It is currently Sun Jul 27, 2025 4:20 pm
PostPosted: Sat Sep 15, 2007 12:26 pm
Hola. I've seen a few of you do white purfling in your fretboards, and I
was curious what you use and how white it stays. Seems like ABS would
stay the cleanest. Anyone use white fiber though?
PostPosted: Sat Sep 15, 2007 12:35 pm
White fiber works great.   I think a lot of folks imagine problems where there aren't any...
PostPosted: Sat Sep 15, 2007 12:37 pm
Thanks Rick. I'll give it a go.
PostPosted: Sat Sep 15, 2007 1:41 pm
White celluloid.
PostPosted: Sat Sep 15, 2007 1:54 pm
That works fine, too.
PostPosted: Sat Sep 15, 2007 4:20 pm
Thanks guys. I've never used celluloid. Do you recommend the Weld-on
cement?
PostPosted: Sat Sep 15, 2007 5:21 pm
I get my best results with CA. Weld-on works, as does any acetone based cement. I've even glued it with PVA glues; if you give a wipe with acetone before using them, they can adhere OK, and I've even had OK results without the acetone wipe. But I trust CA the most. ABS plastic is quite a bit harder to glue than celluloid.
PostPosted: Sat Sep 15, 2007 11:28 pm
G'day Mike,
        Ivory for me !
Craig Lawrence
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Sun Sep 16, 2007 3:48 am
Thank you, Howard.
G'day Craig. That's a fine lookin' neck you got there. Did you have some
long pieces? I've got a bunch of reclaimed piano keys, but it would take
quite a while to cut them all up and prep.
PostPosted: Sun Sep 16, 2007 10:59 am
Yep Mike , it takes a lot of mucking around . Just one other reason it takes me thousands of hours to complete a guitar.
Key tops are graduated in thickness (front to rear),about .7m.m. to .5m.m. ,so you have to thickness them , which isn't easy when they are so short.
On top of that , nearly all of them will have hollows worn in them from the pianists fingers.
As a piano tuner ,I have quite a lot available and choose the tops from the very treble and bass ends of the keyboard ( less wear ).As Ivory comes in various colour shades, I take them off the same keyboard to keep the whole thing uniform in colour.
It's worth the effort ( to me anyway ) as I can't bring myself around to using plastic ,and hey! ,I've got ivory purfling !
Craig Lawrence
PostPosted: Sun Sep 16, 2007 11:54 am
I just bound a fretboard about an hour ago using maple veneer for the purfling.
PostPosted: Mon Sep 17, 2007 1:35 am
I also use maple. I prefer the natrul white of maple to the stark white of fiber or abs
PostPosted: Mon Sep 17, 2007 1:42 am
I am currently using cream colored plastic purfling which seems to better match the white purfling elsewhere that's under a lacquer finish.
PostPosted: Mon Sep 17, 2007 8:14 am
Great. Thanks for all the input, everyone.
