It is currently Tue Nov 26, 2024 3:50 pm
 Post subject: Grain filler, locally?
PostPosted: Wed Sep 10, 2014 8:50 am
First name: sean
State: nm
Zip/Postal Code: 88349
Country: us
So, I know there are many methods to grain filling. I was walking around home depot yesterday wondering what they keep in stock that would work. To be honest I hate ordering anything if I don't have too, and I try to get as much as possible local. I already have to order hardware and electronics as it is, when I finish a guitar I might have more than $100 lost in shipping charges alone.
I have even thought about buying a few products to test out. Since no hardware stores have a luthier sections, anybody have any ideas?
Whatever you do DON'T confuse me as an EXPERT, or MASTER, just a self learned trial and error guy. I had to build a dozen guitar before I found out what a "Luthier" even was (????)
PostPosted: Wed Sep 10, 2014 10:52 am
You can sand egg white into the pores using 320 grit sandpaper.
Work small areas and use a razor blade to scrape off the excess slurry and aid in packing it into the pores.
It works amazingly well. Some woods will require a couple of applications.
Try it, it'll only cost you an egg.
PostPosted: Wed Sep 10, 2014 3:10 pm
First name: Mark
City: Concord
Bet you walked right past the acrylic base drywall spackle. Tint it with matching acrylic paint (~3oz plastic bottles) from the arts and craft section at your local store. Add black to the tinted spackle for the darker woods. Apply with a squeegee, dry for a day, sand back to the surface, re-apply, etc. The spackle and the surface needs to dry and finish shrinking between each coat otherwise your topcoat will orange peel. Plan on 3-4 coats. Try it on cut-offs under your top coat to get the tint right.
These users thanked the author Mark Fogleman for the post: Van Savage (Sun Sep 14, 2014 8:17 pm)
PostPosted: Wed Sep 10, 2014 7:19 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Benjamin Moore paste wood pore filler. You can color it with commercial stains or with artist's oil colors. If people tell you it leaves a "cloudy" appearance, don't listen. That's just because they haven't got all the residue sanded or buffed off after filling.
HOWEVER:
Be advised that this will fill the pores and give an opaque appearance to the pores--because they will be level with the surrounding wood fiber. I like this appearance. You might not.
Here's a picture of a highly-figured walnut banjo head plate, filled with this material, stained with a bit of dark walnut oil stain for contrast and tinted with a bit of cadmium red artist's oil color for warmth. See any cloudiness here?
These users thanked the author cphanna for the post: Van Savage (Sun Sep 14, 2014 8:16 pm)
PostPosted: Wed Sep 10, 2014 8:35 pm
City: Tyler
That's right, BM's filler is a fine product. I use similar from Sherwin Williams. Got a gallon of it, I've done about 15 guitar necks with it and don't think I'll ever run out.
These users thanked the author Glen H for the post: Van Savage (Sun Sep 14, 2014 8:16 pm)
PostPosted: Thu Sep 11, 2014 10:52 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Glen, thanks for the tip about the Sherwin Williams product.
Patrick
PostPosted: Mon Sep 15, 2014 11:22 am
First name: Freeman
Last Name: Keller
Both CA (medium viscosity) and slow setting epoxy (I like Zpoxy) are great pore fillers, particularly for highly figured wood. Zpoxy does a very good job of popping the grain on wood like koa.
Users browsing this forum: No registered users and 49 guests
