It is currently Mon Jul 21, 2025 10:43 am
 Post subject: Bridge placement
PostPosted: Wed Aug 31, 2011 11:54 pm
First name: David
City: whitefish
State: MT
Any rules of thumb for bridge placement on a 25.5 scale length? I always seem to end up sharp and have to max out the saddles. I have double checked fingerboard scale (I have been using Stew Mac pre-slotted finger boards) and they are nut on. I usually set the saddles halfway and center that at 25.5 or 25 for PRS giving me a little wiggle room. It has not been a huge problem in the past because I had been using the Schaller roller bridge, but I'm using TonePros on the last few projects.
P.S. I'm using LSR roller nuts and Earvana compensated nuts.
Thanks in advance
 Post subject: Re: Bridge placement
PostPosted: Thu Sep 01, 2011 2:37 pm
First name: Jim
Last Name: Outman
City: LaGrange
State: GA
Zip/Postal Code: 30240
Stewmac has a fret calculator that gives bridge positions for various bridge types. Very handy.
http://www.stewmac.com/freeinfo/Frettin ... tcalc.html
PostPosted: Thu Sep 01, 2011 6:31 pm
First name: David
City: whitefish
State: MT
Thanks for the link, my frets are exactly on and I found the note at the bottom of the calculation
"Distance from the fretboard edge of the nut to center of forward-most mounting screw or pivot post."
I guess this would put a tunomatic style about 3/8 - 1/2 past the magic 25.5 number. I guess I will just float the bridge under tensioned strings to that point and check the intonation.
Nothing worse than spending a week carving a body to find out your bridge posts are off even a fraction of an inch [headinwall]
PostPosted: Fri Sep 02, 2011 2:08 pm
Last Name: Thiessen
City: Lexington Park
I have found that the stew mac calculator is not always accurate for all the bridges, mainly with tremolo's. If I were you, I would put the neck on, and make a "dry run" before you drill anything.
John Thiessen
http://www.iszacguitars.com
PostPosted: Mon Sep 05, 2011 12:36 am
I have a very tried and true method. Measure from the nut to the 12th fret, then repeat that, go up 1/4" and place your bridge.
