It is currently Mon Dec 02, 2024 1:54 pm
PostPosted: Wed Sep 19, 2018 9:51 am
Good morning,
Has anyone on the forum fully completed an acoustic guitar finish using HP Topcoat? (Not EnduroVar)
I am halfway through applying it on an OM-35 style build and was looking for any feedback others may have in regards to their process.
Currently, I am applying 3 coats a day 2-3 hours apart and sanding with a fine 320 sanding sponge between coats. The goal is 12 coats let sit for 21 days then start finish sanding and buffing.
Thank You,
Ray
Guitar Building = Continuous Improvement Process
PostPosted: Wed Sep 19, 2018 10:54 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I have used it on furniture - 3 coats, level sand, 2 coats, 600 grit, polish up through the grits. I have never made it mirror like, but see that it can be done. Easy on a flat surface. I am right now using Min-Wax Wipe On Poly on a guitar (with a similar schedule) for the first time and it is going well.
Ed
These users thanked the author Ruby50 for the post: Gasawdust (Fri Oct 12, 2018 7:37 am)
PostPosted: Thu Oct 11, 2018 9:17 am
Follow up on General Finishes HP Top Coat:
Very happy with the results after final buffing of this product! Easy to apply and easy to finish to a nice glossy shine.
PostPosted: Thu Oct 11, 2018 9:42 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
I don't believe you. Where's the pics :evil:
Hutch
PostPosted: Thu Oct 11, 2018 10:11 am
Absolutely!
PostPosted: Thu Oct 11, 2018 12:06 pm
Alrighty, is there a simple way to transfer photos from a Samsung phone to this thread?
I sent a pic to Jeff Jewitt last night to ask him some advice and he responded right away! Really cool.
PostPosted: Thu Oct 11, 2018 12:11 pm
Disregard
PostPosted: Sat Oct 13, 2018 5:43 pm
Raymund,
PM'd you but you haven't picked it up yet.
PostPosted: Mon Oct 15, 2018 3:50 am
RaymundH had problems with his phone and asked me to post some images for him.
PostPosted: Mon Oct 15, 2018 3:53 am
Nice one Raymund!
PostPosted: Mon Oct 15, 2018 6:02 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Looks great!
You sprayed?
I'm not a luthier.
PostPosted: Mon Oct 15, 2018 8:06 am
Big thanks to Colin for the help on the pics!
This is the process I used:
Day 01
Foam brush two coats of General Finishes Sanding Sealer two hours apart. (scuff sanding with 320 sponge pad between coats)
Day 02
Brush 4 coats of HP Top Coat two hours apart scuff sanding with 320 sponge pad between coats
Day 03
Brush 3 coats of HP Top Coat two hours apart scuff sanding with 320 sponge pad between coats
Day 04
Day 05
Brush 2-3 coats of HP Top Coat two hours apart scuff sanding with 320 sponge pad between coats
I let this cure for 21 days while I worked on the neck
DRY sand with P400,P600,P800,P1000,P1200,P1500,P2000. I did this by hand over about a two hour time period and a couple beverages.
Used a random orbital sander with 3 Surfbuf pads to polish:
Started with Menzerna 2L Paste followed by 16 Paste and finishes with Liquid Polish. http://www.woodessence.com/Menzerna-Pol ... 91C15.aspx
Instead of applying the Menzerna polish directly to the pads, I applied a small amount of product to the body and buffed in small sections. Found applying to the pad directly very messy as product flew all over the room! Also, I used a dedicated pad for each level of paste.
Keep in mind that although this a durable finish, you can still burn through it if you use a heavy hand on the sander!
These users thanked the author RaymundH for the post: klooker (Mon Oct 15, 2018 1:13 pm)
PostPosted: Mon Oct 15, 2018 8:21 am
First name: Richard
City: Warwick
State: RI
I was looking online today for an alternative to the compressor and I found an airless gun for $59 that got rave reviews. I'm going to try it, just not sure what water borne paint I'm going to use yet. That's still a long ways off for me. Why brush if you can spray for this cheap? Less time, less sanding and spraying is just fun for me.
Hutch
PostPosted: Mon Oct 15, 2018 8:41 am
Frankly, it only takes about 5 min to brush a body with thin coats. As a hobby builder, I can apply in the house shop anytime with no need for a booth or good weather if you spray outside. $8 dollars for a bag of 3" foam brushes and no clean up. As for the sanding, you will have to scuff sand between coats no matter how you apply to get a mechanical bond. (as per manufactures directions)
Now, if you are fully geared up for spraying, then I think that would be the way to go for you. Although, I believe you would have breakdown and clean your gun between coats for water borne finishes??
This is the 5th different finish I have experimented with and find it the best....So far. ;o)
PostPosted: Mon Oct 15, 2018 9:13 am
First name: Richard
City: Warwick
State: RI
WB finishes can be safely sprayed in the house where it's always warm and comfy. No need for a booth either. I would do it right on my bench in the basement with a dust mask on.
I have used the GFHP with a foam brush on a counter top edge and it worked very well. I still prefer to spray and if I had the sprayer at the time, I would have used it for that.
Hutch
PostPosted: Mon Oct 15, 2018 9:58 am
First name: George
City: Seattle
RaymundH,
That finish looks very nice. Thanks for sharing the pics and your process. Did you use the finish straight from the can?
George :-)
PostPosted: Mon Oct 15, 2018 10:11 am
George - Yes, straight out of the can. Try not to back brush to much as you can fix any little runs or ridges with the light scuff sand between coats.
These users thanked the author RaymundH for the post: George L (Mon Oct 15, 2018 5:54 pm)
PostPosted: Mon Oct 15, 2018 11:02 am
First name: Kent
Last Name: Fishburn
City: Woodstock
State: Illinois
Looks great. Did you fill the grain before? If so, what did you use?
Kent
PostPosted: Mon Oct 15, 2018 1:52 pm
Pore Fill:
Day 01
Full coat of Z-poxy applied with a Bondo scraper.
Day 02
Light sanding with maroon synthetic steel wool. Used this instead of 0000 steel wool to negate any potential for steel filings embedding in fill.
Day 03
Light sanding with maroon synthetic steel wool until fill is nice and level
50/50 mix of Z-poxy and methyl hydrate as washcoat
Day 04
Sand level and smooth with maroon synthetic steel wool.
Start Finish.
PostPosted: Mon Oct 15, 2018 2:24 pm
You know, that looks pretty dang good for any finishing method, far less a low tech approach.
PostPosted: Mon Oct 15, 2018 4:00 pm
First name: Richard
City: Warwick
State: RI
+1
Hutch
PostPosted: Mon Oct 15, 2018 5:10 pm
Last Name: Colbert
City: Anacortes
That worked!
Good job!
PostPosted: Mon Oct 15, 2018 9:29 pm
Thanks guys. It was a pretty easy process to follow and I’m definitely going to use it on the next one.
The fun part about this build is that this is only half the experiment on the project. The other part is on the inside!!! ????
PostPosted: Mon Oct 15, 2018 11:12 pm
If you're talking about hearing how the sound turned out, that's my favorite part!
New username, same ole Pat Macaluso!
PostPosted: Tue Oct 16, 2018 4:09 pm
Not yet.
Although, I am extremely curious to see how this bracing system sounds in hand made guitar.
V....
