It is currently Sat Jul 19, 2025 11:46 pm
PostPosted: Fri Dec 31, 2010 10:23 am
First name: Kenneth
Last Name: Jeffs
City: Chesterfield
Zip/Postal Code: 63017
I am getting ready to glue up my neck stock. My neck material is not the best quartersawn stock (I really thought I did a better job of picking this out-so much for my visual skills). I have two 4/4 x 3+ x36 " sticks. If I lay them out to use the 3+" as my fingerboard surface and then glue on a short piece for the heal I have a good blank. However, the grain is running more flatsawn than quarter. With the strength of lamination and a metal truss, do I have a strong enough blank? If not, I will just laminate 3 pieces so that the grain orientation is stronger (more quartersawn) and I have the width for the fretboard.
I am going to shoot the top and bottom plate edges and glue them up this week. Except for the neck blank question, beginning layout looks pretty straight forward.
I am sure I will have more questions when it comes to soundwell location. The beard plans are complete but I can see a challenge in getting the soundwell located properly. The Dusina article uses open sound posts for support so is not much help with soundwell issues.
PostPosted: Fri Jan 14, 2011 10:17 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I know this is kind of an old post with no replies,
but I was wondering if a truss rod is even necessary on a squareneck.
Do the plans call for it?
I think if you could make the neck 1 1/8" thick it wouldn't need a truss.
Especially if it was a laminated quartersawn deal.
Is it maple yer using?
I built an elec lap with a koa squareneck, 1 1/8", and an 1/8" fb,
that thing is pretty stiff.
PostPosted: Sat Jan 15, 2011 10:31 pm
First name: Kenneth
Last Name: Jeffs
City: Chesterfield
Alan,
I have the Dusina articles. He uses a 8/4 maple 3 x 24 blank with a 3/8 " squre steel truss rod for reinforcement. I was concerned with the poor quarter sawn grain in the mahogany blanks I had. I took and laminated 3 (4/4 x 2 7/8 x 24) and created a 12/4 x 2 7/8 x 24 blank. I was overkill but I should be able to cut from any orientation and still have a stable and solid neck.
Question:
What orientation will I choose? should it be on end or flat? I am leaning toward on end. What do you think.
I may not need a truss rod but routing and installation is not a big issue.
Alan thanks for replying. I was wondering if maybe I was talking too much. :)
Ken
PostPosted: Sun Jan 16, 2011 8:28 pm
First name: alan
City: Santa Rosa
State: ca
If it was mine I'd go for quartersawn.
It might not make much difference either way.
Good luck and have fun!
PostPosted: Sun Jan 16, 2011 11:55 pm
First name: Kenneth
Last Name: Jeffs
City: Chesterfield
Yes, I agree.... I am going to cut out the neck this week..
Thanks Alan. I will share some pics when I get them.
