It is currently Mon Aug 25, 2025 12:24 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 21, 2011 3:44 pm
What's form cutting (or a form cut neck) compared to drawing a neck in 3D and machining it? Thanks.
PostPosted: Tue Apr 26, 2011 7:07 pm
The neck would be held on it's edge and carved with a C-shaped cutter custom ground to a "neck" shape. I'd imagine you'd have to take three passes. One down the centerline and one parallel to each edge.
I used to carve necks similarly to this on a pinrouter with large radius roundover bits. It took a lot of cleanup.
