It is currently Sun Jul 20, 2025 6:13 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Tue Feb 28, 2012 3:07 pm
State: AR
Roger I know you're wanting to make your own but...
http://www.guitarbuildingtemplates.com/Fender-family.htm -an option that you may not know about.
PostPosted: Tue Feb 28, 2012 3:11 pm
First name: Virgil
Last Name: Mandanici
State: FL
I would bet it is hard enough for that - can always do a "test run" Also: use Saran wrap to put around the neck when making a mold - I've made molds with Bondo - pretty cool schtuff!
PostPosted: Tue Feb 28, 2012 3:53 pm
I bet J-B Weld is hard enough, if Bondo isn't (which it probably is).
Old growth, shmold growth!
PostPosted: Tue Feb 28, 2012 4:00 pm
First name: Virgil
State: FL
JBweld is slightly weaker than kryptonite.
PostPosted: Tue Feb 28, 2012 5:03 pm
First name: Roger
State: Oklahoma
I actually have a jb weld steel stick at home. I may try that option on version 3 tonight since I don't have any 1/4" mdf on hand.
See, now we're getting somewhere :D
PostPosted: Tue Feb 28, 2012 5:33 pm
A couple hundred or so heads is better than one.....
PostPosted: Tue Feb 28, 2012 6:13 pm
Last Name: Killin
I didn't even think of using filler material with one that you already had that is close, but not quite right. duh I think it will work.
I don't think it really matters between Bondo and JBweld. Bondo might be a bit easier to touch up after it cures.
Good luck and let us know how it goes.
PostPosted: Tue Feb 28, 2012 7:40 pm
Sometimes you guys make things so difficult. Just make it in pieces.
A little bondo for touch up is fine. Too much (like doing the whole curve) can get knocked loose or tossed by the router.
PostPosted: Tue Feb 28, 2012 11:35 pm
Good tip StevenWheeler! You could actually just do butt joints with super glue or epoxy and then use a template bit to duplicate it to create your master.
I have a bunch of jigs with little bits of fixed areas where I used bondo.
And to Roger C108, I did not realiaze you were creating your template from 3/4 stock. I would have recommended using 1/4 material because it is easier to file right up to a line and keep it square. Don't dispare though this is a good learning experience for you on how to use hand tools lutherie is about learning from mistakes after all anyway. If I saved all my mistakes, I wouldn't have room in my shop for the good jigs. ;)
Ken
PostPosted: Tue Feb 28, 2012 11:44 pm
Ain't that the truth! laughing6-hehe laughing6-hehe
I just went through my shop and tossed out a bunch of bad templates I had laying around.
