It is currently Sun Jul 20, 2025 2:13 am
PostPosted: Wed Sep 11, 2013 10:32 am
First name: Matt
Last Name: Meyer
City: Muscatine
State: Iowa
Zip/Postal Code: 52761
I just saw this on ebay. Great idea and pretty simple. It suspends the test pickup over the strings. I wonder exactly how it is wired. It looks like a slider switch.
Here is the description:
AxeTrak® Pickup Tester / Sampler Patent Pending
Finally . . . A no hassle, quick and easy way to audition and test pickups on your electric guitar
Our Pickup Tester lets you test and audition guitar pickups on your guitar . . .
1. Without having to change, remove or even loosen your strings
2. Without needing a soldering iron to connect your pickup under test
3. Without having to remove your pickguard and pickup ring to access critical wiring
4. Without having to remove back plate plastic to access critical wiring
5. Tester mounts quickly and easily anywhere on the smooth finished surface of guitar
6. Lets you quickly audition series, parallel and split coil wiring configurations on mulit-wire pickups
7. Works perfectly with Seymour Duncan, DiMarzio, Fender, Gibson and all other manufacturers of standard size humbucking and single coil guitar pickups.
How does it work? This device works on the principle that it doesn't matter if the pickup is mounted under the stings or above the strings, as long as the distance between the pickup and the strings is the same, you will get the same results. Our pickup tester simply mounts the "pickup under test" upside down, like a bridge directly over your strings instead of under your strings. This device has special leveling feet with suction cups attached so that you can easily adjust the height of your pickup in relation to the strings. This unique design allows the user the same flexibility they would have if the pickup was mounted conventionally under the strings. The suction cups also provide a quick convenient way for the user to attach the tester anywhere on the smooth surface of the guitar. Then simply insert a 1/4" guitar cable into the tester and plug it into your guitar amp as you would normally to play your guitar. It's honestly that simple.
PostPosted: Wed Sep 11, 2013 11:11 am
Swell, but won't it get in the way when picking?
PostPosted: Wed Sep 11, 2013 12:16 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Someone posted that idea a couple of years ago in a thread about pickups. Probably fine for rough ideas, but bolting the pickup to the body will sound a little different. May not be enough difference for most people to hear.
PostPosted: Wed Sep 11, 2013 1:21 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Wont the magnetic fields from the pickups still in the guitar mess with the ones from the new pick up?
Brian
PostPosted: Wed Sep 11, 2013 2:09 pm
Good point.
