It is currently Sun Jul 20, 2025 6:34 am
PostPosted: Mon Sep 02, 2019 10:01 pm
Last Name: Mansfield
City: El Dorado Hills
Hey folks,
What would you consider the minimum distance between the back of the saddle and the bridge pin holes?
I've made a bridge out of piece of ebony; the saddle slotting went awry, so instead of scrapping it, I turned it upside down and started over, removing the spoiled area, just to see what it would lead to. In some areas it's a little short, and I ended up with the center of the pin holes ~8mm below the bottom of the saddle (the edge of the drill holes are a little over 6mm from the saddle, prior to reaming it out). Now I'm wondering if that's too little of a distance. Would appreciate inputs.
Thanks! - Bill
PostPosted: Mon Sep 02, 2019 10:12 pm
Posting a picture..
PostPosted: Mon Sep 02, 2019 10:32 pm
Looks good to me.
These users thanked the author bftobin for the post: billm (Fri Sep 06, 2019 6:57 pm)
PostPosted: Tue Sep 03, 2019 4:33 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
That is no tighter than many that I have seen - especially if it is a smaller bodied guitar (but even if it isn’t it should be fine). A smaller and lighter bridge is a good thing in many ways, as long as it is long enough to overlap the arms of the X-braces, or whatever you have underneath there.
These users thanked the author Mark Mc for the post: billm (Fri Sep 06, 2019 6:57 pm)
PostPosted: Tue Sep 03, 2019 6:38 am
Try to keep the reamer angled back to retain the maximum distance from the saddle, and don't ramp the string holes very much at all, just a small radius at the top to ease the bend in the strings.
A higher break angle can put extra strain on the wood in front of the saddle.
These users thanked the author Colin North for the post: billm (Fri Sep 06, 2019 6:56 pm)
PostPosted: Tue Sep 03, 2019 12:41 pm
Thanks guys! I appreciate it. - Bill
PostPosted: Tue Sep 03, 2019 12:43 pm
I think it's fine...
These users thanked the author meddlingfool for the post: billm (Fri Sep 06, 2019 6:56 pm)
PostPosted: Thu Sep 05, 2019 10:54 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Looks really nice. I'd be happy to have it.
Peter Havriluk
These users thanked the author phavriluk for the post: billm (Fri Sep 06, 2019 6:56 pm)
PostPosted: Fri Sep 06, 2019 11:47 am
Thanks guys!
After some consideration (and finding I routed the saddle slot deeper than I intended - I think it was something like 2.4 mm left from bottom of slot to bottom of bridge) - I'm just going to start over. Which is fine. That said - the look of this bridge has started to appeal to me, it's going to inform what I do now. It was fun to experiment.
Bought a DeWalt 611 with a plunge base that I hope will help address some of the ridiculous issues I've allowed to occur.
PostPosted: Fri Sep 06, 2019 4:14 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
I don't understand how the saddle slot being deeper is cause to make a new bridge. I thought that a deep saddle slot just means less material is taken off the bottom of the saddle when it's mated to the guitar, part of the adjustment everybody makes.
Peter Havriluk
PostPosted: Fri Sep 06, 2019 6:50 pm
The references I have indicate you want 3mm / 1/8" of bridge material between the saddle and the top.
My read of this is that less would perhaps be unsound. Though I haven't seen that stated explicitly.
Is that a wrong takeaway?
Perhaps a better answer would be, I was targeting 3 mm and would like to refine my process to be precise and predictable, so I'll do it again.
PostPosted: Sat Sep 07, 2019 6:54 pm
I've got an early '70's Guild D-55 that I bought new and the saddle goes right through to the top. There have been a number of guitars built that way.
These users thanked the author bftobin for the post: billm (Sun Sep 08, 2019 7:26 pm)
PostPosted: Sun Sep 08, 2019 2:15 am
First name: Mark
Last Name: McLean
City: Sydney
Having a deep saddle slot is really not a problem, and certainly not a reason to discard an otherwise good bridge. You can even shim the bottom of the saddle (ebony is good) if you need it to sit higher.
These users thanked the author Mark Mc for the post: billm (Sun Sep 08, 2019 7:26 pm)
PostPosted: Sun Sep 08, 2019 11:37 am
Thanks guys, that is helpful.
PostPosted: Sun Sep 08, 2019 12:19 pm
I think it's good to have some wood below the saddle, but I think you're O.K. with 1/10th of an inch. Although some guitars may have the slot cut through to the soundboard I think that is a bad idea. The spruce top is much softer than the ebony or rosewood of the bridge and I think more likely to be compressed by the pressure of the strings (but I could be wrong).
These users thanked the author Clay S. for the post: billm (Sun Sep 08, 2019 7:25 pm)
Users browsing this forum: Gary Davis, joe white and 20 guests
