It is currently Sun Jul 20, 2025 11:26 am
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jan 06, 2018 11:39 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I think it could be adapted to a drum sander. I use a similar sled for radiusing my fingerboards. You would not need tape either. just put a layer of sandpaper along guide and a stop on the end for added safety. My sander is 22" wide, so I could put maybe 8 slots in. I could use different lateral placements of sled to avoid hitting same locations on paper. It might take two passes on each side. I guess I could make the tilted guides on the table saw. What you all think? Pine is soft, 80 grit is enough I think.
Curious, what angle is the guide?
I've never experienced sniping with thin stuff.
PostPosted: Sat Jan 06, 2018 1:17 pm
Last Name: Colbert
City: Anacortes
Yes it would likely work. I cut the angle guides on the table saw running the stock through vertically as to maintain the slick melamine surface, not something you will be worried about with a sled. I used to use a similar sled to radius my fretboards also, and if I wasn't paying attention I'd snipe the last 2" on the way out (I'm now using my cnc for this). If I was going your route I'd swap the configuration and place the fence on the right and the angle guide on the left, maintaining the angle front to back on the jig. This will cause the drum to force the material up against the fence during the operation also distributing wear across the drum/abrasive surface. The angles I used are 8° first pass, 16° on the second, using a 1/4" X 5/8" piece of brace stock. 1/4" X 5/8" is my standard brace for everything but my UFB.
Cheers,M
These users thanked the author Michaeldc for the post: Pmaj7 (Sat Jan 06, 2018 2:54 pm)
PostPosted: Sat Jan 06, 2018 6:54 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, it looks like I will be building your sled. Right after I got off this site, I went to FaceBook Market Place and found a Dewalt 735 that had just been listed (like 2 hours ago). $300. Had to drive 30 miles to go see it. It was in perfect, hardly ever used shape. Bought it. How lucky was that?
I am wondering given the depth of cut considerations how you take as much off on a single pass as you do. I will go to Lowes tomorrow and get some melamine.
PostPosted: Sat Jan 06, 2018 8:10 pm
Last Name: Colbert
City: Anacortes
Cool! Way to save a couple a hundred!
The capacity of the your new planer is 1/8" per pass. I'm taking 3/32" per pass/side leaving approximately 1/16 at the top of the triangle. 3/32"*2+1/16"=1/4"
M
PostPosted: Sat Jan 06, 2018 8:16 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks! Could you please specify thickness of your guides? I also noticed your guides were slightly canted to feed direction. Also, some bracing is thicker than others. How do you adjust?
PostPosted: Sat Jan 06, 2018 9:18 pm
Last Name: Colbert
City: Anacortes
The wood guides are 1/4" X 5/8". The canted guides are 8° and 16°, are approximately 3/4" wide and tapering to zero. The guides run the full length of the base. The base is the same width as the space between the guide rails on the planer. The length runs the full length of the infeed/outfeed tables plus a couple inches for the jig stop. All of my bracing starts out at 1/4" X 5/8" with the exception of UFB which starts out at 5/16" X 7/8".
If you want to make a wider/taller brace, start with a wider/taller piece and simply raise the planer cutter head.
M
PostPosted: Sat Jan 06, 2018 10:34 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Got it. Thanks
PostPosted: Sat Jan 06, 2018 10:43 pm
Last Name: Colbert
City: Anacortes
Mike OMelia wrote:
Got it. Thanks
Oh, and set the guides about 10° to starboard. This will cause the feed rollers to force the braces into the fences.
PostPosted: Sat Jan 06, 2018 11:30 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Michaeldc wrote:
Mike OMelia wrote:
Got it. Thanks
I knew there had to be a reason for the angle I noticed in ur jig
PostPosted: Sun Jan 07, 2018 12:44 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
One more thing. How long is ur base? And how do you bond strips to melamine? Don’t use it much
Last Name: O'Melia
City: Huntsville
State: Alabama
PostPosted: Sun Jan 07, 2018 1:21 pm
Last Name: Colbert
City: Anacortes
I don't use it much either. Run it the full length of the infeed/outfeed tables plus a couple inch for the stop. I used medium CA to glue the guides.
PostPosted: Sun Jan 07, 2018 4:36 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Don't have infeed outfeed tables yet. CA? Never would have guessed that.
Holy crap Michael, that silly thing is LOUD!!!
PostPosted: Sun Jan 07, 2018 5:28 pm
Last Name: Colbert
City: Anacortes
Wait till you connect a dust collector.... 18-20" would likely do for the base.
PostPosted: Sun Jan 07, 2018 6:09 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks!
PostPosted: Mon Jan 08, 2018 7:08 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
So, yesterday, I made a new brace profiling jig/fixture based on the one Michael uses in his planer. I have a drum sander not a planer, so mine is a sled that carries the brace under the sanding drum. Just like his, the brace is placed in the left side first. It's sanded down to taste, then flipped end-for-end, and placed on the right side of the sled to sand the other side. I tested it out today on some scrap fir and it worked great. No need for sandpaper on the angled strips. The brace stays put just fine. Definitely slower than Michael's planer, but a good deal faster and simpler to use than the two-piece jig I have been using. [:Y:] Thanks, Michael!
These users thanked the author J De Rocher for the post: Michaeldc (Mon Jan 08, 2018 9:23 pm)
PostPosted: Tue Jan 09, 2018 3:09 pm
If you have a tablesaw you can make a simple jig to angle the tops of the braces by dadoing a foot long piece of scrap with a dado the size of the brace, then angle the blade and cut into the dado at the appropriate point. This becomes the jig you clamp to the fence and you push the strips through, first one way and then the other. You can feed the braces in one behind the other. This jig is similar to the one for making triangular kerfed linings.
PostPosted: Wed Jan 10, 2018 10:44 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Nice job. You proved the point. I'm a little embarrassed that I did not follow through. Guess I was looking for an excuse to buy the planer I always wanted. Lol
PostPosted: Wed Jan 10, 2018 11:19 pm
Now, how will you put the radius in the bottom?
PostPosted: Wed Jan 10, 2018 11:37 pm
Last Name: Colbert
City: Anacortes
I use a radius template to mark the brace, tilt the table on my 6" X 48" sander to 8° which matches the bevel on the brace, and sand to the line.
PostPosted: Thu Jan 11, 2018 12:37 am
First name: Jay
City: Bothell
State: Washington
Hot dang! You're chalk full of good ideas! I've been using a radius template to mark the brace, then removing the bulk of the unwanted wood with the band saw, and then sanding to the final radius in the radius dish. I'll try the sander approach on the next set of braces.
PostPosted: Thu Jan 11, 2018 6:51 am
Last Name: Colbert
City: Anacortes
The only rub is that laying say a 15' radius template against a pre-beveled brace changes the final radius once cut. The problem increases with an increase in bevel angle. My brace bevel is 8° so the radius change is tiny and I don't worry about the difference. Anyway you may want to check your results against your dish. Actually come to think of it the plate also changes the radius. Something around 14'-11-7/8" on the brace side? Once again a tiny difference.
M
PostPosted: Fri Jan 12, 2018 7:32 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Not that much m a big fan of radiusing with a dish, but why would that not work as well? I really want a better, faster way of doing that.
PostPosted: Tue Jan 16, 2018 7:12 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Finally got it put together. Works great. Thank you!!
PostPosted: Tue Jan 16, 2018 7:14 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Have to also add that I really like that planer. Speeds up brace making. I bought some routers (nice ones), some bits and a nice Dewalt Circular Saw off the fellow who sold me the planer. Sold all that stuff. Net cost for planer was $125. Happy dance.
