It is currently Sat Jul 19, 2025 8:02 am
 Post subject: Need a Little Help
PostPosted: Sun Jun 11, 2017 6:34 pm
Last Name: Beaver
City: Lake Forest
I need to make two Macassar Ebony guitars this year. I do have a traditional set with a 2 piece back I'll be using, but have been having a hard time locating another set I like.
I was able to located a few boards that I think will work, but none wide enough for a two piece back. I came up with these alternatives.
Which of the two would you prefer? If you don't like either please say so.
Thanks for the help!
Joe Beaver
Maker of Sawdust
 Post subject: Re: Need a Little Help
PostPosted: Sun Jun 11, 2017 6:42 pm
I like the top one, but I would taper the center section similar to what Martin does with the D 35 series guitars (and also use the added purfling lines).
PostPosted: Sun Jun 11, 2017 7:56 pm
Last Name: Beaver
City: Lake Forest
Thanks Clay, i might experment with a couple backstrips. It would also be a good way to pick binding. I'm thinking gaboon ebony or flamed koa
Joe Beaver
Maker of Sawdust
PostPosted: Sun Jun 11, 2017 8:14 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I agree with Clay, I like the top one better. The symmetry of the center piece in the lower one is nice, but for me, the two type of woods don't go together as well as the three panels in the top one do.
These users thanked the author J De Rocher for the post: Joe Beaver (Mon Jun 12, 2017 1:12 am)
PostPosted: Sun Jun 11, 2017 8:16 pm
First name: Jan-Alexis
Last Name: Tremblay
City: Montreal
Top one for sure.
These users thanked the author Johny for the post: Joe Beaver (Mon Jun 12, 2017 1:12 am)
PostPosted: Sun Jun 11, 2017 8:57 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Top one for me,
These users thanked the author Imbler for the post: Joe Beaver (Mon Jun 12, 2017 1:12 am)
PostPosted: Sun Jun 11, 2017 8:58 pm
Top one for me too.
These users thanked the author SteveSmith for the post: Joe Beaver (Mon Jun 12, 2017 1:12 am)
PostPosted: Sun Jun 11, 2017 9:12 pm
Last Name: Beaver
City: Lake Forest
I'm beginning to think the top one may have it.
Any thoughts on using back strips between the pieces? Or maybe just glue them together and go for a 'one big board look'?
Joe Beaver
Maker of Sawdust
PostPosted: Sun Jun 11, 2017 9:19 pm
City: Escondido
Zip/Postal Code: 92029
+1 on top
+1 on tapered
-1 on back strips (it is busy enough as it is).
These users thanked the author rlrhett for the post: Joe Beaver (Mon Jun 12, 2017 1:12 am)
PostPosted: Sun Jun 11, 2017 9:46 pm
First name: Fred
City: Winnipeg
Of course top one. If a strip black and maybe 1/8" wide at most. Or (ok things are getting weird now) maybe a strip of the same wood you have shown, cut from the opposite side or cut and flipped around so that it has the same texture (visually) but it declares separation between the boards. I do like how most of the joined areas blend in with its mating surface but the lower right hand side of the middle one does not seem to work with the adjoining piece.
I hope that made some sense. Otherwise, I love the wood.
These users thanked the author printer2 for the post: Joe Beaver (Mon Jun 12, 2017 1:12 am)
PostPosted: Sun Jun 11, 2017 10:49 pm
Top fo sho.
Bottom one would be good if you were doing a Flying V shape.
These users thanked the author Pmaj7 for the post: Joe Beaver (Mon Jun 12, 2017 1:12 am)
PostPosted: Mon Jun 12, 2017 4:41 am
Last Name: Orr
No backstrip on top one which I prefer. You have a got a nice grain match there so you don't need a back strip. Bob
These users thanked the author Bob Orr for the post: Joe Beaver (Mon Jun 12, 2017 10:28 am)
PostPosted: Mon Jun 12, 2017 6:06 am
State: Tennessee
Nice set of macassar in the classifieds
These users thanked the author Clinchriver for the post: Joe Beaver (Mon Jun 12, 2017 10:29 am)
PostPosted: Mon Jun 12, 2017 6:47 am
Top one, no backstrip!
These users thanked the author Colin North for the post: Joe Beaver (Mon Jun 12, 2017 10:29 am)
PostPosted: Mon Jun 12, 2017 3:03 pm
First name: David
Last Name: Morris
City: Cheyenne
State: WY
Top one, no backstrip.
These users thanked the author davidmor1 for the post: Joe Beaver (Mon Jun 12, 2017 3:04 pm)
PostPosted: Mon Jun 12, 2017 3:07 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
Top set, tapered, no back strip.
These users thanked the author dpetrzelka for the post: Joe Beaver (Sun Jun 25, 2017 2:13 am)
PostPosted: Tue Jun 20, 2017 11:20 pm
Last Name: Beaver
City: Lake Forest
It does make sense. I was leaning the way you suggested, but then I decided that since I had three bookmatched pieces I would join 2 and rip the other one and make a 4 piece back.
Joe Beaver
Maker of Sawdust
PostPosted: Wed Jun 21, 2017 3:57 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I like the top one and agree that tapering the middle slice would look good. Especially if you can get the taper to go well with the angle of the grain in the upper bout.
I'm assuming you only have 3 slices. If you have 4, it would be cool to bookmatch two halves then bookmatch that but still tapered. By that I mean tat the center section would be wedge shaped but bookmatched and the outside of those pieces would be bookmatched to the outer two pieces. The 4 seams would not be parallel but each seam would have a repeating pattern.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: Joe Beaver (Thu Jun 22, 2017 1:04 am)
PostPosted: Wed Jun 21, 2017 11:38 pm
First name: Chuck
Last Name: Hutchison
City: Houston
I like the bottom one. It's unique.
These users thanked the author ChuckH for the post: Joe Beaver (Thu Jun 22, 2017 1:04 am)
PostPosted: Thu Jun 22, 2017 1:06 am
Last Name: Beaver
City: Lake Forest
Chuck,
The bottom one is kind of interesting. Actually, the center wood is also Macassar ebony.
Joe Beaver
Maker of Sawdust
Last Name: Beaver
City: Lake Forest
Wow, triple post... don't have a clue how that happened
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jun 22, 2017 1:07 am
Last Name: Beaver
City: Lake Forest
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jun 23, 2017 8:31 pm
I'm with Chuck. Top is nice but looks like every other high end guitar out there.
These users thanked the author Edward Taylor for the post: Joe Beaver (Sun Jun 25, 2017 2:13 am)
PostPosted: Sat Jun 24, 2017 7:17 am
"Top is nice but looks like every other high end guitar out there."
And that's a bad thing?
To me, the pieces in the bottom picture have an interesting look individually, but don't work well together. I may be just a "stick in the mud" and sticking with an option I have seen done before. When I first saw a D35 I wasn't too keen on it, but later appreciated it for it's original raison d'etre - a way to use good wood that was too narrow for the two piece back of a Dreadnaught guitar. The tapered center section allowed for the maximum utilization of the wood (two tapered pieces from each back half and less waste of side pieces) and the back purfles created some visual separation of the three sections.
But some people prefer the unusual and unique - if you are building these for someone they would be the person to ask.
These users thanked the author Clay S. for the post: Joe Beaver (Sun Jun 25, 2017 2:12 am)
PostPosted: Sat Jun 24, 2017 12:30 pm
Not a bad thing at all. Variety is however, the spice of life.
The bottom piece strikes me less as a piece of wood and more as a scene. There is drama... a focal point of darkness is cut through by the light, in the periphery is chaos.
:P
These users thanked the author Edward Taylor for the post: Joe Beaver (Sun Jun 25, 2017 2:12 am)
Users browsing this forum: Ken Lewis, Michaeldc and 13 guests
