It is currently Wed Aug 20, 2025 8:14 am
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Sep 09, 2010 10:24 am
Maybe that is why I ALWAYS have problems with under the saddle piezo's laughing6-hehe
But in all fairness I always have issues with them on anyone's guitar. I hate the darned things but usually manage to get them to balance out.
PostPosted: Thu Sep 09, 2010 10:56 am
First name: duh
Last Name: Padma
Yo, Hesh
Me too is sorry to read that you tops are doomed.
Please, if you wish, send me some pics of your dish and bracing/clamping method and any other pics associated with makeing the tops, me will print them out and show them to the Shipebo curanderos at this weeks ceremony and perhaps they can do something about removing this curse for you.
blessings
duh
Padma
PostPosted: Thu Sep 09, 2010 11:07 am
Hesh wrote:
Not questioning your results either I just continue to find it curious that so many of you are doing fine with unfitted bridges and when a bridge is very suspect to coming off in time anyway.
Hesh, to make things clear I fit my bridges to the theoretical radius of my top! I do leave a very thin overlap of varnish under the bridge though. As Todd pointed out, if there is a small gap at the wings (for Martin style bridges anyway), the slightest pressure will align things.
Laurent Brondel
West Paris, Maine - USA
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I agree that a radius block does a much better job than just taping a piece of sandpaper to the top. The main reason I do it this way is so I can glue the sandpaper down to the block. With the paper glued down, there is less tendency to oversand the under side of the wings.
Makes it much easier (and faster) to get an accurate arch on the bridge.
My block is domed on both sides. 60 grit on one side & 220 on the other. Once the fit is perfect, a few quick passes with a scraper (immediately before gluing) takes off the sanding scratches & makes a fresh surface for the glue.
I HAVE had trouble with bridges coming off... This method seems to have cured that.
P.S. I always sand my bridge plates in the dish, just before gluing them down.
PostPosted: Thu Sep 09, 2010 11:43 am
Todd Stock wrote:
Imagining the system as rigid is a simplifying assumption - in the actual system, the majority of bridges (less the bulkier designs with blended saddle and wing area...a little more rigid and higher mass) are relatively flexible - particularly if the wings are refined as per the traditional practice. Sure - stiffer than some bracing, but still able to conform easily to a few thousandths of convexity.
As I mentioned earlier, the tensile loads are pretty low, given both bridge and top distorts, and the top is likely to more easily distort on a lightly built instrument, so whatever radius is used (flat, 15', 28', etc.), string reactive forces are going to cause a lot more stress than the tensile forces which are in any case likely to equilibrate a few weeks after final assembly.
Same deal with the saddle...with 30 to 80 lbs of download from the strings, a few thou difference in curvature is not going to be an issue...provided the bottom of the slot and the saddle are uniform. If you have some time to try this, clamp a saddle in a TT tester and load...not unusual to see a couple thou deflection at very reasonable loadings. Between the top's tendency to move toward the bridge's bottom radius and the real world ability of even stiff bone or ivory to distort, I don't think the saddle fitting issue is all that critical.
Any one piece that requires a bit of clamping pressure to fit tight isn't going to be a big deal. But the cumulative effect of a lot of little things being clamped to fit, throughout the guitar?
Last edited by Howard Klepper on Thu Sep 09, 2010 11:56 am, edited 1 time in total.
PostPosted: Thu Sep 09, 2010 11:55 am
I am hating to hear sanding on a piece of paper taped to the top called "flossing." The usage was tolerable (even though a bit idiosyncratic) for drawing sandpaper through a neck joint. What does sanding on a piece of sandpaper fixed to a form by moving the part to be sanded have to do with flossing? It might make sense if flossing one's teeth consisted of a stationary piece of floss and movable teeth that are rubbed against it. Is fitting anything by means of sanding material off it now to be called "flossing"? It sets my teeth on edge.
PostPosted: Thu Sep 09, 2010 12:22 pm
First name: Marco
Last Name: Pastorio
Country: Italy
I'm reading here that some use to scrape the surfaces prior to gluing. I saw it here so I'm writing here, even if it doesn't apply only to bridges.
I've been taught that wooden surfaces to be glued are not to be smoothed out too much before gluing to achieve maximum gluing strength. Actually, it would be better to leave them quite rough: for instance a cabinetmaker that veneers the traditional way would prepare surfaces with a toothed scraper before gluing with HHG.
Perfectly flat surfaces ain't good for gluing especially with water based glues because it's the glue that penetrates into the wood that makes the bond strong. Scraping also pushes down superficial wood fibers, closing wood pores and making the glue penetrating worse. The water in the glue may rise the fibers, but I wouldn't bet that is what I'd want in this case...
Personally if I need a strong bond I wouldn't sand the surfaces with a finer grit than 120... It's not that a planed surface won't glue at all, only I think the resulting bond wouldn't be as strong...
PostPosted: Thu Sep 09, 2010 12:37 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
In my experience, the bottom of the bridge will become curved on the back edge from string pressure over a few years, regardless of how it is shaped to start with. The issue is whether the extra stress during the clamping of a flat bridge has a lasting negatve effect, and I have just not seen it.
The main issue I have encountered that causes me to fit the bridge more carefully on old guitars has to do with the front-to-back radius that is often created in the top and bridgeplate when a bridge lifts. Clamping a flat bridge in those instances can create extra stress that tends to crack the bridge through the pin holes. Though the bridgeplate can be heated and the top clamped flat, I have found that those guitars work better if I match this front-to-back curvature when shaping the bottom of the bridge.
PostPosted: Thu Sep 09, 2010 12:48 pm
First name: Jonas
Last Name: Baker
City: North Haven
State: CT
Zip/Postal Code: 06473
John, can you explain your method for matching this type of curvature in a bridge glue joint? I have seen people lay sandpaper on the top and just rub the bridge along the area where the bridge will be glued, but this might be more difficult in an old guitar where you have more front to back curvature.
Jonas
PostPosted: Thu Sep 09, 2010 12:50 pm
Finally something worth discussing! :D
What I be hatin be when people be all flossin dey pimped out guitars all over de internet.
http://www.urbandictionary.com/define.php?term=floss
http://www.chassonguitars.com
PostPosted: Thu Sep 09, 2010 1:01 pm
Marco, this is a myth from the time when the glue bond was thought to be a mechanical attachment in the form of "fingers" of glue reaching into the wood. It was thought that scratches gave the glue a place to grab on to. Some of that does occur, but on a much smaller size level than used to be imagined. Actually, most of the strength of glue joint is from chemical attraction at a molecular level. Glue does need to wet the surface of the wood, but this is wetting that occurs at a microscopic scale. The glue itself is a rather weak material (with the possible exception of epoxy) and its thickness should be minimized.
The reason for toothing surfaces to be veneered is to provide a place for excess glue to go, so it won't form a bubble. This is a problem only when gluing a thin material such as veneer over a large surface.
Last edited by Howard Klepper on Thu Sep 09, 2010 1:06 pm, edited 1 time in total.
PostPosted: Thu Sep 09, 2010 1:05 pm
First name: duh
Last Name: Padma
Duh Padmas
Diamond impregnated dental floss...
*works great on Scroll and coping saws,
*cleaning out nut,
* bridge slots
* fret slots
* hundreds of other uses.
Great for dentures too!
$20 for a 500ft role, in an envelop to the Padma C/o dis here web site. Sorry no plastic or COD orders.
Order now!
blessings
duh Padma
PS: Tanx for the idea Howard. Lance, Brock and me, well we gonna cut you in for 10%
PostPosted: Thu Sep 09, 2010 3:19 pm
OK Howard you're right as usual and I'm doomed.... :D
I'll revisit my toot at some point and nix calling it "flossing" in your honor and instead call it "sanding" which, unless you have any objection seems to more accurately describe the verb.
Not that I am arguing mind you but when I floss a neck joint early on I do the heavy lifting so-to-speak with a piece of stinkin sandpaper stuck to the guitar body and I move the neck around instead of pulling strips. Maybe this is where I got confused (about this task...) and started calling sanding anything on what it's going to be mated to flossing. oops_sign idunno
FYI my business cards list me as a "Loothier" since I learned that spelling from you too.
We're all doomed I tell ya, dooomed...... :D
Padma my friend I'll take two and forward the appropriate funds to this here web site c/o You! :D I also may take you up on this source that you have for removing curses.... beehive Eat Drink :D
PostPosted: Thu Sep 09, 2010 4:24 pm
Doooomed I say!
Atom bomb cake...
PostPosted: Thu Sep 09, 2010 5:03 pm
First name: Marco
Last Name: Pastorio
Country: Italy
Indeed, surely I wouldn't glue a surface treated with a toothed cabinet scraper with HHG or titebond when searching for the strongest possible bond (unless maybe with epoxy), but still I don't know if a smooth surface with fibers pushed down is what I'd search for when gluing (especially on a dense, oily and close-grained wood). A too rough sanding ain't good either, but 120 is fine enough and even 80 would do for some tasks.
All I know is that the both the cabinetmaker I worked with and the luthier I had lessons with had similar opinions about it. The latter made me sand the bottom of the bridge (that has been previously scraped) to have stronger bond.
Anyway I'll try to do some specific test anytime soon to check what works better... trying it yourself is the best way, I suppose...
PostPosted: Thu Sep 09, 2010 6:07 pm
That picture is priceless! [:Y:] :D
Hi Marco - I like that you want to do some of your own testing, that's what I do too when trying to sort though some of the information that is in conflict with each other. Good going! [:Y:]
PostPosted: Thu Sep 09, 2010 6:59 pm
I like "lapping" as Todd suggested. But I think technically, first you rough sand, then you lap.
You didn't learn that spelling from me!
PostPosted: Thu Sep 09, 2010 7:46 pm
Oh yes I did learn that spelling from you.... :)
It was in this thread: http://luthiersforum.com/forum/viewtopic.php?f=10101&t=21071&p=292399&hilit=Loothier#p292399
Like it or not Howard you have had a major influence on many of us - some of it was actually positive!!! [clap] [clap] [clap] [clap] [clap] [:Y:] Seriously you are one of the guys who I have always listened to and I'll never be sorry for that.
Filippo I agree that this is a good discussion, kind of like the old days too, eh? I also agree with your surprise that I share regarding #1 in your post and 80 grit.
Regarding over built steel strings as I think that I mentioned I had a Gallagher in here that had a number of issues and it was new too... The neck was over set making a high saddle necessary and that lifted the bridge. The thing weighed over 6 pounds and reminded me of Internet dating just moving it around my shop... Anyway that bridge was also smashed onto some thick finish that was under the perimeter of the bridge and needed to be cleaned up/fitted and reglued.
The top was spruce, probably sitka but around .140 at the sound hole edges. As such the non-fitted bridge and the thick top were not liking the idea of being smashed together with brute clamping force and the bridge lifted along the back and both wings were up too. It was nearly self removing.
The owner was obviously not pleased with the guitar needing to be fixed so soon and the action made it nearly unplayable too. We reglued the bridge, discussed that the neck angle was over set and needed to be reset if the guitar was to be kept (it's not being kept) truss was adjusted and saddle lowered after a mini fret dress. It played better and hopefully will no longer try to toss it's bridge away.
So yeah there may be something to the idea that an over built guitar and possibly an inflexible bridge design, mine is pretty inflexible, may not stay in place well unless fitted well.
PostPosted: Thu Sep 09, 2010 8:11 pm
Filippo Morelli wrote:
Just add a few observations/thoughts to a lively discussion ...
1) I'm surprised some folks are gluing up at 80 grit. Everything I've understood from modern research shows a freshly planed/scraped surface to be the most superior for glue-ups......
One assumption there is that the goal is "the most superior" bond you can get. My goal for all my joints is simply that the glue joint is stronger than the wood by a reasonable margin. From everything I've seen, wood surfaced with 80 grit easily meets that criteria provided everything is well executed. If things aren't well executed, the best surface prep isn't going to help.
I've only repaired about a dozen lifting bridges (none on my guitars) but none of the failures had anything to do with surface prep. Glue was always still well stuck to both surfaces. It's the glue itself that comes apart either from heat or more often, from too thick of a glue line.
PostPosted: Fri Sep 10, 2010 1:54 am
That is precisely the point. A roughened joint will have a thicker glue line than a smooth joint. Less contact area. Therefore weaker, more prone to failure.
L.
PostPosted: Fri Sep 10, 2010 5:10 am
[:Y:]
Exactly so.
Some will think a problem or operation to death, argue whether terms are correct, haul up scientifical fact based on recent tests, etc. to promote the "best" solution.
Others will just "do" based on longtime experience.
Almost all that has been said is good, but just imagine a beginner reading this. OMG, what do I do!?! Do I radius, sand, floss, scrape, lap, or just give up?
PostPosted: Fri Sep 10, 2010 9:30 am
First name: Hugh
City: Lake Oswego
State: oregon
At some point rougher sandpaper would mean enough more glue to be prone to shear, but have you reached the critical point with 80 grit? My sanding disks are 80 and seem to be fine. Maybe there is less pull on the whole top than the bridge.
PostPosted: Fri Sep 10, 2010 11:26 am
80 grit is absolutely adequate. I've been using it for all the guitars I've built and have yet to see a bridge pull up. 1000's of guitars came out that way from a production shop, if it was a problem I know the method would have been changed long ago.
More important is the fact that for rosewoods and ebony the surface must be freshly sanded (or scraped, whatever floats your boat) before gluing. Oxydized oils on the surface will compromise any glue joint.
Laurent Brondel
PostPosted: Fri Sep 10, 2010 11:50 am
L.
I'm curious if people are actually having glue failures that they can attribute to surface prep with 80 grit or if this is, as Haans says, just "theory" and over-thinking. I've got 15 years worth of guitars out there and almost every single brace is surfaced with 80 grit and I have not had a single failure. All my scarf joints are surfaced with 120 and no failures. I scrape most of my bridges (mostly at the last minute to get rid of oils and contamination) but I use 120 grit to smooth the top after routing the finish off. Again, 0% failure rate. I also have glued up dozens of test samples over the years and never seen a problem due to 80 grit surfacing.
I have no problem to be solved. I'm simply suggesting that if any of you do, you would probably benefit by looking in other places first. Poor fit, not enough clamping pressure, too much open time, bad glue, that kind of stuff.
PostPosted: Fri Sep 10, 2010 7:38 pm
Users browsing this forum: phavriluk and 31 guests
