It is currently Sat Jul 19, 2025 4:54 pm
 Post subject: Bending Richlite
PostPosted: Mon Jan 08, 2024 5:44 pm
Has anyone ever bent Richlite bindings? Just like wood?
Sent from my SM-N960U1 using Tapatalk
 Post subject: Re: Bending Richlite
PostPosted: Mon Jan 08, 2024 5:59 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
Just like wood if not easier.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
These users thanked the author Marcus for the post: Pmaj7 (Mon Jan 08, 2024 6:02 pm)
PostPosted: Mon Jan 08, 2024 6:06 pm
Thanks marcus! Did you just use the stuff they sell for cutting boards?
PostPosted: Mon Jan 08, 2024 6:11 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
I haven't used it since LMI stopped supplying it. I just bought the precut binding. I suspect they are the same tho!
-Marcus
Instagram | YouTube
These users thanked the author Marcus for the post: Pmaj7 (Mon Jan 08, 2024 6:11 pm)
PostPosted: Wed Jan 10, 2024 11:23 am
First name: R.M.
Last Name: Mottola
Not an answer to your query, but you may want to take some care about ventilation when you do this. Although it appears that off gassing of heated phenol–formaldehyde resins at typical bending temperatures is mostly water vapor (see https://www.ncbi.nlm.nih.gov/pmc/articles/PMC10346658/), it is the case that these resins when not fully cured off-gas formaldehyde.
R.M. Mottola
LiutaioMottola.com
Author of the books Building the Steel String Acoustic Guitar, Practical Design of the Acoustic Guitar and Similar Instruments, and Mottola's Cyclopedic Dictionary of Lutherie Terms.
I don't check in here very often. If you need to contact me the best bet is via email through the contact page on my site.
These users thanked the author rmmottola for the post (total 2): Kbore (Fri Jan 12, 2024 7:08 am) • Pmaj7 (Wed Jan 10, 2024 12:37 pm)
PostPosted: Thu Jan 11, 2024 3:58 pm
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
Be careful to know the difference between Richlight and Rocklight. If you do a search, you will find that they are different materials. When LMII was supplying a processed wood binding material, it was Rocklight Ebano. Richlight is some sort of paper and resin composite that, I think, is available in the US. As far as I know, it is less suitable for bending than Rocklight. Also as far as I know, Rocklight is no longer available in the US, though I would like to be shown wrong by someone. I recently looked and found a Canadian supplier, though the price is on the high side. My recollection is that it bends pretty well, and certainly more reliably than the commonly available West African Ebony. I just found four pieces of Rocklight bindings that I didn't know I had and will shortly be machine bending them. If it doesn't work out, I'll let you know.
These users thanked the author saltytri for the post: Pmaj7 (Thu Jan 11, 2024 4:41 pm)
PostPosted: Fri Jan 12, 2024 2:51 am
Ok, so I was confusing the two. I noticed that LMI sells Richlite fretboards, so I assumed that the bindings they used to sell were the same. But sounds like that was Rocklite, which is not available in US now.
Salty, do you know someone who tried to bend Richlite?
PostPosted: Fri Jan 12, 2024 4:02 am
Last Name: Bradley
Country: United Kingdom
Rocklite is a breeze to bend, I can confirm.
These users thanked the author mikeyb2 for the post (total 2): Pmaj7 (Fri Jan 12, 2024 10:12 am) • Kbore (Fri Jan 12, 2024 7:09 am)
PostPosted: Fri Jan 12, 2024 2:30 pm
I used the Rocklite bindings from LMI. Extremely easy to bend.
These users thanked the author James Orr for the post: Pmaj7 (Fri Jan 12, 2024 3:46 pm)
PostPosted: Mon Jan 29, 2024 10:27 am
First name: David
Last Name: Ingalls
City: Ashland
State: OR
I just bent a set of Rocklight Ebano bindings for a tenor uke. As many of you may know, the waist bends on a uke are tight, more so than on a guitar except, possibly, in a cutaway. They came out of my bending machine just fine.
I can't say for sure if it's me or the wood but I've had miserable experiences lately with trying to bend ebony bindings. Too much run out, too many breaks. I'm fed up with throwing away expensive wood.
As far as I know, there is now no US supplier for Rocklight products. Fortunately, a Canadian company carries them and will ship to the US:
https://www.facebook.com/EdCoFineWoods
Highly recommended. They sent a bunch of bindings to me in bulletproof packaging via Canada Post, which hands off seamlessly to USPS for delivery here.
These users thanked the author saltytri for the post: Pmaj7 (Wed Jan 31, 2024 11:00 pm)
Users browsing this forum: Bing [Bot] and 24 guests
