It is currently Sat Jul 19, 2025 7:55 pm
PostPosted: Wed Jul 22, 2009 8:51 am
I was HHG gluing some .050" ebony veneer to the inside of the upper bout for a sound port backing and was thinking of a quick way to make a clamping caul for it. I remembered back to my Discus fish breeding days when I used styrofoam under the aquariums to level them out from uneven surfaces. So I bent the veneer on the Ibex and I glued a piece of Styrofoam to a piece of wood and clamped it up. Perhaps this might come in handy for some other things. I understand this might not work in a situation where a lot of pressure is needed for a long time because the foam will compress and conform to the shape and may loose the clamping pressure. But it seems to work in this case.
These users thanked the author Chris Paulick for the post: Ron Bales (Mon Jul 14, 2014 7:26 am)
PostPosted: Wed Jul 22, 2009 8:53 am
After one hour the strofoam conformed to the shape but it was long enought to let the glue set and hold. But I wonder if this might have possibilities for making contour sanding blocks? Some food for thought and something to play around with I guess.
PostPosted: Mon Feb 04, 2013 9:17 pm
First name: David
Last Name: Eddy
City: Mandeville
State: La
Zip/Postal Code: 70448
[That's Clampologie at its best! [clap]
PostPosted: Tue Feb 05, 2013 12:28 am
I used to clamps to fit curves from wood roughly sawed to the shape, and then used automotive bondo for a form fit. Wax paper kept it sticking to the guitar.
PostPosted: Tue Feb 05, 2013 4:25 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Nice, Chris. I used Friendly Plastic to make my caul for this a'la Robbie O'Brien. It can be re-used if you put your port in the same place on the same shape guitar. If not, just drop it back in the hot water for a couple minutes :)
PostPosted: Tue Feb 05, 2013 4:53 pm
Yeah but you have to have something to do with that foam packaging material. Go Green.. :)
PostPosted: Tue Feb 05, 2013 11:17 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I'm all for re-purposing things!!
PostPosted: Fri Feb 15, 2013 3:40 am
Last Name: Sayers
City: rayne
State: essex
Zip/Postal Code: CM77 6TQ
Country: England
I use blue laminate underlay in layers for the same purpose. It can easily be cut with scissors and the glues doesn't stick to it.
