It is currently Sun Jul 20, 2025 12:48 pm
PostPosted: Fri Oct 08, 2021 5:42 pm
Well wouldn't you know it. I finally found a pore filler (System 3 Silvertip) that I like with Enduro-Var finish and the inside of my forearms are breaking out in a rash.
Any body else have this happen and have you found an alternative pore filler that you like? I would prefer a pore filler that is clear and one that is compatible with Endurovar.
Formerly know as Mandodiddle.
PostPosted: Fri Oct 08, 2021 5:56 pm
I am allergic to epoxy and I will no longer use it regardless of how small the job and how much protection I think I have. Do not fool yourself by trying other brands and hoping they are not as bad. As far as pore filling, I expect other members will give you many alternatives. Good luck.
PostPosted: Fri Oct 08, 2021 8:53 pm
Depending on the wood, you might consider filling the pores with Endurovar. When brushed on it builds pretty quickly. Test it on scrap of the same wood you will be finishing.
PostPosted: Fri Oct 08, 2021 9:31 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
It would be a shame if you had to stop using Silvertip. When do you get the rash? During application, during sanding, or both?
PostPosted: Fri Oct 08, 2021 10:55 pm
Both
PostPosted: Sat Oct 09, 2021 5:54 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Mr. Higgs:
This is not medical advice, nor should it be interpreted as such.
My understanding is that there are highly qualified medical professionals specializing in the treatment of occupationally-related allergies. I would imagine that consultation with this type of medical provider might afford a person suffering symptoms of contact dermatitis with very specific and useful information regarding prevention and post-exposure care. I would also imagine that - knowing which component of the epoxy system in use provokes the response - a person might be better equipped to search out a replacement material.
Also keep in mind that some two-pack finishes as well as nut and saddle repair materials may contain dimethacrylate monomer (i.e., epoxy acrylate) or other compounds, diluents, or residual monomers commonly seen in epoxy formulations.
Good luck and stay healthy!
- Beth Brower
PostPosted: Sat Oct 09, 2021 6:27 am
Although exposed by skin contact, some of my encounters resulted in the offending chemicals passing into my blood stream and causing systemic reactions. Do not approach this as only a localized reaction. Next time it might be worse.
PostPosted: Sat Oct 09, 2021 7:10 am
I bought some Aquacoat about a year ago and it's the best darn filler I've ever used. Easy peasy, water based, safe and dries fast and sands back well.
I do like to use CA as a filler too for many of the same reasons but it's not pleasant to work with too.
Someone said it once and I agree 100%, epoxy is good for boats ;)
I know a lot of you out there use it to great success but I like that snarky comment :)
PostPosted: Sat Oct 09, 2021 8:20 am
I'm also a fan of Aquacoat and prefer it over epoxy or oil-based fillers. Perhaps the OP might try this as an alternative.
PostPosted: Sat Oct 09, 2021 8:38 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Alternatives:
Pumice, shellac, and sawdust (too many debates about how important each is to the mix and how much of each is best, but those are the ingredients)
Egg whites and sawdust
Timbermate
AquaCoat
Drywall compound died darker than the wood it is filling
Sorry this happens to some people. Good luck with finding a replacement that works well for you.
PostPosted: Sat Oct 09, 2021 11:02 am
Thanks everybody for the replies. Unfortunatly, I think my rash was a systemic response and not contact. I will probably have to avoid all epoxies in the future. The resin in System3 SilverTip contains bisphenol and I think this is the most common allergen.
I'll give the AquaCoat a try.
Bill
PostPosted: Mon Oct 11, 2021 11:27 am
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
Make sure to keep AquaCoat away from koa and Tassie blackwood, unless you like green instruments.
PostPosted: Mon Oct 11, 2021 12:07 pm
After trying almost everything in general (I have not tried every brand of epoxy, for example) I've pretty much settled on the traditional French polish fill of pumice and shellac, with whatever wood dust gets generated in the process. Once you get some practice it can go pretty quickly, it's very durable and reliable, and so far as I know, nobody is allergic to shellac. From what I've read and seen, epoxy allergies are not something to mess with: after you've developed it the second time can kill.
PostPosted: Mon Oct 11, 2021 3:26 pm
Interesting. I am finishing a guitar right now with koa binding, head plate, etc. No green. Of coarse I always seal with shellac first.
PostPosted: Mon Oct 11, 2021 4:21 pm
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Good point. Shellac may well be an adequate barrier against AquaCoat. I'd be inclined to give it more than a single thin wash coat. The culprit seems to be the water in the AquaCoat, as many have reported green stains when bending with water. Similarly, I've seen green turn up under water based finishes.
PostPosted: Mon Oct 11, 2021 5:48 pm
I always sand any pore filler back to wood. I think that is how aquacoat, unlike epoxy, is supposed to be used. That could have something to do with the green color too.
PostPosted: Mon Oct 11, 2021 6:35 pm
On the bare wood I use 2 coats of shellac, 2# cut, padded on. AquaCoat fill, sand it to wood, then another round of AquaCoat and sand back to wood finishing with 320. Then on to french polish.
Users browsing this forum: Freeman, JimWomack and 25 guests
