It is currently Sat Jul 19, 2025 8:09 am
PostPosted: Mon May 12, 2025 6:58 pm
For the longest time I just used Dollarama craft/scrapbooking tape, and it was perfect. However, they don’t seem to carry it anymore. The stuff from Michael’s is useless, so I’ve resorted to cutting up strips of carpet tape which is tedious and cumbersome. Turns out I use two sided tape a lot…
PostPosted: Mon May 12, 2025 7:58 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
The StewMac stuff:
https://www.stewmac.com/luthier-tools-a ... a066e96539
But I also use more of the blue tape, CA glue trick than I used to.
These users thanked the author doncaparker for the post (total 2): Kbore (Mon May 12, 2025 11:01 pm) • Terence Kennedy (Mon May 12, 2025 8:19 pm)
PostPosted: Mon May 12, 2025 8:10 pm
First name: David
City: Napa
Zip/Postal Code: 94558
This was suggested by the Looth Group. I haven't tried it yet. But I just got it in the mail.
https://www.amazon.com/dp/B017IET8QM?re ... asin_title
PostPosted: Mon May 12, 2025 8:25 pm
I’ve always used Ace Hardware carpet tape of various tacks or for thin light tack book binding tape. I didn’t know SM carried it. Looks good.
Since SM stopped sending a printed catalog they probably carry a lot of stuff I don’t know about. I always enjoyed paging through a new copy.
These users thanked the author Terence Kennedy for the post: Kbore (Mon May 12, 2025 11:01 pm)
PostPosted: Mon May 12, 2025 9:45 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I've been using 3M 109 poster tape for about eight years. It's thin (~0.005", 0.13 mm) and has good holding power. I use it for things like holding pieces to a carrier to go through the drum sander and attaching templates like my headstock and bridge templates to wood. The only negative about it is that it doesn't tear off nicely from the dispenser, so I just cut off the pieces I want with scissors. It doesn't leave any adhesive behind.
These users thanked the author J De Rocher for the post (total 2): meddlingfool (Tue May 13, 2025 12:28 pm) • Kbore (Mon May 12, 2025 11:02 pm)
PostPosted: Mon May 12, 2025 11:17 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
The DS tape I use most is Scotch Double Sided tape and I usually get it from Dollar Tree. It adheres well on a clean surface and is generally removable without solvents.
An interesting tape I use sometimes is 3M 300SLE. THe "SLE" is Low Surface Energy and it sticks to polypropylene and polyethylene plastics very well. If I do use it on wood, and want to remove it, I use small pieces, use very minimal pressure and remove it promptly. It is serious adhesive and best for LE plastics but is good for temporarily holding large wood pieces. Its a beast to get off if you clamp it or leave it one for more than an hour. Its good for holding jigs and fixture parts that will be screwed together.
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: meddlingfool (Tue May 13, 2025 12:28 pm)
PostPosted: Tue May 13, 2025 12:28 am
Hmm…yes I had forgotten about Dollar Tree, perhaps they may have some. I’m after the 1/4” wide stuff. I use mostly for attaching sandpaper to sanding blocks, which I do a lot…
These users thanked the author meddlingfool for the post: Kbore (Tue May 13, 2025 9:16 am)
PostPosted: Tue May 13, 2025 6:53 am
Online
Last Name: Colbert
City: Anacortes
As mentioned above, I use 3M original blue and Hot stuff medium CA for holding bridges, fretboards etc on my CNC. It’s got great holding power and leaves zero glue residue.
These users thanked the author Michaeldc for the post: meddlingfool (Tue May 13, 2025 12:28 pm)
PostPosted: Tue May 13, 2025 10:02 am
First name: John "jd"
City: Santa Barbara
https://www.amazon.com/gp/product/B07CN ... X05MV&th=1
These users thanked the author windsurfer for the post (total 2): Kbore (Tue May 13, 2025 7:51 pm) • meddlingfool (Tue May 13, 2025 12:28 pm)
PostPosted: Tue May 13, 2025 12:14 pm
StewMac tape for me although I do use the CA/masking tape trick on occasion.
These users thanked the author SteveSmith for the post (total 2): Kbore (Tue May 13, 2025 7:51 pm) • meddlingfool (Tue May 13, 2025 12:28 pm)
PostPosted: Tue May 13, 2025 3:17 pm
Thanks for the reminder Kbore…Dollartree for the win.
These users thanked the author meddlingfool for the post (total 2): Juergen (Sat May 17, 2025 10:32 am) • Kbore (Tue May 13, 2025 7:50 pm)
PostPosted: Wed May 14, 2025 6:16 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I tried various double sided tapes since my return to Canada 10 years go, but have never been happy. Fortunately, I’ve travelled to New Zealand every 2 or 3 years and so stocked up on my return with the Sellotape I’ve been using for the last 20 years. It’s thin, holds well, and easy to use — ideal for making custom sanding blocks or holding bridges for routing. (Sellotape is a very old brand name that originated in the UK.)
In NZ and Australia it’s sold in various widths at home improvement centres in packaging like this:
https://www.bunnings.co.nz/sellotape-12mm-x-15m-double-sided-tape_p0145858
I see Amazon has what looks similar, but they say it’s easy to tear by hand, so doesn’t seem the same. I’ll continue to source mine as long as I can from New Zealand.
These users thanked the author Tim Mullin for the post: Kbore (Thu May 15, 2025 10:32 am)
PostPosted: Wed May 14, 2025 8:58 pm
Uline has about 20 different types...
Only problem is that their shipping is very expensive.
I buy my shipping boxes from them and even with shipping they are cheaper (or the same) as anyone else. and I get them the next day.
These users thanked the author Brad Goodman for the post: Kbore (Thu May 15, 2025 10:31 am)
PostPosted: Thu May 15, 2025 12:26 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
I’ve been using some I received from SM but it leaves a residue that doesn’t impress me. I just got an email from Lee Valley showing the double sided tape they have for holding templates sandpaper etc. I haven’t tried it yet but I’m going to pick some up. They are saying it doesn’t leave any residue and comes off cleanly in their advertising.
Might be worth a look Ed.
These users thanked the author Cal Maier for the post (total 2): Durero (Fri May 16, 2025 5:51 pm) • Kbore (Thu May 15, 2025 2:15 pm)
PostPosted: Sat May 17, 2025 7:22 am
Masking tape/CA for almost everything, sometime I use exhibition tape (comes off clean from one side, holds tight on the other) for sandpaper on boards for large areas.
These users thanked the author Colin North for the post: Kbore (Sun May 25, 2025 3:00 pm)
Users browsing this forum: Michaeldc and 22 guests
