It is currently Sat Jul 19, 2025 9:47 am
Post new topic Reply to topic  [ 125 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Tue Jan 10, 2012 11:42 pm
First name: Virgil
Last Name: Mandanici
State: FL
What fun would lutherie be without risks?
PostPosted: Wed Jan 11, 2012 12:22 am
First name: Jim
Last Name: Hansen
Well, lopping off a finger tip is one thing, but having your prized carved top crushed in a vacuum bag.. ugh.. no way man! :p
Jim Hansen
PostPosted: Wed Jan 11, 2012 12:41 am
First name: Virgil
State: FL
Awww, c'mon - that would make for a great "News at 11" clip!
PostPosted: Wed Jan 11, 2012 12:42 pm
First name: Shawn
Last Name: Smith
City: Indianapolis
can you explain what you are doing with the rosewood in the vacuum? are you covering the soundholes with a rosewood veneer? thanks.
I have been following this build eagerly as it is pretty similar to the build I am currently doing.
"All of us contain Music & Truth, but most of us can't get it out."
- Mark Twain
PostPosted: Wed Jan 11, 2012 1:32 pm
First name: Tony
Last Name: C
City: Brooklyn
What are you gluing in that pic with the rosewood piece over your soundholes?
http://www.CostaGuitars.com
PMoMC
PostPosted: Wed Jan 11, 2012 1:54 pm
First name: Shawn
Last Name: Smith
City: Indianapolis
Filippo Morelli wrote:
The top to the body blank. White glue. Vacuum rocks for itregular surface glue ups. Also water-based glue dries much faster under vacuum.
Filippo
ahhh... this is where you lost me. I thought you were gluing the rosewood. I didn't realize what you were actually gluing up in that pic. now it all makes sense. glue the top to the body and reinforce the soundholes with a little rosewood.
- Mark Twain
PostPosted: Sun Jan 15, 2012 8:30 pm
First name: Virgil
State: FL
Very nice Filippo!
PostPosted: Sun Jan 15, 2012 10:05 pm
Looking good, Mr. Morelli!!
PostPosted: Thu Jan 19, 2012 7:01 pm
Last Name: coloccia
Country: States
Okay for you photo junkies ...
Headplate thicknesses with Saf-t-Planer and cut on bandsaw to get in the zip code.
Difficult to see in this photo, but the neck is cut to a rough profile. This guitar gets a backstrap, which requires getting final thickness of the neck behind the first fret dialed in. This is because the backstrap is veneer and won't take much sanding to go through.
Faux bound fingerboard on this one. This is a jig I built to cut the correct edge angle on a fretboard. The fretboard is a pretty rare Curly Katalox, from Mexico. This photo shows the correct color, a dark purple.
The faux binding is 0.050" cutoffs from the fretboard blank prior to slotting, which are then glued back on with CA. Makes for a clean edge. Also allows for fretting after finish.
Finally a bit of West Systems epoxy glues up the fretboard. I use a technique I learned from Todd to locate the fretboard. I am NOT a fan of pins in the fret slot holes. Instead I take some scrap Mahogany blocks and CA them to the neck, butting the blocks to the fretboard. The fretboard can then be removed then wedged back into place. Under glue up it will not move. When finished, simple tap the blocks with a chisel and they pop off. The remaining neck area where the glue up was done gets routed off anyway.
Hope this is helpful. If anyone has questions or observations, please feel free to chime in.
Filippo
I usually do the pins through the fret slots, but I read this a couple of nights ago and decided to try it today. Great technique. I think I'll glue all my fingerboard on like this from now on.
PostPosted: Fri Jan 20, 2012 11:22 am
Wonderful build!!! I was wondering if you can share some tips on the top veneering. I understand the concept and want to do this on my future builds. My questions are around the middle seam. Did you do anything special to ensrue a tight seam? Besids getting very true edges and tape them up well? Did you have to account for extra slack because the edges are going to be going over the carve? Why the green tape vs the traditional brown veneer tape? I am just trying to head off any issues at the pass so to speak. Any detail on your jointing and glue up would be appreciated.
Thanks for any info.
Matthew
PostPosted: Fri Jan 20, 2012 8:43 pm
First name: Everett
Last Name: Caudle
City: Alachua
State: FL
Zip/Postal Code: 32615
I am generally happy to share any information that I have. . . . . As such I feel improper sharing that knowledge. . . . If there is anything else I can help with or share, please don't hesitate to ask!
Filippo
verhoevenc wrote:
I don't feel comfortable teaching it . . . . I'd contact Myka if I were you. If he's willing to share, but not got the time to teach, let me know and I'm sure we can work something out for the teaching side.
Chris
idunno
Has Myka got some sort of patent that prevents users of the forum from giving tips on how to do veneering? Seems like other tips are pretty freely shared around here.
BTW, not trying to pick an arguement (seems like we already have enough of that going on in other threads). Just trying to understand why there's so much reluctance to discuss the few specific questions asked by Matthew.
PostPosted: Fri Jan 20, 2012 8:53 pm
Last Name: coloccia
Country: States
FWIW, Cumpiano told me that I'm free to share everything and anything that he's taught me....which isn't much because the man is always busy. LOL. I did ask him, though, and he sat me down and gave me a nice lecture why he is so open. I guess it's just a matter of respect so I can understand the reluctance.
Somehow I think Myka's going to be fine with it, but he's easy enough to get in touch with if there's any doubt.
PostPosted: Sat Jan 21, 2012 11:21 am
No problem. I asked Chris the same question when he posted a build on another forum. He told me the same thing. I did not know he taught it to you. I thought u just figured it out on your own or was a common. Veneering practice that I have not learned yet. I did contact David at Chris's direction but got no reply. I will try again. I am just trying to avoid stupid or exPensive mistakes. Thanks for your sharing of your build. I have learned a lot from it already.
Matthew
PostPosted: Mon Jan 23, 2012 12:23 pm
Very cool treatment on the heel!
PostPosted: Mon Jan 23, 2012 5:01 pm
First name: Everett
Last Name: Caudle
City: Alachua
State: FL
It's a matter of respect. David Myka developed it. I did not. It is not common knowledge. I defer to David insofar as whether he wishes to share it. You are welcome to contact him.
Everett, if you go back and read my response - it was a) gracious, b) offered to help with anything else I could, c) explained why I felt it improper to share this specific answer and d) told you who you could contact to get more information. Given the threads I have posted on this forum over the years and information I have provided, I'm hardly a reluctant sharer of information. But ... I am a respectful first.
Filippo
Understood, Filippo. Like I said, not trying to open any can of worms. I just thought some of his questions looked like "routine" veneering questions and not really related to any one guy's particular techniques. I agree, your responses all generally meet the standards you laid out A-D and you are most certainly helpful sharer. Thanks for doing so.
Everett
PostPosted: Mon Jan 23, 2012 10:33 pm
City: Quakertown
State: Pa
Hey Filippo, Awesome thread. I was curious about the Myka Style jig and this thread cleared up most of my questions. However I do have a question, what is the purpose of the aluminum on the two top rails? Wouldn't it make sense to have them on the inside for the router bit bearing to ride against?
Scott
PostPosted: Tue Jan 24, 2012 11:16 am
City: Quakertown
State: Pa
Makes sense! Great Jig and nice looking to boot!
PostPosted: Tue Jan 24, 2012 12:06 pm
First name: Big
Last Name: Jim
Love the look of that Guitar [:Y:] You are a great jig builder as well , i am always impressed at the jigs you have ! I am at the point of deciding on binding for the drop top I added . Open to suggestions lol
PostPosted: Tue Jan 24, 2012 2:41 pm
First name: Big
Last Name: Jim
what I am kicking around is running a router bit into the side that takes out mostly mahogany and a small piece of the drop top and putting in a narrow " 1/8" black binding strip that just coveres the glue joint . so you have a edge visual of the mahagony 1/8" of black and then the roundover burl .
PostPosted: Mon Feb 20, 2012 8:37 pm
First name: Stuart
Last Name: Gort
Aaaaahhh....the finish. I KNEW that was going to pop that burl.
Now.....let's make one for each other. :)
StuMusic
PostPosted: Mon Feb 20, 2012 11:45 pm
City: chicagoland
State: illinois
regarding magnets, depending on their power you could probably get away with using half as many, most times- just mate each magnet up with a metal slug/screw/piece of rod, etcetera, instead of another magnet. same goes for the "removal tool", you'd just need a metal slug inlaid into the cover...i did a pair of speakers a couple months ago and i used big flathead screws as the "magnet receiving points", and inlaid the magnets themselves into the grill frames(Dynaco a25s, for you vintage audio buffs).
and of course another thing to plan around, of course, is making sure the magnet fields aren't too close to the strings or pickups...with some rare earth magnets that could translate to an inch or more distance
PostPosted: Tue Feb 21, 2012 12:01 pm
First name: Virgil
State: FL
Spectacular - love the heel too! [clap]
PostPosted: Tue Feb 21, 2012 1:43 pm
Great looking guitar, Fillipo! Nice work.
A couple of questions, if i may?
How long and how deep is your neck tenon/pocket? How deep are the humbucker routs?
PostPosted: Tue Feb 21, 2012 3:03 pm
Thanks for the info, Chris and Filippo.
PostPosted: Thu Mar 01, 2012 10:58 pm
First name: shad
Last Name: peters
Binding the average 00 size classical, dread, et cetera is far easier than doing horns, or sharp joints, especially when it comes to bending the wood (without breaking it) or getting the purfling miters just right. It's not beginner binding for sure.
Filippo
Sure it is! I guess I dont think its all that tough, my first experience was binding a solid body with some very tight curves in curly maple. It was a bear I guess, but it was a very valuable experience though and as far as binding guitars goes im not really scared off by much now.
But thats besides the point. Excellent work Filippo! I always enjoy watching your build threads. between you and chris I learn something new every time. Thanks for the contribution!
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
