It is currently Tue Jul 15, 2025 5:35 pm
PostPosted: Sat Sep 08, 2012 9:02 am
First name: D
Last Name: S
Hi Fellows,
I'm planning way ahead on my next build.
I'm using Chinaberry that has open grain that I will need to fill.
I will use transtint water based dye.
I'm not sure how to go about filling grain when using dye.
I've used epoxy fill in the past with good results.
My thought is to apply the dye, apply the epoxy, and then try to sand it back leaving only the filled spots, then apply dye.
Perhaps I can add dye to the epoxy?
Any thoughts?
Here's a pic of Chinaberry I used on a build - I did not fill the grain on this one.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Sep 08, 2012 2:36 pm
First name: Stuart
Last Name: Gort
I'd like to hear a detailed description of the process that you used to create this one. Primarily I'm interested on what was done to create the unique differentiation of green and brown coloring.
It could be relatively simple to combine this process with an epoxy pore fill....depends on what you did to get the color here.
StuMusic
PostPosted: Sat Sep 08, 2012 4:56 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Yes, Transtint liquid will dissolve in epoxy - that's all I can help you with.
Kevin Looker
I'm not a luthier.
PostPosted: Sat Sep 08, 2012 6:07 pm
First name: Patrick
Last Name: Hanna
State: Missouri
You have doubtless already seen the answer that comes up most often: Experiment on scrap and see what works for you.
PostPosted: Sat Sep 08, 2012 8:20 pm
First name: D
Last Name: S
Hey Zlurgh, I just wiped on one coat of transtint dissolved in water. I was pleased to see some of the brown still showing.
DZ
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Sep 08, 2012 8:26 pm
First name: D
Last Name: S
Here's a pic of the rough Chinaberry.
I reckon the dye was absorbed more easily in the softer grain.
DZ
wah
Wah-wah-wah-wah
Wah
