It is currently Sat Jul 26, 2025 8:20 pm
PostPosted: Mon Nov 17, 2014 9:00 pm
First name: D
Last Name: S
Hey fellers, what is a good brand of tape?
I have not been cutting with templates lately due to mishaps.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Nov 18, 2014 12:08 am
I just buy whatever double-sided carpet tape the hardware store across the street has in stock.
PostPosted: Tue Nov 18, 2014 10:36 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
The best I have found is the 3M tape StewMac sells, I went through several different store brands but on trying this tape it was much superior in its hold. I do a lot of template operations and have not had any movement issues with it. Can be a bit of a pain to separate but this is a good thing in my mind.
Fred
Fred Tellier
PostPosted: Tue Nov 18, 2014 2:08 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
This question made me smile. I've been using Sellotape brand ever since I started building guitars in New Zealand. Readily available at home improvement centres in a variety of widths: http://www.sellotape.co.nz/products/stationery/tapes/double-sided/63-double-sided-general-purpose.aspx
I never thought it was anything special, until I tried to buy something similar in Canada and the US, and really couldn't find anything comparable in home improvement or stationery stores. I went back to NZ last Christmas for the birth of my grandson, and stocked up on Sellotape while I was there.
PostPosted: Tue Nov 18, 2014 5:32 pm
First name: D
Last Name: S
Thanks for the replies!
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Nov 18, 2014 5:58 pm
First name: Jim
Last Name: Outman
City: LaGrange
State: GA
Zip/Postal Code: 30240
Yes! I had to cut out a neck and replace it on a bass due to tape that slipped while routing. Will check it out.
PostPosted: Tue Nov 18, 2014 9:51 pm
First name: Freeman
Last Name: Keller
While I use 3M tape I also try to back it up with a screw or clamp.
PostPosted: Wed Nov 19, 2014 9:58 am
The best I have used is the 3M 9589. That is what I buy for students at work and it has never failed.
My home shop budget though usually goes for the hardware store carpet tape :( And even with the frown it still works great.
Burton
Brookline, MA.
PostPosted: Wed Nov 19, 2014 6:49 pm
First name: D
Last Name: S
I reckon I'll order some from Stewmac.
I have used carpet tape, but it's a hassle getting the goo off.
Thanks!
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Nov 20, 2014 12:33 am
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
I've been using Fasttape from Fastcap. It sticks great, kind of a pain to peel the paper off the one side and really a pain to get off your wood. Sticks like crazy though, I think it's sold as adhesive for applying cabinetry edgebanding, and it claims to be permanent. It's not, if you have a putty knife and a scraper, lol.
PostPosted: Thu Nov 20, 2014 7:19 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I use Itape 591. It's like double sided masking tape. It is strong, relatively easy to remove, doesn't shred and leaves no residue.
I get it from McMaster, their p/n is 76405A12 for 3/4".
Kevin Looker
edit:
It's relatively easy to remove unless you put the parts in a vacuum press DAMHIKT [headinwall]
I'm not a luthier.
These users thanked the author klooker for the post: dzsmith (Thu Nov 20, 2014 7:51 am)
PostPosted: Thu Nov 20, 2014 6:46 pm
State: AR
Another vote for the StewMac tape...good stuff.
It can be a little work separating the pieces and removing the tape but I found it's easier to roll the tape off rather than trying to
pull it off.
PostPosted: Thu Nov 20, 2014 8:54 pm
I use the StewMac tape. A little Naptha will make the tape release easily.
