nov 10, 2007 4:30 pm
[QUOTE=Kevin Gallagher]
Hey Don,
you around.
All the best,
Kevin Gallagher/Omega Guitars[/QUOTE]
Going really well. I'm heading to Missouri next week to visit John Griffin
at old standard to buy a bunch of red spruce for McPherson. Should be
fun. I'll try to take a lot of pics of his operation.    I LOVE having a three
day weekend every week!
PostPosted: Mon Nov 12, 2007 1:43 pm
   I also thin the treble side of my bridges and slot them. I do like to try an maintain a certain break angle. I use the slotting after construction to get the most from the guitar that I can.
   I don't want all treble but by tweaking the angles on the different strings you can get more depth out of the guitar and better balance the tones and voice for the client.
john hall
PostPosted: Mon Nov 12, 2007 3:59 pm
Interestingly, when you look at really fine Spanish classical guitars, what you'll see is that the fingerboard is planed at a twist to allow more relief on the bass side. This way, the height of the top of the saddle is more or less constant across the length, and so the torque load (assuming relatively constant string tension from string to string) is close to the same all the way across, and the bridge height is the same.   Quite deliberate, quite interesting. I've got a Ramirez 1a set up this way.
