It is currently Sun Jul 20, 2025 7:16 am
PostPosted: Sun Sep 08, 2024 7:20 pm
What adhesive do you use to hold down inlays when tracing their outline?
Formerly know as Mandodiddle.
PostPosted: Sun Sep 08, 2024 8:34 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Very small dots of CA (smaller than a pin head). The number of dots depends on the size and shape of the inlay.
PostPosted: Sun Sep 08, 2024 9:58 pm
I do a dot of tightbond and hit the inlay with a heat gun to release it.
PostPosted: Sun Sep 08, 2024 10:24 pm
Tightbond and a drymount tacking iron to release.
PostPosted: Mon Sep 09, 2024 5:55 am
Last Name: Ball
Most of the time I use very small dots of CA. Then I pop them up with a scalpel. For really fragile inlays, I use a small dot of titebond and a tacking iron.
PostPosted: Mon Sep 09, 2024 8:39 am
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
Elmer's clear school glue, then use exacto knife to make pin dots around inlay. Chalk in the indentures lets you see outline while inlaying
PostPosted: Mon Sep 09, 2024 9:18 am
CA dissolves in acetone, and that's the way to get those fragile inlays loose.
PostPosted: Mon Sep 09, 2024 9:59 am
That can work for removing a K&K transducer too. Turn the guitar upside down and with a syringe saturate the area around the transducer with acetone. (Sorry about the thread drift). :)
These users thanked the author Terence Kennedy for the post (total 3): bcombs510 (Mon Sep 09, 2024 10:46 am) • Colin North (Mon Sep 09, 2024 10:28 am) • Kbore (Mon Sep 09, 2024 10:17 am)
PostPosted: Mon Sep 09, 2024 10:49 am
First name: Jay
City: Bothell
State: Washington
That's a good idea. What sort of syringe do you use to keep the acetone from dribbling out and getting where you don't want it since acetone has such low viscosity?
PostPosted: Mon Sep 09, 2024 11:56 am
I just used a small like 2.5cc syringe with a short section of iv tubing attached and long 25G spinal needle.
Guitar supported upside down on blocks and reached inside, positioned the needle by feel and saturated the bridge plate around the transducer. After a wait of several minutes a steady pull on the wires for a short period of time and they came loose.
I have only done it once. But isn’t the rule “see one-do one-teach one”? :)
These users thanked the author Terence Kennedy for the post (total 2): Kbore (Wed Sep 11, 2024 8:55 pm) • J De Rocher (Mon Sep 09, 2024 12:12 pm)
