It is currently Sat Jul 19, 2025 11:24 am
Post new topic Reply to topic  [ 143 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon Jul 27, 2020 9:26 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Well, it didn't work. Here's what happened....
I put it back up on the shelf with the other parts and will address it another time. I have a laminating form for that shape so will try to use that as a fix someday. idunno
PostPosted: Tue Jul 28, 2020 1:35 am
Dang...:(
These users thanked the author meddlingfool for the post: Bri (Tue Jul 28, 2020 2:54 am)
PostPosted: Tue Jul 28, 2020 7:04 am
Clay S. wrote:
CarlD wrote:
Well, it's my turn.....
Got to the shop this afternoon and found the side I bent yesterday wasn't bookmatched. I know you can't see both sides at the same time, but it bugged me enough that I had to try again. An hour of flattening with my wife's old iron. Back in the bender sandwich. I'll check it tomorrow. It's Chechin. I used water and windex and it bent readily.
I'd heard of this happening to others but first time for me.
You are in good company. Romanillos mentions in his book a guitar Torres built with matched sides bent "wrong".
I did that on a set of BRW sides I laminated with epoxy. With laminated sides there's no going back. They hung around the shop for a couple of years until I decided to build a guitar to try out some new ideas. I matched them up with a back that needed a little bit of wood patched in and put the thing together. It turned out to be a good sounding little guitar. Now when I pick it up I don't even think about all the little flaws.
Hi Carl,
Remember I said I didn't think about all the little flaws? You just reminded me of a couple. laughing6-hehe Another reason the sides laid around the shop were the buckle fractures that occurred during the lamination. Usually the epoxy wets out the veneer enough for it to conform to the form, but for some reason it didn't. I could have retouched those areas before finishing to make them less obvious, but I didn't.
I used CA to glue them but hide glue would have been a better choice.
PostPosted: Tue Jul 28, 2020 9:08 am
Hi Carl,
That's actually pretty impressive and I thought if anything CA glue would make it stain and show more.
I'm on my 67th guitar now and I have NEVER cracked sides before till I got hold of this really old BRW and most luthiers tell me, pffft it bends like butter! I've cracked 4 sides two of which were in a bending machine which I purchased becasue I got a sever case of the yipps and thought I could never bend sides again. It must be the the wood!
PostPosted: Wed Jul 29, 2020 6:29 am
First name: Chuck
Last Name: Skarsaune
City: Butler
Glued a bridge on last night. I had a little trouble with the last one I glued on shifting when clamped, so I checked alignment repeatedly as I got it clamped up.
Drilled the pin holes this morning and took the clamps & cauls off.
dang thing is ~5/16" off side to side, like it needs to be shifted a whole pin hole over. Got so laser focused on making sure it was right front to back that I completely spaced the side to side.
Of course I scraped the nice sunburst amber lacquer off for a good glue surface below the bridge, so I'll have to fix that too.
Ugh.
PostPosted: Wed Jul 29, 2020 12:32 pm
That sucks.
I double stick tape the bridge where it’s going to go. Then check positioning very carefully. Then I drill the two e string holes and use the bits to hold the bridge while gluing so it can’t slide around...
PostPosted: Wed Jul 29, 2020 1:15 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That's pretty much what I do too.
I tape off the bridge area before finishing so I put down tape over where the bridge will land and carefully mark a center-line on the tape. I use my home made version of the saddlematic to locate the bridge distance according to the saddle slot and make sure the center-line on the tape matches the center marking on the bridge. Then I clamp it all down as if I were gluing it in place. I double check everything and then drill through the two E holes into the top and through the bridge caul. I use drill bits in these holes to ensure it doesn't move while I cut the tape around the bridge. The saddlematic gives me the North/South location and the center-line takes care of the East/West.
Bryan Bear PMoMC
PostPosted: Wed Jul 29, 2020 2:36 pm
Yeah that does suck but you can recover. I use 3/16in bolts to align in the outer Ee pin holes.
PostPosted: Wed Jul 29, 2020 2:50 pm
I think it's a consensus, we all use bolts or pins to keep the bridge aligned while it's being glued.
PostPosted: Wed Jul 29, 2020 3:32 pm
First name: Chuck
City: Butler
Yep, I can recover.
I’ve done screws thru the pin holes for bridge reglues - going to adopt that on new installs to prevent shifting.
And make myself a saddlematic type jig.
And pay more attention, lol. Measure many times, cut once.
It’s funny (not really) but I’ve been studying mindfulness. Obviously I’m not practicing it very well.
PostPosted: Wed Jul 29, 2020 3:33 pm
Happens to us all
PostPosted: Thu Jul 30, 2020 3:14 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Speaking of bridges - very timely. I build about one a year, so never get really comfortable with some procedures. Locating a bridge today with my home made saddle-matic. Nothing Matic about it apparently. Put the wrong side of the saddle against the jig
PostPosted: Thu Jul 30, 2020 4:02 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Oh man, that hurts! That is the trouble with non-belly bridges. I have caught myself almost doing that before. In fact, you post just made me get up and double check the two guitars I'm working on right now.
Bryan Bear PMoMC
PostPosted: Thu Jul 30, 2020 7:18 pm
Last Name: Ionta
City: Hopkinton
State: Massachusetts
Zip/Postal Code: 01748
Oh ouch. What would you think of a Gib-ish reverse belly bridge?
PostPosted: Thu Jul 30, 2020 7:37 pm
Oh dang..::(
PostPosted: Thu Jul 30, 2020 9:17 pm
Hahahha I wonder if that's what started that God awful design in the first place :D
Hey! At least there is precedence. It's a great idea actually.
PostPosted: Thu Jul 30, 2020 11:17 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
If you look carefully (not), you notice a separated seam in the area and pitch pockets everywhere.
What happened is I glued the top to the side in sessions, one area at a time, and I misjudged where the center seam is (the glue line is VERY hard to see) and so I had glued the neck portion off by about 4mm. So I had to heat and unglue that section and reposition it. Unfortunately it raised some sap and separated the center seam in the heel area. Fortunately they sand out, and the underside has been reinforced very well, and a fingerboard will go over that. I will also route a pocket where the separation is to accommodate the truss rod, so all is good. One bonus is that portion is likely torrified so will result in better tone.
Typhoon Guitars
PostPosted: Fri Jul 31, 2020 2:03 am
That particular section is where most of the tone is so you got lucky...
These users thanked the author meddlingfool for the post: Colin North (Fri Jul 31, 2020 2:14 am)
PostPosted: Fri Jul 31, 2020 7:22 am
Last Name: Minch
City: Chestertown
I think I can hide the two holes next to the bridge adequately. The guitar needs the pyramid bridge because it has a Stauffer neck
PostPosted: Fri Jul 31, 2020 7:37 am
Ed Minch that looks fantastic!
PostPosted: Fri Jul 31, 2020 8:59 am
From vintage Martin.com:
http://vintagemartin.com/Martin1837HudsonSt_B033r.jpg
Hi Ed,
I think you pointed out to me the decorative inlays some of the old guitars incorporated around their bridges. If the bridge footprint doesn't cover the holes this might be a way to bury them and add a little more embellishment to the guitar.
PostPosted: Fri Jul 31, 2020 9:15 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Um... I don't see any holes.
Hutch
PostPosted: Fri Jul 31, 2020 12:18 pm
Last Name: Minch
City: Chestertown
Thanks J
That interesting decoration on the head is adapted from one that JG Stauffer did in the very early 19th c, but his metal plate was on the back. My ivoroid plate is on the front
Clay - great idea. I have the holes patched and if they show poorly under that Endurovar you sent, then there is an option/
BP - I like your attitude
Ed
PostPosted: Tue Aug 04, 2020 10:20 am
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
My last build: I mistakenly routed the back instead of the front. ..... now everybody knows the back purfling is a dum-dum feature.
Measure Twice,
Karl Borum
PostPosted: Tue Aug 04, 2020 10:26 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I did that with rosettes when for some reason the channel is too loose.
Typhoon Guitars
