It is currently Fri Nov 22, 2024 11:26 pm
PostPosted: Mon Jun 16, 2014 8:19 am
First name: Francisco
Last Name: Marchante
State: Cádiz
Country: Spain
Hi! I would like to know how to do Blue Mist finish. Automotive paint maybe? Do I have to apply a base color like for example white? And then clear coats of gloss
Due to not having airbrush tools, I will buy aerosol sprays cans. What brands do you recomend ?
Like this:
PostPosted: Mon Jun 16, 2014 9:12 am
First name: Stuart
Last Name: Gort
Mohawk Finishing makes an entire line of opaque tints used in lacquer. If you send those pics to your local dealer he'll be able to pick the tint....or tell you if he can't match it. He'll probably also be able to give you some details about the procedure. I shouldn't speak for all Mohawk dealers but my guy has been very helpful in the past with this kind of stuff.
That looks like simple base coats of tinted lacquer and several coats of clear over the top. There's probably a sub coat of gray (neutral) primer under the color.
StuMusic
PostPosted: Mon Jun 16, 2014 2:42 pm
State: Cádiz
Country: Spain
Thank you. The only problem is that I am in Spain and Mohawk Finishing products are almost null.
Spray like Krylon or House of Kolor work well?
Also if I do the color base coat do I have to put clear be core the next coat for the final colour?
PostPosted: Tue Jun 17, 2014 7:18 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Looks like a pearl with a fine metallic to me. You should be able to find a similar color from HOK. Seal the wood with an appropriate sealer, sand out at 600, spray color coats then clearcoat.
Brian
PostPosted: Tue Jun 17, 2014 7:47 am
^^^ I agree with Mr. Howard. ^^^
PostPosted: Tue Jun 17, 2014 4:14 pm
State: Cádiz
Country: Spain
Thanks for the answers.
I also have questions about the primer. I've seen coloured ones, what primer do you recommend for mahogany ? White coloured one to apply blue colour coat later?
PostPosted: Wed Jun 18, 2014 7:22 am
Last Name: Howard
City: Magnolia
State: Delaware
You will need an appropriate sealer for wood rather than a primer made for metal as the very base coat. Look for a polyurethane based sanding sealer and that should be compatible with the HOK spray paint. I typically do not use a colored "primer" under my colors but rather go right over the sealer. 4-5 medium wet coats should give coverage with almost any color over a sealer.
Brian
