It is currently Wed Jul 30, 2025 2:36 am
PostPosted: Sat May 13, 2017 4:31 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I spent 1.5hrs looking for this tape between HD and lowes.It/s vy thin and works well for for fretting templates, bridges jigs etc . I have some double sided tape with fiberglass reinforcement I find it a real Pita to use.What I/m looking for is the older style of tape . Where can I buy some ?? thank you
PostPosted: Sat May 13, 2017 5:20 pm
Last Name: shelton
City: Alsea
State: Oregon
Zip/Postal Code: 97324
Highland hardware (on the net).
These users thanked the author jshelton for the post: ernie (Sat May 13, 2017 8:41 pm)
PostPosted: Sat May 13, 2017 5:48 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Stewmac #1689 It is two inches, but very thin and extremely tenacious,
These users thanked the author Imbler for the post: ernie (Sat May 13, 2017 8:41 pm)
PostPosted: Sat May 13, 2017 6:14 pm
Last Name: Beaver
City: Lake Forest
It's not 1", but I use golf club grip tape. Works great and you get a large roll for about $10. Any golf shop should have it or online from Hireko, Amazon, Golfsmith or etc.
If I need a smaller piece I cut it.
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: ernie (Sat May 13, 2017 6:44 pm)
PostPosted: Sat May 13, 2017 7:28 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
Super glue and cheap masking tape
These users thanked the author surveyor for the post: ernie (Sat May 13, 2017 8:42 pm)
PostPosted: Sat May 13, 2017 8:19 pm
I'll second Highland Woodworking. Their tape is much better than the carpet type tape you find at HD.
I don't think they have 1" but 3/4" might work.
http://www.highlandwoodworking.com/doublesticktape3x36yds.aspx
These users thanked the author kjaffrey for the post: ernie (Sat May 13, 2017 8:42 pm)
PostPosted: Sun May 14, 2017 1:59 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I second the suggestion of the masking tape and super glue trick. If you haven't ever tried ito you will be amazed at the strength and simplicity.
Let's say you want to plane a fingerboard to thickness and you want to secure it to the benchtop. Put a strip of ordinary masking tape on the back of the work piece (in this case a fingerboard blank) for its full length, and put another strip on your bench top. Rub them down to stick them well to each surface. Then put a very small amount of super glue (thin CA) on one of the strips (don't let it stray beyond the edges of the tape), and spray some accelerator on the other strip. Then place the work piece onto the bench so the two strips are aligned. They will stick very strongly. You can go at it with a plane as hard as you like and it won't move anywhere. When you want it separated use a thin knife blade or palete kniife to peel one of the tape strips off.
These users thanked the author Mark Mc for the post: ernie (Sun May 14, 2017 5:53 am)
PostPosted: Sun May 14, 2017 4:25 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
The great virtue of double sided carpet tape with fiberglass reinforcement is zero force removal with naphtha. For holding rosettes to carrier boards, for milling crack reinforcing cleats similar to what TJ Thompson uses, or for other use where a palette knife or other forceful separation will not work well, double-sided tape with a permeable scrim (e.g., fiberglass) will do the job. While the CA and tape trick works well for many one-shot holding jobs, double stick tape is preferred in this shop where the potential for finish damage or marring posed by some misplaced CA or tape alignment issues (common in repair work) outweighs ease of use. Finally, for multi-use applications, such as on nut or saddle carrier boards, holders for bridge/small component shaping, or classical guitar internal magnet placement to secure arm rests (where less reversible adhesives are not acceptable), the durability of and ease of cleanup of an indoor/outdoor double-stick fiberglass reinforced tape is very useful.
We use Duck Brand 392907/442062 for moderate tack jobs and Shurtape #282640/#280396 where higher tack, higher shear strength, or higher separation resistance is desired (e.g., between raw wood surfaces). The Duck Brand products are available from Amazon as Prime items (about $9 for a 36mm x 12.8m roll or 48mm x 22.8m roll delivered) and the Shurtape product from Lowes.Com ($5 plus shipping and sale tax for a 36mm x 12.8m roll, SKU 256904; $9 plus shipping and sales tax for a 48mm x 22.8m roll, SKU 256882).
I hope this helps! Forget cutting the stuff with scissors - use single-edged razor blades to both cut and to lift the backing from the tape...much less mess than cleaning off the adhesive and stray fibers from our good shop shears.
- Beth Brower
These users thanked the author Woodie G for the post (total 3): Pmaj7 (Sun May 14, 2017 11:37 am) • david farmer (Sun May 14, 2017 8:26 am) • ernie (Sun May 14, 2017 5:50 am)
PostPosted: Sun May 14, 2017 12:13 pm
https://www.bedbathandbeyond.com/store/ ... aQodBN0Avg
Ken Cierp
These users thanked the author kencierp for the post: ernie (Sun May 14, 2017 5:45 pm)
PostPosted: Wed May 17, 2017 3:04 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
For any one interested . I bought a 40 yd roll of 1.5in old schoold double sided tape for $9 including shipping from a vendor 3 rd venue.com on e - bay
