It is currently Sun Jul 20, 2025 8:14 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Sun Apr 30, 2023 11:28 am
First name: Brad
Last Name: Combs
I’m very late to the game. I tried the tool out yesterday on the latest build.
I love the simplicity of the interface, nothing to tweak really it just worked right out of the box.
The autorun feature and the visual cues to prepare to tap and then tap are a big help.
Am I correct in my thinking that I could take the identified fundamental after 5 taps and use it in the formula? Or should I have been doing more inspection of the results?
Plugging the numbers into the spreadsheet gave me a target thickness of .105. After thinning the joined plates that’s right when I started to get the whomp. :D
PostPosted: Wed May 24, 2023 4:03 pm
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
If you are testing a completed guitar:
Depending where you place the mic, what is reported as the fundamental "T(1,1)2" might be the air mode "T(1,1)1" if your mic is right in front of the sound hole. In fact the software just report the tallest peak as the fundamental. Just make sure this is not the case by blocking the sound hole with something (I use the thin styrofoam from a meat platter cut to size). When the soundhole is blocked the peak which disappear is the Air mode.
If you are testing a plate then yes the fundamental is the tallest peak and is the plate frequency.
These users thanked the author Alain Lambert for the post: bcombs510 (Wed May 24, 2023 6:46 pm)
PostPosted: Wed May 24, 2023 6:47 pm
First name: Brad
Last Name: Combs
Fabulous. Thanks, Alain. It’s a great tool! It seems the evaluation lasts forever now? Or is there still a licensing option?
PostPosted: Fri May 26, 2023 10:29 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Thank you!
What does the registration part entail? It says 7 days.
PostPosted: Fri May 26, 2023 12:19 pm
I might suggest putting effort into making it an app.
We all carry an expensive recording suite in our pockets and get annoyed when it actually rings. I’ve been using an FFT called iAnalyzer since 2008.
The idea of having to set up a computer with a mic seems cumbersome to me when you can just set your iPhone on the bench and go, not to mention that you can take it with you whenever you go. I’ve taken spectrums of hundreds of guitars by big names at shows, in stores, at other people’s shops etc. On the spot convenience…
These users thanked the author meddlingfool for the post (total 2): James Orr (Fri May 26, 2023 3:16 pm) • Durero (Fri May 26, 2023 1:25 pm)
PostPosted: Fri May 26, 2023 2:39 pm
First name: Brad
Last Name: Combs
An app would be great. :) Plus you get a built in channel and transact ability in the App Store!
PostPosted: Fri May 26, 2023 3:37 pm
Particularly if that app included the spreadsheet where you can type in your data and have it spit out target thickness…
These users thanked the author meddlingfool for the post: bcombs510 (Fri May 26, 2023 6:23 pm)
PostPosted: Fri May 26, 2023 6:25 pm
First name: Brad
Last Name: Combs
I’m guessing that’s getting into IP infringement territory? I don’t really know. I expect that replicating the formulas in a commercially available product would cross a line that the spreadsheet floating around the internet doesn’t? Would be curious to know. :)
PostPosted: Fri May 26, 2023 8:13 pm
Point…but, can you own maths?
These users thanked the author meddlingfool for the post: bcombs510 (Fri May 26, 2023 8:44 pm)
PostPosted: Sat May 27, 2023 9:23 am
The answer to that is a big no.
PostPosted: Sat May 27, 2023 4:39 pm
First name: Josh
Can you own “math”? No.
Can you own an algorithm or series of algorithms that implement existing math in some novel or useful way which you intend to sell as a product? Yes.
PostPosted: Tue May 30, 2023 6:58 pm
First name: Alain
Last Name: Lambert
State: Quebec
Mike OMelia wrote:
Thank you!
The 7 days are days of use, not calendar or consecutive days. So, with a little planning, you have plenty of time to make a guitar.
Users browsing this forum: No registered users and 115 guests
