It is currently Sat Jul 19, 2025 10:13 pm
PostPosted: Sun Mar 24, 2013 8:51 am
First name: matt
Last Name: zimbelman
City: Durham
Zip/Postal Code: 27705
This has been my favorite jig to build to date. I mixed all the features of other builds that I liked.
I bought the silicon heat blanket/slats from Blues Creek. Thank you B/C,they work great. I used 3/4 Baltic ply on the body and individual molds. I picked up a 15 min bathroom timer, and wired it inline on the temp controller.
My first attempt to bend was less than amazing. I broke a The first rib because I was too impatient and started bending to fast. Second rib I gave enough time to warm up and the jig worked its magic.
I am glad that it only took one broken rib to get the hang of the machine. I am not glad however that I chose for that first rib to be Koa. I have since bent local ash to a om size and am loving this machine. Now every board I see leads to the question, would that look good as a guitar?
I will need to be careful, this thing is very additive.Image
http://www.unit5woodworks.com
PostPosted: Sun Mar 24, 2013 2:03 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
You'll never be able to look at a straight line again! Nice looking rig, Matt! [:Y:]
Alex
PostPosted: Sun Mar 24, 2013 9:43 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
You can easily add a pid controller a thermocouple wire and a 20 amp solid state relay..available via ebay and lots of info on the forum , just search blanket controller here is a pic of mine using a mechanical timer
MK5acoustics.com
PostPosted: Tue Mar 26, 2013 8:04 pm
First name: matt
City: Durham
Thanks for the input. I thought about the thermocoupler setup. But it worked pretty well with just a standard meat thermo stuck in the bending sandwich.
By the way what are you bending in the photo posted?
PostPosted: Tue Mar 26, 2013 10:30 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
that's Adirondack spruce , laminates for falcate bracing,
MK5acoustics.com
