It is currently Fri Sep 19, 2025 6:12 pm
 Post subject: fret re-install
PostPosted: Sat Sep 15, 2018 1:29 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Fretted a board and had a half dozen that were not well seated. Took them all out, leveled the board again, and checked the slots, and am ready to re-install. Before I took then out, I filed the ends even with the binding on this bound board, then bevelled just a touch.
Is there a good way to get these frets back into their slots so I don't end up with a short and and a long end?
Ed
These users thanked the author Ruby50 for the post: Bri (Sun Sep 16, 2018 10:08 am)
 Post subject: Re: fret re-install
PostPosted: Sat Sep 15, 2018 3:42 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
I"m no repair guru but my instinct tells me I probably would ditch the removed frets and replace them with slightly longer ones.
The little extra could then be filed flush to the others with no worries. Wonder what the repair folk think:)
PostPosted: Sat Sep 15, 2018 3:46 pm
Last Name: Minch
City: Chestertown
At worst, I would move them up the board to the next position that was slightly shorter, then replace the longest - #19 in this case. But I have seen a couple of builders who cut the lengths and round the ends before installing, so there must be a way.
Ed
PostPosted: Sat Sep 15, 2018 3:53 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Gotcha, I'm not much help then. I do think you're right tho, "there must be a way." I'll stay tuned right here
for the answer.
PostPosted: Sat Sep 15, 2018 4:48 pm
When I have a fret pop loose after filing the ends I just place it back in the slot and let the "barbs" position it and tell me if I have it the right way around. If it is the wrong way around the fret will usually be noticeably off one side and the other.
PostPosted: Sat Sep 15, 2018 5:02 pm
Last Name: Kincheloe
Ed
I am one of those builders, and there's no trick to it. Just put the fret where you want it and hammer it in.
The barb scars in the slot can cause trouble if the barbs are very close to them, and want to realign to the old grooves. Although in your case, it might help you get them back exactly where they were originally. You can also turn the fret around, and usually the barbs will be aligned differently relative to the old grooves in the wood.
PostPosted: Sat Sep 15, 2018 6:11 pm
Last Name: Minch
City: Chestertown
Hadn't thought of the barb groove theory - I'll give it a try
Ed
PostPosted: Sat Sep 15, 2018 11:25 pm
I’d use new freshly radiused fret wire and use hide glue injected into the slot with a syringe and needle. The bottled Stuff is fine for frets.
Do you know why they were high?
These users thanked the author Terence Kennedy for the post: dpetrzelka (Sun Sep 16, 2018 10:25 am)
PostPosted: Sun Sep 16, 2018 6:29 am
State: Tennessee
If you can re-radius the pulled frets, you may be able to reinstall. I would use new fretwire.
PostPosted: Sun Sep 16, 2018 6:51 am
there comes a point where saving a penny may cost a dollar use new frets
I break the corner of the fret slot with a file then spray with water , allow a few minutes then use glue as a filler and lube it helps the barbs slip in and seat.
PostPosted: Sun Sep 16, 2018 7:31 am
Last Name: Minch
City: Chestertown
Thanks all
I installed an abalone strip down each side, then binding. I re-cut the slots after the abalone and unintentionally made them a little wide. I used Old Brown Glue (liquid hide) and I did not clamp long enough. I went blithely on my way down the fretboard and didn't notice that some had popped up. Look here and back one:
https://www.flickr.com/photos/ruby1638/43000477871/in/album-72157688488198220/
Ed
PostPosted: Sun Sep 16, 2018 8:33 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Ed, FWIW ,I use fish glue to lube, and a diamond triangular file from HF to create a slight bevelled opening for the fret to seat. I use a plastic hammer fromHF to secure the fret and then use a radioused caul from stew mac in an arbor press for the final press inn . I use a machinests 45 -90 machined gauge to check for flatness on at least 3 frets, I double check when finished with a moore and wright or other suitable machinests straightedge. I find the worst offenders for proper seating of frets is the uber thin frets used on mandos ukes and dulcimers , they are a total PITA and frequently resist seating properly especially in very hdwds like ebony . Hope it works !!!
PostPosted: Mon Sep 17, 2018 6:29 am
when working with pearl on the fretboard I use CA or tite bond with ebony. Prefer the ca
PostPosted: Mon Sep 17, 2018 10:29 am
Last Name: Minch
City: Chestertown
My daughter recommended medium density CA and that is what I am using. Her observations is that it is pressure that kicks the glue, so it will sit in liquid state in the slot until you install in the fret. I use a polished cobbler's hammer and they are seating very nicely but I have been clamping a curved caul on them for a couple of hours TO BE SURE, even though she suggested 5 minutes would be enough.
Thanks all - It's only a mistake if you can't fix it
Ed
PostPosted: Mon Oct 01, 2018 10:35 am
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
I used to crank out three guitars a day in a factory warranty shop: pull the frets, make the board flat, tap the frets back in, just enough fret work to fix any buzzing frets and make it look good. It never seemed to be a problem getting the frets centered. As I recall, I started at one end of the fret and didn't proceed unless that end was perfect.
PostPosted: Mon Oct 01, 2018 5:10 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
On refrets where the 13th or 15th fret will be pulled for neck removal and reset after the neck is on, we do exactly as we do to mark the ends of nuts, saddles, or other easily reversed components...we use a Sharpie to put a dot on the treble end (on top of fret; underside of nut or saddle, etc.). If a 'memory jogger' mark was not applied, it is easy enough to do as other suggested and dry-fit to determine how the fret must have come out.
- Beth Brower
