It is currently Mon Jul 28, 2025 4:48 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Sat Aug 22, 2020 12:31 pm
" what is the shiny material in the first one?"
Probably birch or maple veneer; I used some of both. The way it's sliced produces flat cut leaves, so the edge grain is vertical, showing a lot of ray pattern. Wood is also most reflective on the quartered surface. The yellow wood, which, so far as I know, is Euonymous atropurpuria is also pretty reflective, and is well quartered. I picked that up about 40 years ago when a friend and I were salvage logging for fire wood at a construction site near Boston. It was winter, so there were no leaves to go by.
It also helps on that one that I put a couple of coats of varnish on the top. That's the lowest density piece of WRC I've seen, and also the softest. I varnished it to help harden the surface, and seal it so that I could stick on a piece of paper with spray adhesive without worrying that it would get into the top and cause problems later.
These users thanked the author Alan Carruth for the post (total 2): cablepuller1 (Sun Aug 23, 2020 2:32 am) • Pmaj7 (Sat Aug 22, 2020 9:53 pm)
PostPosted: Sat Aug 22, 2020 1:13 pm
First name: Fred
Last Name: Overend
State: Lancashire
Country: United Kingdom
There are some truly wonderful designs on this thread and some great inspiration.
The last one I did was for a friend's 50th birthday with a motorcycle theme. The rosette was inspired by the brake disc and calipers with five MOP discs to represent his 5 decades.
https://overendsite.wordpress.com/2017/ ... -complete/
These users thanked the author Fred O for the post (total 3): TimAllen (Sun Aug 30, 2020 7:10 pm) • cablepuller1 (Sun Aug 23, 2020 2:32 am) • Michaeldc (Sat Aug 22, 2020 2:07 pm)
PostPosted: Sun Aug 30, 2020 4:18 pm
Thanks for all the advice, finally ended up with this, its off cuts from the back(bog oak) and some shell, pretty pleased with it :)Image
Sent from my SM-A715F using Tapatalk
These users thanked the author cablepuller1 for the post: Michaeldc (Mon Aug 31, 2020 11:28 am)
PostPosted: Sun Aug 30, 2020 4:20 pm
Will sand the showing spruce under it at final sanding stageImage
PostPosted: Mon Aug 31, 2020 8:04 am
Very nice!
These users thanked the author Clay S. for the post: cablepuller1 (Wed Sep 02, 2020 11:43 am)
PostPosted: Mon Aug 31, 2020 11:05 am
Can you take a close up?
PostPosted: Wed Sep 02, 2020 11:52 am
Close up Image
These users thanked the author cablepuller1 for the post: Pmaj7 (Wed Sep 02, 2020 11:55 am)
PostPosted: Wed Sep 02, 2020 11:57 am
I like it! Usually I don't care for that color scheme, but being compact and close to the sound hole I think it's nice.
These users thanked the author Pmaj7 for the post: cablepuller1 (Thu Sep 03, 2020 2:30 am)
