It is currently Sat Jul 19, 2025 6:04 pm
 Post subject: Damaged top
PostPosted: Sat Sep 14, 2024 8:08 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Sooo, i started using my new router tower and leveling board. I was afraid to even start using it and with good reason. I learned the hard way that i need to cover all metal parts with leather. The guitar somehow fell off the supports and the top of a screw dug in.
I tried and tried to steam it out. I didn't make much progress.ImageImage
Sent from my SM-A546V using Tapatalk
Hutch
 Post subject: Re: Damaged top
PostPosted: Sat Sep 14, 2024 8:12 am
First name: Brad
Last Name: Combs
Where is it located on the top?
PostPosted: Sat Sep 14, 2024 8:17 am
First name: Juergen
Last Name: Gartemann
City: Bielefeld
State: NRW
Zip/Postal Code: 33719
Country: Germany
That is an very old trick of a furniture restauration man, my uncle. Make the dent wet, then rubb it very fast with the cork of a vine bottle, better a champagne bottle. Try it several times until the dent comes up again.
Gesendet von meinem SM-G950F mit Tapatalk
These users thanked the author Juergen for the post: CraigG (Sat Sep 21, 2024 1:49 pm)
PostPosted: Sat Sep 14, 2024 8:30 am
First name: Josh
Last Name: French
City: Houston
How long did you steam it for and what was your process? It looks like you have broken fibers in there, but it also looks like it should steam up quite a bit. This might be what you've already done, but if not try a wet (not dripping) paper towel and a clothes iron on it for 10-15 seconds, look at it, and then repeat and re-wet as needed. If it comes up nicely, I'd then brush some hot hide glue on it.
Instagram: @jfrenchluthier
PostPosted: Sat Sep 14, 2024 8:40 am
Last Name: Colbert
City: Anacortes
I prefer a soldering iron over a clothes iron - it’s easier to focus the heat.
M
These users thanked the author Michaeldc for the post: Kbore (Sat Sep 14, 2024 1:02 pm)
PostPosted: Sat Sep 14, 2024 9:06 am
I also prefer a soldering iron and a wet piece of cotton T-shirt for steaming out dents. Any reason you can't flip the top over and put the damage on the underside? EDIT: oops, I see the top is already glued on.
These users thanked the author SteveSmith for the post: Michaeldc (Sat Sep 14, 2024 9:18 am)
PostPosted: Sat Sep 14, 2024 9:13 am
First name: Josh
Last Name: French
City: Houston
I have always found the tip of a clothes iron to be fast and accurate, creating a lot of steam. But to each their own. I believe he is saying he was at the point of routing for his bindings when the guitar fell off the cradle, so there would be no turning the soundboard over at that point.
These users thanked the author jfrench for the post (total 2): SteveSmith (Sat Sep 14, 2024 9:37 am) • Michaeldc (Sat Sep 14, 2024 9:18 am)
PostPosted: Sat Sep 14, 2024 9:20 am
City: Tyler
Been there many times. Crushed fibers are harder to fix. If it were my ding, first thing I would do is put one single drop of water right in the center of it and leave it overnight. Then re-access.
PostPosted: Sat Sep 14, 2024 9:23 am
Last Name: Kincheloe
It does look like it should steam out. I boil some water in a pan, dip a piece of paper towel in it and set it on the dent, and press the pan against it for 20-30 seconds. No danger of overheating, as the water is no more than 212F to begin with, and cools off the longer you hold it.
If it really won't swell, you'll just have to graft in a piece of wood and live with a couple of horizontal glue lines. I'd cut out a rectangle between those two dark grain lines, and ignore the minor damage farther to the right.
PostPosted: Sat Sep 14, 2024 9:36 am
First name: Richard
City: Warwick
State: RI
That's a new method to me. I just used a damp paper towel and soldering iron. I made some progress but need a little more.
My binding ledges came out great! I made my own wooden bindings that are .06 thick and bend pretty easy. Im not sure if it's worth pre-bending.
Hutch
PostPosted: Sat Sep 14, 2024 9:40 am
First name: Richard
City: Warwick
State: RI
I'll consider this. Similarly, ieas thinking of scooping it out with a gouge and fiiling it with another scoop. I've done this before with good success.
Hutch
These users thanked the author banjopicks for the post: Kbore (Sat Sep 14, 2024 1:04 pm)
PostPosted: Sat Sep 14, 2024 11:27 am
First name: Ken
Last Name: Nagy
City: Goodrich
[/quote]I'll consider this. Similarly, ieas thinking of scooping it out with a gouge and fiiling it with another scoop. I've done this before with good success.
Sent from my SM-A546V using Tapatalk[/quote]
I've done that before with pitch pockets. If you have the same belly wood handy, and have it facing the right way, and pick the same grain pattern, it almost disappears.
Why be normal?
PostPosted: Sat Sep 14, 2024 2:15 pm
I prefer a soldering iron too. Soldering irons need to get up to at least 300 deg F to melt solder; clothes irons, not so much.
PostPosted: Sat Sep 14, 2024 8:20 pm
If steam does not do it I guess I’d consider grafting similar spruce from one of the off cuts in that area and do a burst. I don’t think you could ever completely hide that under a clear finish.
One thought, I always thin the edges of the lower bout after the box is closed but before binding. Got the idea from Dana Bourgeois’ voicing articles. You can look them up. He taps and feels the top vibrate while thinning.
On an OM with around a 0.118 top they usually wind up around 0.090-0.095. You can measure by looking at the exposed edge of top.
If you have a pretty thick top this might allow you to sand out some of what is left after steaming. You could recut the binding channels if needed.
Another thing, I didn’t see any shellac on that top. I always shellac the edges before cutting the channels and taping the bindings.
Let us know what you do :)
PostPosted: Sun Sep 15, 2024 5:05 am
Hutch my friend it may be too much of a dent with broken fibers, etc but there is no harm in trying:
http://luthiersforum.com/forum/viewtopic.php?f=10117&t=20604
PostPosted: Tue Sep 17, 2024 5:33 am
Pre-wet the dent so there is plenty of moisture to make steam within the fibers of the wood and then use the wet rag and iron or soldering iron. If you have a steam iron use the steam from the iron in addition to the wet rag. After raising the dent while the area is still wet, wipe the entire top with a wet cloth to help avoid water marks.
PostPosted: Tue Sep 17, 2024 9:16 am
First name: Richard
City: Warwick
State: RI
Upper bout where you rest your arm.
Hutch
These users thanked the author banjopicks for the post: bcombs510 (Tue Sep 17, 2024 5:40 pm)
PostPosted: Tue Sep 17, 2024 4:34 pm
This may be an opportunity to do an inlay.
Brent
PostPosted: Tue Sep 17, 2024 5:41 pm
First name: Brad
Last Name: Combs
Do you mean lower bout?
If the lower bout, maybe an arm bevel or similar? Provided it doesn’t steam out using the recommendations above.
These users thanked the author bcombs510 for the post: banjopicks (Wed Sep 18, 2024 8:20 am)
PostPosted: Tue Sep 17, 2024 7:46 pm
City: U.P.
That looks bad.
Because water wants to bead up and take a while to soak in, as others have mentioned give it some time to wet the wood.
But I tried applying a small drop to the dent. Then I heat up a dull pointed piece of metal, a tine of a stainless fork would work, in a propane torch till quite hot and just touch it to the bead of water. The water immediately comes to a boil as it soaks in to the dent. Repeat as necessary. Practice on a scrap dent.
What I like is it confines the heat and steam to the dent and you can see exactly what you are doing. It only takes a second per droplet.
It's my goto dent fix.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: Terence Kennedy (Tue Sep 17, 2024 11:00 pm)
PostPosted: Wed Sep 18, 2024 8:21 am
First name: Richard
City: Warwick
State: RI
Yes, lower bout.
Hutch
PostPosted: Sat Sep 21, 2024 4:47 am
First name: Richard
City: Warwick
State: RI
It's almost gone now. It took a bunch of steamings and plus a little heavy sanding. This looks acceptable to me, and i won't mess with it any further until finish time. It's neck carving time, yay!
Hutch
These users thanked the author banjopicks for the post (total 3): Michaeldc (Sat Sep 21, 2024 7:00 am) • SteveSmith (Sat Sep 21, 2024 6:50 am) • bcombs510 (Sat Sep 21, 2024 6:47 am)
Users browsing this forum: Bing [Bot] and 27 guests
