It is currently Sun Jul 27, 2025 3:30 pm
PostPosted: Tue Jan 05, 2021 9:08 pm
Perhaps this should be in the Repair discussion board: I very carelessly made a deep and long cut with a purfling cutter (so, more of a deep groove) on an Englemann spruce soundboard. Using glue and spruce wood powder I filled in the cut, which fortunately was not too deep to damage the soundboard, but it left a dark line and is very visible.
What would more experienced luthiers would have done to fix this kind of mistake? Because it runs along the contour of the guitar, I could install a much wider purfling but it is not worth it at this time. Thank you.
PostPosted: Tue Jan 05, 2021 9:27 pm
Wider purfling or retop. Or just accept the dark line.
Or, as said below, a candidate for a burst although not normally one of my choices.
PostPosted: Wed Jan 06, 2021 1:01 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
It's not that experienced builders don't make mistakes, it's that they've worked hard at hiding them. Sounds to me that wider purfling would hide the problem in sawdust and there wouldn't be any damage, it'd be removed. Easier than replacing the top. Or a sudden desire for a sunburst...
I think I spoke so obliquely as to allow for misinterpretation. My 'sawdust' comment above wasn't an invitation to try to fill the damage with sawdust, but to make sawdust with a deeper purfling cut and remove the damaged area.
Peter Havriluk
PostPosted: Wed Jan 06, 2021 2:06 am
I don't think there is a way of fully covering the mark, I have found that mixing dust with PVA glue gives you a much lighter end result, the more PVA the lighter it dries, you can practice on an off cut. It will still be visible but not a dark line, would seal with shellac before spraying over to avoid any possible reactions . Good luck
Sent from my SM-A715F using Tapatalk
PostPosted: Wed Jan 06, 2021 8:23 am
Yeah mixing glue and dust will never work. You will see that under a finish. The first thing to try is to steam it and see if the wood fibers rise up and fill it, doubtful in the case of a saw cut but worth a try. Otherwise change your binding and purfling scheme to cover it up. Or as mentioned just live with it. I still have my first guitar that I built in '92 with purfling cutter marks on it :D
PostPosted: Wed Jan 06, 2021 8:42 am
City: U.P.
Can you post a picture?
I've seen some pretty creative ways to cover mistakes, even turn them into a feature.
With a picture, someone might be able to make a suggestion.
Brian R, Wood Mechanic
N8ZED
PostPosted: Wed Jan 06, 2021 10:54 am
Thank you very much for all of your suggestions. Right now I am considering going with the "just live with it" option!
PostPosted: Wed Jan 06, 2021 11:01 am
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
Wider purfling or spray a burst on the top.
Tony Thatcher
Bozeman, Montana
PostPosted: Wed Jan 06, 2021 11:10 am
When it is all said and done, if you decide you don't like it you can do a "black face" guitar.
PostPosted: Wed Jan 06, 2021 2:21 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
This is s copy of a Martin Style 3 soprano uke I did in Osage Orange. That little dooflicky at the bottom of the soundboard is called a parand. You could cook up something similar to fit the style of the instrument
PostPosted: Wed Jan 06, 2021 9:19 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
One option is to pop the top loose in the area and shim it up, creating a bump that will allow the groove to be sanded out.
Sent from my SM-G950U1 using Tapatalk
These users thanked the author John Arnold for the post: SteveSmith (Thu Jan 07, 2021 6:51 am)
