It is currently Sun Jul 20, 2025 2:11 am
 Post subject: White spots on redwood
PostPosted: Mon Jan 09, 2023 8:55 am
First name: gary
Last Name: davis
City: BILLINGS
State: Montana
Zip/Postal Code: 59105
Greetings from Montana. I thinned my intended redwood soundboard too much and am looking at another set I have. I'm wondering about these white spots. Lots of research yielded little. My only guess at this point is salt efflorescence. This set came from California and is supposedly forest salvage. Salt from the ocean? I'm not saying they are uniformly through the sample but are present on both sides and both pieces. I assume these deposits will affect finishing. What about tone?
Any ideas or further research tips would be greatly appreciated.
Gary Davis
PostPosted: Mon Jan 09, 2023 9:33 am
Look like mineral deposits.
If it is ocean salt deposits water should remove them, so I would try that first.
If it's mineral deposits, see video https://www.youtube.com/watch?v=PGF0FohKcE8&t=88s
But you must test it outside the plate outline you're using it, and don't use a wire brush on redwood.
Apparently it's not uncommon in domestic redwood https://www.lmii.com/blog/2016/05/08/dealing-with-mineral-deposits-may-2016/ where it says they may disappear under shellac which is easily tested on an offcut/spare bit.
PostPosted: Mon Jan 09, 2023 12:07 pm
First name: gary
Last Name: davis
City: BILLINGS
State: Montana
OK - thanks for that. I did try some water yesterday (and sandpaper). Not much happened. I'll give it a better shot next time I'm at the shop.
If its salt, I'm assuming it would taste salty or would that be a dangerous thing to do-to taste it?
Gary
PostPosted: Mon Jan 09, 2023 12:13 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
how thick is the top?
Is it thick enough to sand it down without messing it up?
3/16 is fairly normal for suppliers.
sand with a palm sander in a spot that will NOT be in the guitar shape.
Mike Collins
PostPosted: Mon Jan 09, 2023 2:08 pm
Muriatic acid has worked for me on EIR with white spots. Might be worth a try, though it's nasty stuff. Take precautions.
PostPosted: Tue Jan 10, 2023 8:44 am
CLR us what I use to remove mineral deposits.
PostPosted: Tue Jan 10, 2023 10:20 am
First name: gary
Last Name: davis
City: BILLINGS
State: Montana
OK y'all. Thanks. I may get a chance to go over today. I'll report what I find.
Gary
PostPosted: Wed Jan 11, 2023 8:35 am
First name: gary
Last Name: davis
City: BILLINGS
State: Montana
I checked it out a bit more yesterday. There are just too many spots. Water seemed to do nothing. I'll just get another set - hopefully without spots.
Any recommendations for acquiring another redwood soundboard?
[[url][url=https://flic.kr/p/2oaQmtQ]Image[/url]Untitled by Gary Davis, on Flickr/url]
Gary Davis
PostPosted: Wed Jan 11, 2023 9:19 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I have bought some good sets from Vince Strauss https://www.pacificcoastwoods.net/.
PostPosted: Wed Jan 11, 2023 9:33 am
Last Name: Colbert
City: Anacortes
Gary Davis
Did you try CLR as per John's recommendation, or only water?
Thanks, M
PostPosted: Wed Jan 11, 2023 10:12 am
First name: gary
Last Name: davis
City: BILLINGS
State: Montana
Only water. I'll try the CLR.
Gary
These users thanked the author Gary Davis for the post: Michaeldc (Wed Jan 11, 2023 10:20 am)
PostPosted: Wed Jan 11, 2023 10:34 am
Last Name: Kincheloe
This sinker set had some white spots, but they pretty much disappeared when coated with shellac.
Pour a pool on it and push it around so it can really soak in before it dries. The initial shellac application makes a big difference to the appearance. If the initial coat is done with a fairly dry cloth, it will create a thin film just on the surface and prevent further coats from penetrating. Useful for preventing endgrain from darkening, but in this case we want to see if the mineral spots go clear when fully wetted. And deeper penetration usually looks better on soundboards anyway.
PostPosted: Wed Jan 11, 2023 12:35 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Gary Davis
Felly Smith at Fiddleback Woodshack in Bend, OR is a good source for nice redwood tops. He doesn't have sets posted on his website right now, but he's going been doing several runs of very nice redwood tops and posting about them as he does them on Instagram. I think they've been selling too fast to be worth putting up on his website. I recently bought several sets from him. If you contact him, he'll send you photos of top sets that are available. Felly's a good guy to deal with.
http://www.fiddlebackwoodshack.com/products.php?id=2
PostPosted: Fri Jan 13, 2023 7:30 am
First name: gary
Last Name: davis
City: BILLINGS
State: Montana
Thanks Jay. I've acquired a few pieces from Fiddleback. I'll contact him.
Thanks for the images Dennis. I think I'll get another set and experiment with this one. I'll mix up some shellac.
Gary
cron
