It is currently Sat Jul 19, 2025 6:15 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Edge sander woes...
PostPosted: Mon Aug 12, 2019 8:24 pm
Can't hurt and you'll answer the question for sure.
PostPosted: Mon Aug 12, 2019 8:26 pm
Exactly!
PostPosted: Mon Aug 12, 2019 8:37 pm
Bri,
Are you referring to an on/off switch, or the internal centrifugal switch?
PostPosted: Mon Aug 12, 2019 10:29 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Mine was an on/off switch, though I would guess that the centrifugal switch could fill with dust.
Especially on a sander.
B
PostPosted: Mon Aug 12, 2019 11:31 pm
I'll try the capacitor first...
 Post subject: Edge sander woes...
PostPosted: Tue Aug 13, 2019 7:26 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Ed: I understand the desire to DIY — I do most of my own shop electrical work. But not motors. Electrical component failures are often due to overheating, caused by overloading, caused by a tight bearing. No sense in replacing a component, only to have it blow again. It’s a specialised area, and I have access to a rather good motor repair place that is very fair. Just my two cents
PostPosted: Tue Aug 13, 2019 11:18 am
It's not so much that I desire to DYI, I don't, but changing a capacitor seemed approachable. Anything beyond and the experts get called in.
Much to my delight, it was indeed the start capacitor malfunctioning, a quick sub out and I'm back in biz...
Thanks for the help everyone:)
PostPosted: Tue Aug 13, 2019 7:29 pm
Glad you got it fixed!
PostPosted: Tue Aug 13, 2019 7:45 pm
Yeah me too! I use that machine a lot a lot a lot...
PostPosted: Wed Aug 14, 2019 7:35 am
First name: Gregor
Last Name: Crothers
Good to hear Ed, glad she is running again.
Wake up and smell the rosewood!
PostPosted: Wed Aug 14, 2019 8:09 am
Hi Ed,
Good to hear you got the motor sorted. It's always nice when it's an easy fix.
The motor on my compressor "went up". I think it's a bearing, but I haven't torn it apart yet. I found another motor in my "spares" collection but the rotation is wrong. So I need to either fix the old motor or change the rotation (if possible) on the replacement. Another possibility is to orient the replacement backwards so it dangles off the edge of the mounting plate. The last possibility is, God forbid, buy another motor!
I still have a small pancake compressor to get me by, for the small amount I need one.
PostPosted: Thu Aug 15, 2019 7:11 am
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
Clay S. wrote:
Hi Ed,
Assuming for the moment the motor in question is a single-phase motor, open the connection box and look for leads 5 and 8. Reverse those, and your motor will spin the other way. If you don't have access to those two leads, you will need to find other options.
These users thanked the author Lincoln Goertzen for the post: Clay S. (Thu Aug 15, 2019 7:29 am)
PostPosted: Thu Aug 15, 2019 7:17 pm
That’s awesome. I didn’t realize it was getting up to speed if you turned it by hand. That’s almost always an indication of a capacitor issue. At least in my experience.
I’m probably butchering it, but some of these tools take more current at startup to get those initial turns than we’re able to supply; the cap acts as a buffer supplying the extra kick. My first drill press came with a bad cap. It would run, but only if I spun the chuck with my hand to help it get moving.
PostPosted: Thu Aug 15, 2019 7:42 pm
I’m very happy about it. Now I have tackle the stove, lol!
Users browsing this forum: joe white and 29 guests
