It is currently Thu Jul 31, 2025 4:34 am
 Post subject: My #2 a mahogany OOO
PostPosted: Wed Jul 12, 2017 4:06 pm
Last Name: Orr
Plan: Stew mac 000. Changed bracing pattern to add A frame bracing in upper bout, mortised into head block. Added scoop cutaway, sound port and arm bevel.
Back sides and top: mahogany/sapele. Cannot be more specific as it it is reclaimed timber from Bristol Timber Recycling Project. Width was limited hence 4 piece top and back.
Purfling: BWB
Binding: oak I cut myself
Fingerboard, bridge, head stock plate and back strap: EIR
Inlay, MOP on head stock, Abalone sound hole and son’s initials at 12th fret. All hand cut except MOP stars which were purchased
Finish: shellac sealer, Zpoxy grain fill then TruOil
Tuners: Wilkinson open back
Strung with a set of Martin light gauge strings
This is my second guitar (the first was the black walnut resonator I posted a while back) and this one was built for my son Mike. I have attached a picture of the bracing so you can see the changes I made. You will note that two of the finger braces are missing in this photo! Fortunately I spotted this before I attached the top! It has a low action and a wide 48mm nut. Plays well all up the neck with no buzzes, rattles or wolf notes. For this I have to thank Hesh for posting his method of setting the neck, flattening the fret board, cutting the nut and saddle etc. It worked a treat first time. Thank you very much Hesh and everyone else who posts here. It sounds good to me. Loud and even across all the strings with a full base and nice clear highs, which surprised me somewhat given the mahogany top. I am happy with the tight joint at the neck with no gaps under the fret board extension and the neat mitres on the purfling. Will try and get mu son to record something and put it on Youtube.
Would be happy to answer any queries. Cheers, Bob
PostPosted: Wed Jul 12, 2017 4:11 pm
Last Name: Orr
 Post subject: Re: My #2 a mahogany OOO
PostPosted: Wed Jul 12, 2017 5:12 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Beautifully done, Bob! Love the colour of the neck. Stained, or natural?
Alex
PostPosted: Wed Jul 12, 2017 10:55 pm
Congrats!
PostPosted: Thu Jul 13, 2017 3:39 am
Nice one Bob! I like the whole thing, bet you had a lot of fun making it too.
What did you use for a finish? And how do you like the tuners? - I have a set of them I'm thinking to use for my current build.
PostPosted: Thu Jul 13, 2017 6:17 am
Looks great!!! Tackling a scoop cutaway and bevel arm rest on your second build is quite admirable, but it looks pretty good.
Kent
PostPosted: Thu Jul 13, 2017 8:08 am
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
Very nice work. I'm curious about the bracing ( or lack of) on the bass side of the X brace. Seems like a large area of soundboard. Does this affect you tone in any significant way?
Brad Hall
Mystic Dawg Guitars
PostPosted: Thu Jul 13, 2017 10:14 am
Last Name: Orr
Alex
Natural, no stain used at all. Makes me think neck is genuine mahogany. That piece I know came from the handrail of an old local fire station that was pulled down and must be at least 50 years old. It was lovely stuff to work with.
Bob
PostPosted: Thu Jul 13, 2017 10:17 am
Last Name: Orr
Finish is three coats of shellac sanding sealer then grain filled with three coats of Z-poxy, sanding between then several coats of TruOil applied in thin coats with a cloth. Tuners are fine so far and seem to work nice and smoothly. Only been strung a couple of days so time will tell!
Bob
PostPosted: Thu Jul 13, 2017 10:19 am
Last Name: Orr
In the pic two finger braces are missing on the base side. Fortunately I noticed and rectified this before gluing on the top! Bracing otherwise is as per StewMac plan but with added A frame in upper bout.
These users thanked the author Bob Orr for the post: kjaffrey (Sat Jul 15, 2017 6:23 am)
PostPosted: Thu Jul 13, 2017 12:02 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
MMM...sweet. I love a mahogany top. Is that a 4pc top?
PostPosted: Thu Jul 13, 2017 12:10 pm
Last Name: Orr
Yes and the back too. It is made from reclaimed timber so I was limited in the width available. Bob
PostPosted: Thu Jul 13, 2017 1:53 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
Very nice job, looks great.
Jason Moe
LaCrosse WI 54601
PostPosted: Thu Jul 13, 2017 7:42 pm
Last Name: Beaver
City: Lake Forest
Beautiful work Bob. It will be a treasure forever
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jul 13, 2017 11:45 pm
First name: Mitch
Last Name: Johnson
City: Little Falls
State: Minnesota
Zip/Postal Code: 56345
Nicely done! That's a very nice looking #2. I've been wanting to build a 000 from the stewmac plans for a couple years now. I took some time off from building but I'm finally set up to build again. How were the plans to work from? Any complaints?
PostPosted: Fri Jul 14, 2017 10:15 am
First name: George
City: Seattle
Nice work, especially for a second effort. Well done!
George :-)
PostPosted: Fri Jul 14, 2017 12:45 pm
Looks like you pretty much nailed it. Nice!!
PostPosted: Sun Jul 16, 2017 10:35 am
Really nice looking guitar. Great job!
Users browsing this forum: Michaeldc and 21 guests
