It is currently Sat Jul 19, 2025 6:16 am
Post new topic Reply to topic  [ 54 posts ]  Go to page 1, 2, 3  Next
 Post subject: Brace radius sanding jig
PostPosted: Sat Sep 22, 2018 5:05 pm
First name: Brad
Last Name: Combs
Hello,
Currently I use a jig to put the radius on braces. I basically use the jig described in the Gore book for 15’ and 30’ radius. I use a pattern bit in the router. I also have been hitting the radiused side with 180 on a wood block to clean up the bit of wave from the router bit.
I started thinking that maybe I should move the whole operation to a sander instead so there is just one step.
I have a 12” Delta disc sander I use for putting the radius on neck and tail blocks, but the grit is too rough (I hit the blocks with 180 as well after putting the radius on). I also have a Rikon 6x48 combo and one of the Rigid oscillating belt / spindle sanders.
For the Rigid sander I have 180 and 220 belts so I’m thinking that might be a good choice.
Anyone using a sander based jig for putting the radius on braces? Care to share any pics?
Or does everyone just rub the braces in a dish? :)
Thanks!
Brad
PostPosted: Sat Sep 22, 2018 7:13 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Mark, cut on a band saw, sand on a sanding batten. Less than 2 minutes each?
Ed
These users thanked the author Ruby50 for the post: bcombs510 (Sat Sep 22, 2018 9:38 pm)
PostPosted: Sat Sep 22, 2018 7:36 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Ed
Same here except I sand them on a radius dish. Pretty fast.
These users thanked the author J De Rocher for the post: bcombs510 (Sat Sep 22, 2018 9:38 pm)
PostPosted: Sat Sep 22, 2018 8:14 pm
First name: Brad
Last Name: Combs
My dish has 60 grit. Do you go straight from 60 grit to glueup?
I’ll take a few pics of what I’m doing now with the router to help with where I’m coming from. I’ve been working for months on a build system using jigs and locating pins. This is one piece of the puzzle. :)
PostPosted: Sat Sep 22, 2018 9:03 pm
This is the concept Charles Fox taught in his course. He used it on a horizontal edge sander but it should work on the Rigid.
Make an auxiliary table that has a piece of thin aluminum attached as a buttress your radius template pushes against. Attach the part to be sanded to the template on a sliding cradle so it can be moved into the belt at the proper thickness.
The picture is this concept being used for radiusing end blocks.
I still use a router table and template bit using climb cuts. Comes out pretty smooth. When I tried to sand in the dish I inevitably rocked it a little or used uneven pressure or a varying angle resulting in a less than perfect mating surface.
These users thanked the author Terence Kennedy for the post (total 2): Bri (Sun Sep 23, 2018 1:31 pm) • bcombs510 (Sat Sep 22, 2018 9:34 pm)
PostPosted: Sat Sep 22, 2018 9:38 pm
First name: Brad
Last Name: Combs
Awesome. Thanks, Terence.
Out of curiosity - do you use any special bits? I’m using a two flute pattern bit, maybe I need to do three flute or take the passes differently? What I found is just a bit of wave in the cut and was trying to clean it up with 180 paper. It’s possible I’ve talked myself into the routed surface not being “good enough”. Wouldn’t be the first time I guess. ;)
PostPosted: Sun Sep 23, 2018 1:26 am
First name: Jay
City: Bothell
State: Washington
My dishes have 60 or 80 grit, I don't remember which. After the initial sanding to the radius, I place a long strip of adhesive-backed 220 grit across the diameter of the dish and sand the braces to remove the 60/80 grit scratches. That step is fast. Right before gluing the braces, I scrape the brace bottoms with a fresh razor blade. Also, I sand the inside surface of the top and back to 220.
These users thanked the author J De Rocher for the post: bcombs510 (Sun Sep 23, 2018 1:29 am)
PostPosted: Sun Sep 23, 2018 6:47 am
State: Tennessee
Sanding? Dishes? :mrgreen:
I swiped this idea and pics from Bruce Sexauer, infinitely adjustable, and your gluing surface is just off a sharp (hopefully) plane
I use my Veritas Shoot Board plane it works pretty good
PostPosted: Sun Sep 23, 2018 6:56 am
Clinchriver just beat me to it, why not just use a plane?
These users thanked the author Colin North for the post: Clinchriver (Sun Sep 23, 2018 7:01 am)
PostPosted: Sun Sep 23, 2018 7:24 am
Just to be clear. I personally use a different system, similar to yours Brad.
I have 60 grit in 12' and 28' radius dishes, and I shape my braces with a router trim cutter and radius template.
I also made 2 each radius blocks, 12' and 28' radius, about 2" square x 2', double sided, with 100/150/180/240 grit abrasives.
These radius blocks are used both to sand the rims (after initially shaping and "driving the bus") and to sand the braces to the higher grits.
240 grit is saved for final touch up just before gluing.
These users thanked the author Colin North for the post: bcombs510 (Sun Sep 23, 2018 10:34 am)
PostPosted: Sun Sep 23, 2018 9:04 am
I just mark it and use a block plane. Too many jigs clutters up my small workshop. This guy uses a jig and can probably do it in about a minute. Takes me a bit longer but saving a minute or so is hardly a big deal for me.
https://www.youtube.com/watch?v=qrO6ZEECmFY
PostPosted: Sun Sep 23, 2018 9:55 am
First name: Oris
Last Name: Morton
City: Franklinton
Drive the bus. [MAN]????‍[AIRPLANE]️
PostPosted: Sun Sep 23, 2018 10:21 am
I have been just using a two flute template bit doing climb cuts and finishing with a regular cut. I do go over it with a hard sanding block just prior to gluing to freshen things.
As usual many paths to a good outcome. I think a sanding jig on the Rigid with around 120G would work great.
These users thanked the author Terence Kennedy for the post: bcombs510 (Sun Sep 23, 2018 10:34 am)
PostPosted: Sun Sep 23, 2018 10:39 am
First name: Brad
Last Name: Combs
Thanks, Terence. I think I will use your idea to make a plate for the jig I already have and use the rigid. The nice thing about the Rigid is I can go down to really close with 120 or so and then hit it once last hit with 180 and the belt swap out is really easy.
Thanks everyone else for the ideas. Of course there are lots of ways to do this, but I’m specifically looking for a jig approach that uses a sander and can keep things square for me. Even hand sanding off the router with a hard block I tend to nip the edges sometimes which ruins the fit. The jig will help with this. I’ll post some pics of what I come up with.
PostPosted: Sun Sep 23, 2018 10:54 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
With the plate in the radius dish, scribe the brace to the plate.
Block plane to the scribe line, test fit, maybe touch up once more.
B
These users thanked the author Bri for the post: Ken McKay (Sun Sep 23, 2018 1:34 pm)
PostPosted: Sun Sep 23, 2018 11:32 am
Rotate the assembled rims and end blocks (clamped in the mould) on radius dishes with PSA abrasive to achieve desired spherical rim shape.
These users thanked the author Colin North for the post: olmorton71 (Thu Jun 06, 2019 8:13 pm)
PostPosted: Sun Sep 23, 2018 11:35 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
For odd radii, bench hook and block plane. For 15', 28' and 60', we use the Luthier (Oops...Suppliers!!!) tablesaw brace radiusing jig finished with a jack plane while the brace is still presenting a flat surface to the tool. We are typically doing 3-4 brace kits at one time, so jigs do save a significant amount of time.
- Beth Brower
PostPosted: Sun Sep 23, 2018 11:49 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Scribe to your radius on the bottom of your brace. Use a 12 in disc sander on a combo sander, finish sand to 180 , or a suitable radius dish . Have the LMI radius jig costs $$ but one can easily make a copy of them for your final sanding
PostPosted: Sun Sep 23, 2018 12:12 pm
Last Name: Minch
City: Chestertown
Stanley used to offer this tool, and L-N still does. Bamboo rod makers use it in their aluminum or steel jigs for planing the long hexagonal lengths of material for assembly into rod section. You set the blade so that it is not lower than the bed but just cuts inside the groove, and you can run the bed over your jig without planing the jig. Would be simple to alter a garage sale #4 or #5 like this, making the groove as wide as you wanted. I keep a special plane for a shoot board, why not for jigs?
https://www.highlandwoodworking.com/lie ... plane.aspx
Ed
PostPosted: Sun Sep 23, 2018 3:38 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Woodie G wrote:
For odd radii, bench hook and block plane. For 15', 28' and 60', we use the Luthier Tools tablesaw brace radiusing jig finished with a jack plane while the brace is still presenting a flat surface to the tool. We are typically doing 3-4 brace kits at one time, so jigs do save a significant amount of time.
^^^Agreed!
PostPosted: Sun Sep 23, 2018 4:06 pm
First name: Brad
Last Name: Combs
Woodie, I can’t seem to find this jig online. Is it from Chris at luthiertool.com?
Brad
PostPosted: Sun Sep 23, 2018 4:41 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Perhaps Woody means this from Luthier Suppliers:
http://www.luthiersuppliers.com/products/p6.html
These users thanked the author doncaparker for the post: bcombs510 (Sun Sep 23, 2018 5:58 pm)
PostPosted: Sun Sep 23, 2018 6:48 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
I was not in the shop today, so was working with what appears to be a very faulty memory! Luthier Suppliers, indeed. For shops that are less tablesaw-centric, the jig works with a bandsaw as well, assuming a fence and accurately tracked blade. A pass with a plane clean s up or sanding in the appropriate dish (the plane is much faster).
- Beth Brower
PostPosted: Mon Sep 24, 2018 3:15 am
You can also tack glue 3 or 4 braces together then shape them all at the same time, assuming they are all at the same radius. I've done that when I'm after super speed.
These users thanked the author Michael.N. for the post (total 2): olmorton71 (Thu Sep 27, 2018 8:09 pm) • ernie (Mon Sep 24, 2018 7:26 am)
PostPosted: Mon Sep 24, 2018 8:53 am
I make the back braces start to finish with no jigs in about 6 minutes....
First I take a piece of spruce the length of my longest brace and 5/8" high by about 1-1/4" wide.
Then I sand a radius (by eye) on one side with my 6 X 89 sander with the table at 90 degrees to the platen.
I then compare it to my radius dish-I am usually right on or close-I adjust if necessary.
then I slice that up into four 1/4" (or 5/16") braces
Then I cut them to length and scallop the ends (roughed out on the bandsaw first) on the wheel end of the belt sander
and bevel the length on the platen -Done!
I leave a little flat on the top of the braces for the go bars to have some purchase.
So I am gluing on a 95% finished brace to the back.
These users thanked the author Brad Goodman for the post (total 2): Pmaj7 (Tue Sep 25, 2018 5:19 pm) • ernie (Tue Sep 25, 2018 8:44 am)
Users browsing this forum: joe white and 23 guests
