It is currently Fri Sep 19, 2025 4:20 am
PostPosted: Fri Aug 03, 2007 12:44 am
I have a couple of questions about using fiber sheets in laminations:
1. Are they strong enough to hold together as part of neck
    laminations and body laminations (for electric guitar).
2. Do you think their being less dense than wood will
    lessen the sustain significantly when used in
    laminations.
PostPosted: Fri Aug 03, 2007 1:26 am
Thanks, Hesh
I knew folks were using them, just curious to know if everyone thought they were structurally and tonally sound. I am planning to use them in the body of my first electric, unless someone can convince me it is unsound.
PostPosted: Fri Aug 03, 2007 1:36 am
Where do you guys buy your laminations? And what do you use to cut and plane them?
PostPosted: Fri Aug 03, 2007 4:25 am
I carry sheets in blue, green, maple, red and black I think...another of those things that I may not have up on the website yet . They are all .020. I also have b/w/b in sheets, they are all 6" x 36" I think.
PostPosted: Fri Aug 03, 2007 4:43 am
Ron,
I would use fiber laminations if I had too but my first choice would be maple or other type of veneer.... maybe dyed.
PostPosted: Fri Aug 03, 2007 8:20 am
I've used black fiber laminated into a bass body with a bird's eye maple top and a swamp ash main body. It worked just fine. Also, the density on that stuff is pretty high.
PostPosted: Fri Aug 03, 2007 2:30 pm
Thanks Rick and everyone else. I will proceed.
