It is currently Wed Apr 30, 2025 11:57 am
PostPosted: Fri Mar 11, 2005 12:55 am
anybody know what taper the Martin Bridge Pin reamer is?The unit they sell on there site.
Thx
LK
PostPosted: Fri Mar 11, 2005 1:13 am
Lance I don't know what they sell but every Martin I have done any work on has had 5 deg pins so I would assume that the reamer they sell would be 5 deg.
PostPosted: Fri Mar 11, 2005 1:22 am
You can pick up the one they sell at your local Ace Hardware, that's where I got mine.
Martin has it for twenty bucks, click here.
Searching Ace Online, turned up nothing, but if you have a good older hardware store they may have this tool. Mine was about $15 locally.Dickey38422.4139930556
PostPosted: Fri Mar 11, 2005 2:17 am
If you want good reamers for bridge pins at a really reasonable price go to Grizzly. They are 1/2 the price of the StewMac products.
PostPosted: Fri Mar 11, 2005 3:23 am
I'll second buying from Grizzly. You can get a 3°, 5° and peghead reamer all for $49.95. Here is the link...Grizzly reamer set.
PostPosted: Fri Mar 11, 2005 4:04 am
Lance, I was picking up some termite treatment and passed over to tools to get these numbers for you.
They are exactly the same as Martin Guitarmaker's connection. Both priced at 15 and 17 before contractor discount. Not bad full price.
Lance you asked for degrees? It doesn't say on either tool or package, but they are correct for Martin pins.Dickey38422.5336111111
PostPosted: Fri Mar 11, 2005 10:35 am
I'll third the Grizzly set. Mine work just fine!
