It is currently Sun Jul 20, 2025 5:26 am
 Post subject: a slight problem...
PostPosted: Thu Sep 27, 2018 3:05 pm
Last Name: Sollod
I've got a slight problem. I made my headstock about 7/16" thick. A little thin perhaps... But, I did not expect that the Gotoh 510 tuners wouldn't go down that far. It looks like I'm about 1/32" too thin. So, they don't tighten down to 7/16". I'm thinking maybe one thing I could do is grind the threaded insert down slightly on my grinder. As long as I don't foul the threads I think that could work. I suppose another remedy would be to use some different tuners, but I sure like the Gotoh 510s and this build is calling out for them. Any thoughts or suggestions?
www.swiftcreekguitars.com
 Post subject: Re: a slight problem...
PostPosted: Thu Sep 27, 2018 3:13 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
I can't tell much about the veneer, but possibly scrap the old one and put on a thicker one.
These users thanked the author surveyor for the post: olmorton71 (Thu Sep 27, 2018 7:14 pm)
PostPosted: Thu Sep 27, 2018 3:15 pm
Short term fix - washers.
PostPosted: Thu Sep 27, 2018 3:21 pm
Last Name: Sollod
I just completed the finishing on this one, probably the best finish I've done. I'm sure not going to remove and replace the headplate at this point... and adding a washer wouldn't be very professional....
So... how about grinding down the threaded insert. Am I likely to booger it up? Does anyone know of other tuning machines that will tighten down to 7/16"?
PostPosted: Thu Sep 27, 2018 3:24 pm
Look for some different tuners?
PostPosted: Thu Sep 27, 2018 4:16 pm
Well, try it. If you crap out a bushing they're easy to come by. But I'd think that would probably work...
PostPosted: Thu Sep 27, 2018 4:51 pm
Last Name: Sollod
Okay - For anyone that is interested... or has this problem in the future. I went ahead and ground down the threaded inserts for these tuners to fit my "thinnish" headstock and they fit perfectly. Sometimes you have to not be afraid to try something...
These users thanked the author sdsollod for the post (total 4): Robbie_McD (Thu Sep 27, 2018 8:33 pm) • J De Rocher (Thu Sep 27, 2018 6:25 pm) • bcombs510 (Thu Sep 27, 2018 5:46 pm) • Pmaj7 (Thu Sep 27, 2018 5:31 pm)
PostPosted: Thu Sep 27, 2018 4:58 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
You might want to measure the length of the screws and make sure they won’t poke through the front.
PostPosted: Thu Sep 27, 2018 5:05 pm
Last Name: Sollod
Nope. Plenty of room. Its not that thin...
PostPosted: Thu Sep 27, 2018 5:46 pm
First name: Brad
Last Name: Combs
Nice workaround.
PostPosted: Thu Sep 27, 2018 7:52 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
What about adding another layer to the back strap?
Ed
PostPosted: Thu Sep 27, 2018 9:27 pm
Last Name: Sollod
The guitar is finished. After the endless finishing process I have no interest in going back to add 1/16”. Besides, it looks fine, good in fact and the problem is solved...
