It is currently Tue Jul 29, 2025 7:34 am
 Post subject: Vinyl Sealer
PostPosted: Sat Feb 15, 2020 12:48 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Is it ok to spray vinyl sealer over epoxy pore fill? I use a final wash coat of epoxy when finished with pores. Finish will be nitro.
 Post subject: Re: Vinyl Sealer
PostPosted: Sat Feb 15, 2020 1:42 pm
I usually spray nitro directly on top of epoxy. Vinyl sealer doesn't adhere as well as nitro does to most things and has less clarity so I don't use it, but as long as the epoxy has cured (week?) it should be O.K.
PostPosted: Sat Feb 15, 2020 1:46 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
How about the top ?
PostPosted: Sat Feb 15, 2020 3:04 pm
Hi Mike,
I self seal the top with nitro. It is close grained and doesn't need any pore filling and I don't use epoxy on it (sometimes epoxy fill the rosette if it is porous material)
PostPosted: Sat Feb 15, 2020 3:31 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
While you do not need the sealer it won't hurt. I would use the recommended sealer for the finish from the same manufacturer.
**edited**
Brian
PostPosted: Sat Feb 15, 2020 4:09 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Its Mohawk (Behlen) sealer, for the Mohawk nitro. Think I'll just spray the top. Brian, did you mean "while u don't need" ?
These users thanked the author Mike OMelia for the post: B. Howard (Sun Feb 16, 2020 9:00 am)
PostPosted: Sun Feb 16, 2020 1:45 am
Last Name: Beaver
City: Lake Forest
I have never used Mohawk nitro, I use the Cardinal LuthierLac stuff and their vinyl sealer. I always try to use finish and undercoat from the same manufacture as you have done.
The only thing I can add is with Cardinal, it bonds much better if you spray the sealer (over cured epoxy or bare wood) and then follow up in 30-60 minutes with the first top coat. I suppose my point is it is best to follow the manufacturer recommendations.
Joe Beaver
Maker of Sawdust
PostPosted: Sun Feb 16, 2020 9:39 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I’ve done it without any issues over Z Poxy & over West Systems 105/207
I'm not a luthier.
PostPosted: Sun Feb 16, 2020 12:13 pm
First name: Freeman
Last Name: Keller
I also spray it over Zpoxy with no problems
