It is currently Sun Jul 20, 2025 2:17 am
PostPosted: Sun Jan 16, 2011 1:02 pm
First name: james
Last Name: wilson
hello, i have a bass with emg active P & jazz bass pickups, the precission pick up is shot and i was wondering what would happen if i switched the volume pot, installed a passive pickup and kept the active jazz pickup as is? thanks james
PostPosted: Sun Jan 16, 2011 2:37 pm
First name: shad
Last Name: peters
that depend entirely on how it is wired up.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Sun Jan 16, 2011 4:20 pm
First name: james
Last Name: wilson
what if i wire the passive pickup with a 250K double stacked pot, for volume and tone, and wire it to the jack separate of the active pot ? thanks james
PostPosted: Sun Jan 16, 2011 11:17 pm
First name: shad
Last Name: peters
i no wiring expert so maybe someone else can chime in here, but i think that that would work fine, although i dont know if you would run into issues playing the two together.
~shad peters
PostPosted: Mon Jan 17, 2011 4:21 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I would not do this myself, 'cause there is too much different in tone and power between active and passsive. You should put another active P-bass, but, if you want, you could rewire it all to get the possibility to switch 'em two on a passive mode.
Check out Seymour Duncan website for many wiring diagrams, it could help you.
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Mon Jan 17, 2011 4:43 pm
You can possibly run an active pickup with a 250K pot, you might get feedback issues, but I wouldn't run a passive pickup on a 25K pot, might sound muddy.
It's not good to mismatch your impedances.
http://www.emginc.com/pages/support
Go to the "wiring questions" section, it has a response to your query specifically.
Old growth, shmold growth!
PostPosted: Mon Jan 17, 2011 8:20 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I'm pretty sure an active pup needs a 25k pot, and passive needs 250-500k.
So, you would need to have 2 volume controls as I see it.
I would go with active or passive, not the 2 together.
You might get varied volumes which might get to be a pain if you are playing a "show".
You know, switch to active and it's way louder, etc.
PostPosted: Tue Jan 18, 2011 12:21 pm
First name: james
Last Name: wilson
thanks for the input, i think i will purchase another active pickup and be done with it. james
