It is currently Fri Nov 29, 2024 1:51 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2  Next
 Post subject: Amazingly sharp
PostPosted: Tue Feb 25, 2020 8:28 pm
I just used the 3M lapping films on float glass and holy )&@:t I’ve never touched a chisel so sharp. It’s like a light saber!
I should have tried this a long time ago
 Post subject: Re: Amazingly sharp
PostPosted: Tue Feb 25, 2020 9:22 pm
First name: Brad
Last Name: Combs
Scary sharp is just that! If you didn’t already find them, taytools is a seller on Amazon and usually has nice prices on the films and Amazon’s prime shipping.
These users thanked the author bcombs510 for the post: SnowManSnow (Tue Feb 25, 2020 10:31 pm)
PostPosted: Tue Feb 25, 2020 11:09 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Specifically what did you use - 3M makes so many different ones.
I'm not a luthier.
PostPosted: Tue Feb 25, 2020 11:12 pm
Last Name: Kincheloe
Welcome to the club of sharpening snobs :mrgreen:
Your life will be much easier from now on.
PostPosted: Wed Feb 26, 2020 6:22 am
First name: Brad
Last Name: Combs
Kevin, the one I use is from Taytools on Amazon. They put together a kit of 1/3 sheets that fit the float glass they sell - https://www.amazon.com/3M-TM-Microfinis ... ls+&sr=8-7
Here is the kit that I bought, it has 3 pieces of glass and comes with 7 grits. What I did was put one sheet on each side of the glass skipping the finest grit. Works good for me.
https://www.amazon.com/Taytools-279205- ... ls+&sr=8-8
Hope that helps.
Brad
These users thanked the author bcombs510 for the post: klooker (Wed Feb 26, 2020 6:33 pm)
PostPosted: Wed Feb 26, 2020 6:49 am
I love water stones and tormet but yes scary sharp works. Todd stock has a video out there on the subject
PostPosted: Wed Feb 26, 2020 8:43 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
FWIW taytools on amazon above sells the narex cryogenic chisels exc . for luthiery
PostPosted: Wed Feb 26, 2020 8:55 am
Yes I used the ray tools set of lapping sheets stuck to a float glass. I had a piece large enough to get all 7 on it (back and front). I used water as lubricant.
The chisel that was sharpened is a BlueSpruce 3/4 “ bench.
It will be interesting to see how long the films last
PostPosted: Wed Feb 26, 2020 9:57 am
Can you expand on that a bit, perhaps with pics? What is float glass and holy?
PostPosted: Wed Feb 26, 2020 11:06 am
Float glass from the production method. The melted glass is floated on molten metal, this produces the flattest form of glass plate.
I think holy )&@:t just may be an expletive...... :o
PostPosted: Wed Feb 26, 2020 1:06 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Anybody interested in a fun and funny read, here is Steve Lamantia, the guy who fully developed and named the scary sharp (tm) method about 1995- always use the (tm)
https://swingleydev.com/ot/get/261749/single/
I have used it since I joined that list in 1997. I use wet/dry emory paper because it is readily available, on 2 discarded glass cabinet shelves. I always sharpen to 600, and then depending on the task I might go to 2000, then the green compound in a piece of pine. Luthiery gets the full treatment. And always with vintage tools - we have to recycle, right?
Ed
PostPosted: Wed Feb 26, 2020 2:35 pm
Ah ok I see. So regular thick glass is not good enough?
PostPosted: Wed Feb 26, 2020 7:29 pm
Most modern window glass is float glass, and you can back it up with a piece of melamine or other reasonably flat substrate. You could probably get away with just using the melamine in a pinch. Most sharpening systems rely on holding the angle more than absolute flatness.
PostPosted: Wed Feb 26, 2020 9:09 pm
Last Name: Minch
City: Chestertown
I think the glass came in because you can use water to stick sheets of paper to it, use the sheet, lift it off, then stick on the next progressive grit. A piece of MDF would be flat enough for the widths that we use.
Ed
PostPosted: Wed Feb 26, 2020 9:29 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I used to use glass for my sharpening until I looked at the broken edges on the piece I use in the shop (I keep it leaning against the wall and put it on the bench only when I sharpen). I hardly ever wear shoes. I realized that someday the odds would catch me. I bought one of those flat granite blocks from Woodcraft and keep it on the end of my bench. The glass is retired.
PostPosted: Wed Feb 26, 2020 11:13 pm
A regular piece of double strength window glass contact cemented to a slightly larger piece of MDF should work fine and not be too much of a hazard.
PostPosted: Thu Feb 27, 2020 7:29 am
I’m sure you could just stick it to a granite slab too.
PostPosted: Thu Feb 27, 2020 9:27 am
MDF and water don't go together very well though. Does anyone know how to cut thick glass? A while back I found a 1/2in glass table top in a barn in my backyard. I'm thinking a regular old glass cutter aint gonna work on that and I won't touch it with my band saw :D
PostPosted: Thu Feb 27, 2020 11:01 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Be careful admitting things like that, Bob. People will either give you grief for the inherently unsafe nature of being barefoot in a woodshop or mistake you for being from West Virginia. :lol:
I've lived here for over 20 years, so I'm allowed to make those jokes.
PostPosted: Thu Feb 27, 2020 11:50 am
First name: Brad
Last Name: Combs
When I lived in northern KY and worked in Ohio my co-workers asked the same thing every day.... "Any issues putting your shoes on while driving across the bridge in Cincinnati"? Now I live in Cincinnati and my co-workers (company is based in Seattle) ask what it's like to live in "the south". :D Can't win.
PostPosted: Thu Feb 27, 2020 12:45 pm
Last Name: Parker
City: Charleston
Brad--
Yeah, I grew up in Western Kentucky and went to college in Central Kentucky. I heard more than one joke about the need to check out some shoes from the shoe library.
On topic (sorry for the tangent)--I like my Worksharp. It works on the same Scary Sharp principle of progressively finer grits of sandpaper attached to glass. I'm impatient, so having a powered sharpener is good for me.
These users thanked the author doncaparker for the post: bcombs510 (Fri Feb 28, 2020 10:39 pm)
PostPosted: Thu Feb 27, 2020 12:50 pm
If it is tempered glass it may be very difficult to cut (tempered glass has smooth edges).
PostPosted: Thu Feb 27, 2020 1:42 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I am always barefoot in the shop, but I am a Hoosier.
I have found a bunch of ways to get chisels and plane blades really sharp, including lapping paper on a granite slab. The main thing I learned about having sharp tools is to have a setup always available to at least touch up the edges of the tools while working with them. A leather strop and polishing compound is one way. This may be just me; while I will mostly start with a sharp tool I am very reluctant to stop and sharpen a tool while working with it if it is a hassle. I will work with relatively dull tools. Now, I have a Work Sharp 3000 (sandpaper or lapping film on tempered glass) always setup with 6000 micro-mesh on both sides of a glass disk. I will stop and touch up an edge of a tool even in the middle of working with it. Once I stop if the edge needs more than a touch up. I may re-sharpen starting at 400P or 1000P. I used the tool for a few years now and it not only sharpens well it also broke me of my habit of working with dull tools.
These users thanked the author johnparchem for the post: Pmaj7 (Thu Feb 27, 2020 2:24 pm)
PostPosted: Thu Feb 27, 2020 4:27 pm
"I hardly ever wear shoes. I realized that someday the odds would catch me."
I would worry less about stepping on a piece of glass and more about knocking a scary sharp chisel off the bench and trimming your toenails!
PostPosted: Thu Feb 27, 2020 5:32 pm
First name: John "jd"
City: Santa Barbara
Was sanding in sandals and felt a sharp pain. Looked down to find my small kiridashi stuck in the top of my foot after vibrating off the bench.
Scary sharp is a gateway drug, just wait until you discover ceramic waterstones.
Users browsing this forum: Michaeldc and 68 guests
