It is currently Thu Aug 07, 2025 9:40 pm
PostPosted: Mon Jun 24, 2013 2:56 pm
First name: Blake
Last Name: Dixon
City: Kelowna
Zip/Postal Code: V1V1W7
I just purchased some cardinal clear nitro finish.. I see there is a shelf life of one year unopened can? Is there true and if so I have a lot to deal with for those in Canada that use this product. Also what is the recipe for spraying i.e. mix with DA etc? Also do you cut the sealer as well or spray directly out of the can?
Blake
Blake Dixon
Kelowna B.C.
PostPosted: Mon Jun 24, 2013 3:17 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Always best to start with the manufacturers suggested application via the TDS
http://www.cardinalpaint.com/redBird/ne ... tds-1.html
Brian
PostPosted: Mon Jun 24, 2013 5:13 pm
One year? That surprises me. I assumed nitro would have a much longer shelf life than that... idunno
PostPosted: Mon Jun 24, 2013 7:36 pm
First name: Blake
Last Name: Dixon
City: Kelowna
That's what the label says. One year with an expiration date on each container with a tracking number. Do others keep it much longer?
Blake
Blake Dixon
Kelowna B.C.
PostPosted: Mon Jun 24, 2013 8:28 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Mix with DA? wow I didn't know you could do that. Can you really do that? I use a slow lacquer thinner, The dang stuff costs almost as much a the lacquer but it works good.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Mon Jun 24, 2013 11:25 pm
As Ukulele Mike said, use lacquer thinner to cut the Cardinal, not denatured alcohol. I've had good results with a 3:1 ratio of lacquer to thinner. I was warned by a pro finisher to hold the gun about 18" away from the work surface to avoid "microbubbles". Discovered that it was sound advice after I forgot once and held the gun closer. As far as expiration, I can't help. I use more than one gallon a year.
michael propsom
www.propsomguitars.com
PostPosted: Tue Jun 25, 2013 12:42 am
First name: Aaron
Last Name: Craig
State: Missouri
I spray sealer straight from the can.
Aaron Craig
PostPosted: Tue Jun 25, 2013 4:26 am
Last Name: Howard
City: Magnolia
State: Delaware
Blake
I Was talking to Dave Nichols at the symposium about cardinals new high solids lacquer that he was using. The product he described to me sounded like a pre cat lacquer based on certain behavior. While one year would be a long shelf life for a pre cat its feasible.
Brian
PostPosted: Tue Jun 25, 2013 7:27 am
I have some lacquer that is 10 years old and it still works fine.
PostPosted: Tue Jun 25, 2013 7:43 am
Call or e-mail them directly.
Mac Schurmeier
Cardinal Paint & Powder
Technical Representative
626-444-9274
macs@cardinalpaint.com
Guitar Building = Continuous Improvement Process
